i showed the prototype a year ago ;)
i fixed the links
Also hadn’t noticed announcement of this model before.
It uses 3x XHP70.2 … so it would look like a competitor to the Haikelite MT03 TA Devourer, which also uses 3x XHP70.2, which also uses NarsilM and Texas Avenger driver. But maybe Lumintop’s build quality may be better? (MT03 TA Devourer claims “21000” lumens which is more of an exaggeration, whereas the GT3 specs indicate 18000 lumens, which might be possible in ideal conditions (high-drain battery + maybe if spring-bypass is needed?)
I wonder how the battery carrier tube looks like on the GT3?
So much mis/lack of information in the listing of the GT3 - says NarsilM, then says Anduril, says smooth reflector then shows an OP...
Would like to see the battery tube and if the button has a LED controlled by the firmware (EDC18's switch LED is not controllable by firmware).
That bunny button, if like the EDC18, could be stiff and prone to wearing down - not big issues, but they could have done better with the EDC18's button for sure.
If the GT3 has Anduril, I’ll want one. I have a big pile of flashlights I would like if they had Anduril, don’t want to add to that pile.
it has Narsil (neal added the anduril line because of the license i guess)
and teh reflectors are OP
Lumintop GT3 previews ..... (link to original post on Baidu)
2. "Soda Can design........ with additional texture for gripping and aesthetics"
With a thankyou to the Baidu FC for providing these previews.
Thanks,
Martin
glad you like the shape of the "knurling"
i was allowed to choose this from 3 suggestions when i visited Lumintop a year ago :)
XANES® 25C 40W LED COB USB Rechargeable Strong Floodlight Emergency Power Bank Waterproof Work Light
please post below if you are intersteded in one of my silent deals
(or just check on my page if you already have "the password" ;) )
ROVYVON A1X 650Lumens XP-G3 Polyamide EDC Keychain Flashlight USB Rechargeable
whats the password? im interested in the rovyvons!
the coupon has expired
which deal are you reffering to?
ROVYVON Aurora A5x GITD 650Lumen EDC
thanks - i let them fis it asap
same as a7x, also expired
yeah - i disable them for now
When did the GT nano get released?
Oct 15th
https://budgetlightforum.com/t/-/31589/5378
the RovyVon code has been fixed
