Replaced previous Charity Sale thread :-)
Warrior X Pro $90.97 (will be $129.95)
https://lmxdeals.com/olight-wxp-rgb
● Max 2,100 lumens with a 500-meter throw
● Passed 3-meter drop test and IPX8 waterproof
● A max 8-hour runtime powered by a customized 5000mAh 21700 lithium battery
● Includes a MCC3 fast charging cable with a 2amp output, 2x the speed of previous models
● Redesigned raised tail switch for an unprecedented intuitive operation experience
Baldr RL Desert Tan/Black $77.97 (Will be $129.95)
Note: The RCR123A battery is not suitable for Baldr RL
● 5mW Red laser helps you aim at target more precisely
● Three light settings available by one rotating switch
● Both Glock rail and Picatinny rail are compatible with Baldr RL
● Max 1,120 lumens and 240 meters throw with 4 hours runtime
Olantern $55.97 (will be $79.95)
https://lmxdeals.com/olight-olantern
● A reliable outdoor companion with max 360-lumen output and max 80-hour runtime
● Never miss a single surprise with even, steady 360-degree lighting distribution
● Use the flaming module to decorate your blissful moments with beloved ones
● A warm dinner or an adventure journey, Olantern is always there to witness your unforgettable time
O'Pen 2 CU $48.71 (Will be $64.95)
https://lmxdeals.com/olight-open2-cu
Issues from O'Pen 2 fixed with new refill
● Made of the beautiful and durable copper metal
● Includes four brightness levels ranging from 5 to 120 lumens
● Up to a 10-hour runtime on a full charge
● Fully charging in less than an hour via USB-C
● Perfect for daily pocket carry when you need a high-quality pen or bright light on the go
O-Refill $0.00 (Will be $9.95)
https://lmxdeals.com/olight-refills
No worries about running out of the refills any more!
The upgraded refill Ink cartridges for O'pen 2 and O'pen 2 CU, 3 pieces per pack.
Customers who have O'Pen 2 can get the free o-refill pack when you need it. Offer is available until Dec. 31, 2022.
Free shipping for orders over $49 and limit 1 pack per order
MEGA PACK $208.05 ($346.75 value)
https://lmxdeals.com/olight-oct-mp
● Olantern: A reliable outdoor companion with max 360-lumen output and max 80-hour runtime
● Warrior X pro: Max 2,100 lumens with a 500-meter throw. Passed 3-meter drop test and IPX8 waterproof
● i5T EOS Ti: Max 300 lumens output with a 60-meter beam distance
● O'Pen 2 CU: Perfect for daily pocket carry when you need a high-quality pen or bright light on the go
● i3T EOS ODG: Easy to carry in a pocket or mount onto a hat with the included two-way pocket clip
Olantern Bundle Warrior X Pro $125.94 ($209.90 Value)
Olantern + Warrior X pro
https://lmxdeals.com/olight-lwb
Warrior X Pro Bundle $97.74 ($162.90 Value)
https://lmxdeals.com/olight-wxp-i5t
Warriox X Pro + Green i5T
