When the ’puter center at school would toss old terminals when “upgrading”, I’d grab 1 or 2 nice ones, like ADM-11s. Problem is, they were filthy, inside and out.
I’d literally disassemble them down to the boards, harnesses, cases, etc., and soak’n’scrub them like doing the dishes.
Ever see a CRT bobbing up’n’down in a utility sink filled with sudsy water? And yeah, I’d take a brush (well, stiff paintbrush, actually) to boards exactly like in the pic. Keyboards, disassembled down to the keycaps, springs, you name it.
All of it thoroughly dried and reassembled, they worked perfectly!
I read the OP and I comprehend fairly well for my age. sp5it came back to you almost immediately with a warning and a first step.
Hope it all works out and you can get your moms computer back up and running. I know the feeling of wanting to get things done for family. I get computers and electronics dropped off at my house weekly from family wanting free work. And we do it because we love them.
Just for the anecdote, yes, putting a HDD in the freezer (in a plastic ziplock bag) can work in some special cases (when the HDD is overheating too quickly and starts being unresponsive). I had an HDD do that and managed to backup the data.
Now, in case of damaged sectors, not sure it would help!
A great tool to recover files is PhotoRec (and it’s Free Software)
Tap water is actually pretty “clean” once left to air-dry. Ain’t like washing it in seawater or anything…
Even if some got trapped in little nooks’n’crannies, heat from the beastie in operation would help evaporate what’s left.
I never worried about it, not even soaking the yoke (big open coils) from around the CRT’s neck. Washed thoroughly, rinsed thoroughly, then left to air-dry a coupla days before reassembly, there’d be very little water left to cause any mischief.
And even electrolytics were end-sealed with rubber caps, so ain’t like anything would get ruined by water.
I did so many terminals and things, that all worked without any problems after cleaning, so I was confident that it was safe.
Off topic buuuuttttt…… here in NC we had a family owned pizza place that made NY style pizza. Ridiculously good! However ’“ Turk” swore the ones they sold in NYC were better. Said it was the water that made the difference.
Well, do show her howmuch dust has accumulatedinside the case when you open it. But omit the bath with toothbrush. Some people believe what they see on the Internet.
You should know that Aomei is Chinese made, and my antivirus detected it as malware. Switched to Macrium Reflect Free for system backups, and am using ViceVersa for backing up personal files. Macrium Reflect is much more sophisticated than Aoemei.
Take a look at SyncBack from 2BrightSparks.
This is a data backup program, not an image program.
There is a free for home users version.
I have had clients using it for many many years.
I like to do an image, I like Paragon the free version for home users.
Then setup a Syncback schedule to keep the data file backups up to date.
All the Best,
Jeff
I’m also a Macrium Reflect user. I used to use paid Acronis and abandoned it.
FWIW, for ALL of them, whatever you use, it’s a VERY good idea to have a spare drive around and test an image backup once in awhile. You don’t KNOW it works until you do this. I have had failures. That would be adding insult to injury.
