Waiting for next batch [AMZ US Available Now] $49.99 Sofirn SP36 Anduril Version
210 posts / 0 new
TexasToasted
TexasToasted's picture
Last seen: 1 hour 28 min ago
jasontheguitarist wrote:
I caved and bought one on amazon too. Says there are 8 left in stock now. It says free expedited shipping, I assume it’s shipping from china, unless Sofirn has a warehouse in the US.
Ordered mine from Amazon May 22.
Tracking shows “Package has left the carrier facility
CHANGSHA EMS, CHINA” on May 26.
jasontheguitarist
Last seen: 12 hours 35 min ago
That is expedited. Normal china shipping doesn’t even have active tracking for like a week. 4 days to have the package actually trackable and making progress is pretty good for china shipping.
d_t_a
Last seen: 17 hours 59 min ago
Sofirn SP36 (4x XP-L2, “6000” lumens) vs Sofirn SP36 “BLF Anduril” (4x LH351D NW, “5650” lumens) beam comparison
SP36 XP-L2 has a cool/bluish hotspot, while the SP36 LH351D has a more uniform neutral-white tint across the hotspot, corona and spill area.
The “wall” ahead is around 18 meters or 60 feet away from the flashlight.
distance from the “building” in front is estimated to be around 150 meters (120 meters direct ground-to-ground distance as per Google Maps)
Sofirn SP36 “BLF Anduril” (4x Samsung LH351D 5000K neutral-white, “5650” lumens)
comparison to:
Sofirn SP36 (4x XP-L2, “6000” lumens, NarsilM v1.2)
MKayze
MKayze's picture
Last seen: 1 month 15 hours ago
It’s currently out of stock. When is it gonna be available for purchase?
Relampago
Relampago's picture
It’s available here: BG SP36 Anduril
“Electricity is really just organized lightning”
― George Carlin
jasontheguitarist
Don’t get it from banggood, its cheaper directly from sofirn. https://www.aliexpress.com/item/33017839387.html?storeId=2933049&spm=a2g...
hodor
hodor's picture
Last seen: 1 day 7 hours ago
Thanks d_t_a! Is the Anduril version still glued?
d_t_a
I would suppose so. I don’t have the skills to remove the driver board of the SP36..
hodor
hodor's picture
That’s a shame, still very tempting though!
Glennac
Last seen: 1 year 6 months ago
I am comparing my original XP-L2 (6000lm) with this LH351D (5650lm) and this BLF model is significantly dimmer than the original. Is this to be expected? Would 350lm make that much difference?
Have tried several sets of batteries at different amps and results are the same. This light sure doesn’t SEEM like it 5650 lumens. Several of my smaller 26650 lights appear much brighter.
What’s everyone’s experience now that they have had them for a few weeks?
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 5 days ago
Yeah, there are three reasons for this:
1. The XP-L2 70CRI still has a lower VF than the 90CRI LH351D, making it draw more current.
2. The LH351D 90CRI is a less efficient LED.
3. The LH351D is quite a bit floodier, making it seem less bright.
I mean, if my modded LH351D 90CRI BLF Q8 with dual BeCu springs can only reach around 5200 lumens OTF, then a stock Sofirn SP36 90CRI LH351D won’t get more than that.
d_t_a
I think one reason already mentioned is that the SP36 with LH351D is floodier (less “punch” in the center hotspot). It has a creamy smooth tint from hotspot to the corona, unlike the harsher difference of the SP36 XP-L2 where the hotspot is a visibly different color temperature than the corona.
LTC
Last seen: 1 day 11 hours ago
Hi guys, I was playing with those fancy modes Anduril on the SP36 for comparison with the MF01S Anduril.
Noticed something unusual or different.
In the MF01S, at Muggle mode max ramp, immediately it steps down in a very noticeable step ramping(ramp down more than 10 times). Read the MF01S manual, found something written that the temp sensor might be off. When i checked the temp, indeed, the calibration was off. Re-calibrate the sensor and it works fine now.
For the SP36, at Muggle mode max ramp, after about 5 seconds, it straight away ramp down to floor in 1 step. I checked the temp and it was off too. Before applying a re-calibration step mentioned in the MF01S manual, I checked the SP36 manual and nothing was written regarding the step down. Well, it’s Anduril, I just proceed to re-calibrate the sensor. Temp is ok now after calibration. But this time, on the SP36, unsuccessful. It still step down to floor after 5 seconds.
Anyone experience this?
I understand it’s not really a big issue that maybe most of us don’t use the muggle mode.
I’m just wondering if something is wrong and will lead to something else or worse…
hodor
hodor's picture
I finally bit the bullet and ordered one. I’m curious though, does anyone know what tint bin was used for the SP36 or is it a lottery?
ToyKeeper
ToyKeeper's picture
Last seen: 10 min 46 sec ago
That is because the SP36 used an older version. In the older version, muggle mode responded to every temperature warning by panicking and going directly to the lowest level. In newer versions, it tries to adjust in smaller steps.
Additionally, older versions had a lot more jitter in the measurements, so they were more prone to sending spurious temperature warnings. Newer versions put the measurements through a strong lowpass filter to avoid that.
LTC
Oh… got it now. Thanks for replying ToyKepper.
Sofirn
Sofirn's picture
Last seen: 39 min 15 sec ago
SP36 Pro 4*SST40 emitter,8000LM expect at the end of month have available
Paul321
Paul321's picture
Last seen: 1 day 16 hours ago
I assume you mean the end of October 2020 from Amazon
Paul-
oakey22
Wish I had seen this earlier, just ordered the Sofirn SP36 BLF Anduril 4*Samsung LH351D 5650lm from Ali.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 6 hours 21 min ago
6.500K or 5.000K? Anyway, even 6.500K was reported to be much warmer than expected, more likely to be around 5.700K. Thumbs Up
Fescron
Last seen: 8 hours 28 min ago
I hope it’ll come in 4000k (but 5000k is also fine) Big Smile Will it be able to charge with a type c – type c cable? And will it have powerbank functionality? IMO that’s a nice to have for “just in case” situations, I carry powerbank(s) with me but integrated functionality in this beast of a flashlight will give me more peace of mind…
Lux-Perpetua
Fescron wrote:
I hope it'll come in 4000k (but 5000k is also fine) Big Smile Will it be able to charge with a type c - type c cable? And will it have powerbank functionality? IMO that's a nice to have for "just in case" situations, I carry powerbank(s) with me but integrated functionality in this beast of a flashlight will give me more peace of mind...
I suggested Sofirn to look for a Px flux bin and a DC or DD chromaticity bin of SST40, being around 4.800K. This one seems to please most of us, being quite neutralwhite and not greenish, see Wildtrail's BLF D80v2.
If I recall correctly from the SC31 Pro thread, Sofirn is definitely interested in SST40 4.000K but so far it is difficult for them to source.
Type C-C cable compatibility should be easy to achieve. Basically, it's just two additional resistors in the USB-C port to make it work. But even with USB-C (type C-C) it will still be using 5V 2A (10W) or maybe 12V 1.5A (18W) as we have seen it before in Sofirn's SP36S, see my picture below for reference. A powerbank mode ("reverse charging") would be great but my guess is that SP36 Pro will not come with that feature as it requires significant driver changes. But maybe we will be surprised... Wink Since Wurkkos has introduced reverse charging with their new HD20 model, I am confident that Sofirn will eventually offer this functionality, too. I hope that future driver revisions will offer the PowerDelivery protocol with 36W (12V 3A) for faster recharging.
Fescron
Nice! Guess I’ll possibly get myself another SC31 Pro in the future then Smile
Lux-Perpetua wrote:
Type C-C cable compatibility should be easy to achieve. Basically, it’s just two additional resistors in the USB-C port to make it work.
Yeah I was looking up info about type c – c and I might try to mod my SC31 Pro and/or make an adapter which adds resistors to “activate” 5V power on PD compliant chargers.
Lux-Perpetua wrote:
But even with USB-C (type C-C) it will still be using 5V 2A (10W) or maybe 12V 1.5A (18W) as we have seen it before in Sofirn’s SP36S, see my picture below for reference.
Cool! I did not know the SP36S had this functionality so I hope/assume they’ll add it to the SP36 Pro too!
Lux-Perpetua wrote:
A powerbank mode (“reverse charging”) would be great but my guess is that SP36 Pro will not come with that feature as it requires significant driver changes. But maybe we will be surprised… Wink Since Wurkkos has introduced reverse charging with their new HD20 model, I am confident that Sofirn will eventually offer this functionality, too.
Yeah I have the same feeling, and yes I was pleasantly surprised by this functionality of the HD20 which was one of the reasons why I ordered it. I kinda feel bad they didn’t include this functionality on the SC31 Pro though, since I carry this light everywhere with me in my backpack and powerbank functionality would save me some weight without also carrying a dedicated powerbank. I don’t see me carrying the HD20 everywhere.
Do you/anybody have any idea if powerbank functionality is also planned for a future revision of the LT1? Apart from the SP36 that’s another light I also want to get but might wait a little longer for a new version to come out…
Lux-Perpetua
If I got Barry right, the USB-C output "powerbank" feature for LT1 is being tested by Sofirn already. Let's hope we get to read some amazing news anytime soon. Smile
Fescron
Lux-Perpetua wrote:
If I got Barry right, the USB-C output “powerbank” feature for LT1 is being tested by Sofirn already. Let’s hope we get to read some amazing news anytime soon. Smile
That’s awesome to hear! I’ll be sure to hold off buying an LT1 then for now, I won’t really need it anytime soon… Let’s hope I can buy it by the end of the year on Aliexpress because the import rules will change in the EU and buying directly from China will certainly get more difficult and/or expensive Sad
Sofirn
Sofirn's picture
standard tint will be 6000-6500K, 5000K will also be available by then.
Sofirn
Sofirn's picture
sell through sofirnlight.com
AK4
Last seen: 4 months 1 week ago
Когда поступит в продажу ?
Optiblue
Last seen: 2 months 1 day ago
Can’t wait for this, hopefully 5000K will be available!
Don't keep blue bin emitters alive during the golden age of neutral white!
