Well…bad news…now mine says RETURNED TO SHIPPER…WTF…
That is really bad news.
Several possible reasons for this, if you ordered batteries as well, that is the most likely cause.
Neal said it was that…hope they dont stop it again.
Brainsick67:Well…bad news…now mine says RETURNED TO SHIPPER…WTF…
It is…i want to cry…lol…
I just received my GT94 from nealsgadgets. However, there is an issue - read and view below.
However, something doesn't look correct. The LEDs are de-doomed as expected, However the reflector is not polished. It's orange-pealed. Did I miss something about a last minute design change?
This is what nealsgadgets shows for the reflector and what was previously spec'd - Reflector: 118 mm inner diameter, aluminum, smooth finish
However, something doesn’t look correct. The LEDs are de-doomed as expected, However the reflector is not polished. It’s orange-pealed. Did I miss something about a last minute design change?
This is what nealsgadgets shows for the reflector and what was previously spec’d - Reflector: 118 mm inner diameter, aluminum, smooth finish
It should be smooth…MATT SMITHs video its smooth…that sucks…seems like they accidently put the GT4 Reflector in it…sorry man…hope ours doesnt have it.LET US K KW WHAT YOU FIND OUT
OP reflector is a good thing. I’d have that.
This was the first light I purchased from Neal, great service for myself. I ordered after watching Matt Smith's video on 9/26, I also received mine today, :-) I didn't even notice until. Mine is the same.
What is the reason for the OP reflector?
OP reflectors give a smoother beam pattern at the cost of throw.
Neal just said he will be sending a smooth reflector to those who received an OP and also to those who were already shipped.
Sorry for that.
Sorry for that.
I don’t think that’s a fair fix. Not everyone has the tools and knowledge to remove the bezel on these monsters to replace the reflector.
tatasal:Neal just said he will be sending a smooth reflector to those who received an OP and also to those who were already shipped.
Sorry for that.
Indeed!!!
tatasal:Neal just said he will be sending a smooth reflector to those who received an OP and also to those who were already shipped. Sorry for that.
Perhaps someone could provide the list of tools and instructions required to remove the bezel and replace the reflector.
I'd be okay with replacing the reflector myself.
Coyotehawk: tatasal:Neal just said he will be sending a smooth reflector to those who received an OP and also to those who were already shipped. Sorry for that.
I’d be okay with replacing the reflector myself.
I don’t have the light myself, but I know the bezel is not glued, but tight.
Yes, a video will be made and I will post it once available.
Are you serious, orange peel? That’s sucks!
Neal just sent me a message that he'll send me a smooth reflector when it is available. All good!!!
Is it an easy switch I don’t mod or fix,but simply buy flashlights
Quick beam shot on turbo comparison: GT4 vs GT94
Distance: 9 feet 3 inches.
GT4 step down after: 2:53 m:s
GT94 step down after: 00:58 m:s
NOTE: Large cooling fans was used because of high ambient temperature. Step down times would have been less without fan.
GT4
GT94 with OP reflector
NOTE: Daisy peddle effect was seen on outer edges of beam, but not include here. I wanted to compare the exact same areas of the spot beam.
I will do the same test after I receive the smooth reflector for the GT94.
Why such difference in step down time?
