Ok, cool. If I end up going the spring route, using a small spring on the driver would work, too?
I’m a bit confused on how a thicker MCPCB would leave a gap. Wouldn’t it be an issue of less space, not more? I’m clearly not conceptualizing this properly. Thanks for taking the time to explain.
Jaxman uses a standard 16mm mcpcb with a thickness of 1mm in thier flashlights and they designed the flashlight for this thickness. They don’t sell it as a host, that’s why they probably did it. I received 1mm mcpcb with the set when ordering the host version.
I think the Convoy T2 is a better choice for us (modders). Think about it too.
It looks like a T2 takes a 17mm driver as well? If I put in one of those two drivers I suggested into a T2, I’d be going to all 14500, and it would work fine, correct? And the T2 takes a 16mm DTP MCPCB fine?
Re:219b in a T2 with a FET driver (as I’m planning), so you think my Keeppower 14500 1000mAh puts out just too much at 4A continuous to not fry the emitter? Perhaps I should get a Vapcell 3A?
Nop, T2 uses smaller MCPCB.
There is an edge in the top of the shelf, so it uses 14-15mm MCPCB.
Of course you can file the 16mm board to make it smaller.
And…it is also designed for 1mm thick boards.
Ok, rad. Thanks for the info. So I’d still be sanding down an MCPCB. Does my build make more sense for a T2 or E3? Or does it not matter? 17mm DrJones FET driver (or Mtn17-DDm), whatever DTP MCPCB I can make fit, 219b emitter, running off of 14500s.
Thanks for the info on this thread and the other, Mascaratum.
I think I’m going to go the Jaxman E3 mod route in order to not have to file down or modify a 16mm MCPCB as much. If I’m leaving it the same thickness and using an O-ring, what size should I get?
Hey again, everyone. I’m sitting here with my Jaxman E3 trying for the life of me to take off the bezel to get to the LED and driver. How did you open the head up and get to the LED? It seems like the bezel is either glued or really forced in there so tight I may never get it off…
Press the bezel against your hand (or a glove, something that helps with grip) and rotate the flashlight anti-clockwise! It shoud open that way, it didn’t take me much to open mine! :+1:
As far as I can tell, this one is not sold as host only. Also, as far as I can tell, this version was not copied by other brands/manufcaturers, unlike the previous version.
What kind of build are you planning?
These are very easy to disassemble. I had intended to mod mine but the more I used other lights I realized how good the E3 is and decided to leave it stock. I was a bit disappointed with the max output initially but later found out that some of my old eneloops weren’t providing enough power, once I got new batteries the issue is gone.
