“REVIEW”: Acebeam TK16 (AL) – Triple Osram – 1 x CR123A / 16340 - 1300 Lumens [Pic Heavy] - ***BEAMSHOTS ADDED - POST #14***
Nop! The flashlight has an integrated shelf.
The way to do it is from the top (bezel) as I described.
I have a copper TK16.
Great light. But it did have one problem.
One day, the clip just broke apart and shot off the light. One of the arms on the clip that grips the light literally just snapped off. I wasn’t even carrying the light when this happened. It was sitting on a desk. The light was less than 3 months old at the time.
Apart from the crappy clip quality, it’s a great light.
I asked the question because I thought TK18 and TK16 were of the same construction… I’m really sorry.
If you don’t mind, may I see some images around the TK16 lens?
Here’s an image of the TK18 around the lens and the driver’s side
@Naito:
There's a link in my signature to a thread on how to post pics on BLF.
If you don’t mind I will post it later today as I don’t have the light with me at the moment :wink:
Thank you both.
I managed to take some photos above the MCPCB and you can see that below it it has a shelf.
I also took some others, with and without the glass lens, similar to your photo.
I wasn’t able to take the driver of its place. I guess the wires are very short, so I would have to unsolder the driver to take it out.
It is screwed in with 2 screws too, as show in the review post!
No glass lens >>>> With glass lens
Indeed a nice little light! I didn’t have any issue with the clip so far. I just wish it was deep carry from the tail.
I also would like that changing modes was a bit faster (as Olight), but it is not unbearable :wink:
Definitely one of the best, brightest smaller 16340s in the market! :+1:
Sorry. I can’t seem to get the TIR lens out of the bezel side.Do you have any suggestions?
I was able to disassemble it. Thank you.
Yup! Take the bezel out, take the lens, take the o-ring and then tap with the flashlight in your hand, with the lens down.
If you cannot remove it, try a toothpick or something pointy but not hard to alleviate the TIR on the sides. Then tap again.
It is not glued nor stuck, but the holes in the MCPCB and even the thermal paste below it may be hindering it from coming out.
Try the toothpick gently around the TIR, without much pressure :wink:
If you have a suction cup, you can also attach it to the TIR and try to pull it out!!
See this thread: help removing carclo optics from p60 dropin
Hi guys. Any idea how big the MCPCB is?
Looking at the comparison picture between the TK16 and FW3A it’s hard to judge because the FW3A is taller and sits closer to the camera lens.
I didn’t take it out for a proper diameter measurements, but the one in the TK16 is slightly smaller than the one in the FW3A.
Also, the one in the TK16 is straight on the sides and not round, which makes it slimmer, too. Besides that, there are the screw holes on each side.
If you want to put the TK16 MCPCB into the FW3A you can, but the reverse I am afraid it is not possible :zipper_mouth_face:
Ahhh thank you. I had plans for the Osram triple in another light and wanted to install some very special 3000K SST-20’s in the TK16…
I guess that the TK16 may fit in lights like the FW3A and convoy lights, but the FW3A MCPCB seems made for larger diameter lights.
I don’t have the lights with right now but sunday I can try to measure it more accuratelly so that you know the real diameter.
Maybe the Jaxman E2L MCPCB will fit. It has a 19mm diameter.
Or just try a reflow. It’s not that hard, even on a triple.
