at 1km you will not be able to tell much as it is hard for most human eyes to even see that far clearly.
Although my statement above was a more general opinion I hold, there are exceptions to it of course but in general I pick the OP reflector when available.
In this lights case the SMO reflector has a slight donut hole (simply due to how large the die is on the LED, not much you can do about it). I am guessing the OP reflector would basically eliminate this which would be nice for everything except max range usage IMHO.
I read in some reviews that the GT94 gets hot very soon. Perhaps the step down set by the factory is to prevent the driver from getting damaged. Buck drivers are delicate. Perhaps it is better to leave the factory settings which has some good reason.
I haven’t seen a donut hole in the videos posted on Youtube. Perhaps it is very light and can only be noticed by projecting the beam onto a white wall at very short distance.
I set the default step-down temperature at 55c in the firmware. Due to variances in the MCU’s this can vary by 15c+ from light to light. So the step-down could happen between 40c and 70c depending on your particular light. This is not a problem since the user can recalibrate the temperature to their liking.
The factory did not change the temperature setting from what I set it to, it is just simply variances in the MCU’s. It is perfectly safe to raise the tempreture or even disable it. The internal components are rated for 105c+, the cells are the only thing you really have to worry about, VTC6’s are rated for 80c but lower quality cells can be rated for less.
In my stress testing with thermal control disabled I saw a max temp or ~95c at the head and the cells were ~75c. So still safe even with thermal control disabled, although it is not recommended to do that on a regular basis.
In a nut shell, you are welcome to re-calibrate the temperature control to whatever temp you want or disable it completely. It is easy to do in the firmware, I simply don’t have it memorized. It should say in the manual how to do it though. If not there is a cheatsheet in the GT70 thread that has it for sure.
Correct, it is the same driver setup as the GT70, a resistor bank for the low modes and FET for the higher modes. The GT4/GT94 driver is just beefed up a fair amount to handle the ~30A it has to deal with.
I doubt a camera would pick it up easily, it is faint but there. I mostly noticed it when getting lux readings, the numbers were higher at the edge of the hotspot then in the center. It is most noticeable at mid ranges.
I am a technical guy though so I focus on things like that more then most. On the flip side I don’t generally care much about cosmetics and that sort of thing.
Cool! Thank you sir. Another question. If and when I get the reflector could I send you the head and you install the new reflector? I would be willing to pay a fee. I don’t have the tools and am not comfortable disassemblying the light. We can take this to pm if you like.
Kind of/sort related/unrelated, TA - were you involved in the HK90 design or driver? I got one coming in a few days. The price of the GT94 is out of my reach for now, so settled on a "Super Shocker", paying homage to the BTU Shocker of a few years back - the HK90 is a triple LED at 100 mm head diameter size, SMO reflector, 3 21700's, 3 SBT90.2's. Neal gave me a pretty good deal.
Nope, not sure who did that one, my guess is Lexel.
That is an interesting light, a larger version of the MT09r basically, I still love my MT09R / MT03’s and are some of my most used lights. I actually want to get another MT03 or similar light as a Christmas gift sometime soon, keep hoping another stimulus check would show up lol.
Yeah, the MT03 is awesome - I got a couple of them. The HK90 tested at 688 kcd, rated at 750 kcd. It's a bit lower than what I'd expect. The lumens tested at 16K, which is fair, so think'n it's not well focused, or reflector issues. I'm think'n it's not down by a lot, though - was hoping for 750-800 kcd from a triple in this size.
Yeah, those numbers are not bad all things considered but could be a bit better possibly.
I think part of the numbers being low is it being a triple vs a quad. There is more wasted reflector space in a triple vs a quad which will effect the numbers. This is part of why I prefer quads as a rule.
I just got my BLF GT94 Texas_Ace Group Buy delivered to me by DHL. The enclosed instruction set document looks like it is nicely detailed in refreshingly clear English. Texas Avenger driver, Narsil user interface. The battery carrier looks like something that is not for the electro-mechanically challenged person. I was able to get the cells and the carrier functioning properly the first time; no fumbling or repeated attempts were necessary. Insert the cells correct polarity, tighten the thingy-dingy screw cap, insert carrier, double click, instant turbo, no fuss, no muss.
The head has a heavy-quality feel, lots of heat sinking. The cooling fins look like they really were designed to be cooling fins, not just a visual afterthought; so there should be plenty of heat sinking and heat dissipation.
I have to wait nine hours for the dawn of the new flashlight day. Then, I will see for myself how much more it throws compared to the X65 and the R90TS. I am visualizing narrower beam than the R90TS and a little bit more wider beam than the X65. Mine came with orange peel reflector, but word on the street is that Neal will be mailing smooth reflectors some time in the future. This will be an opportunity to see for myself the difference in observable throw for smooth versus op reflectors.
I don't post beam shots, because my beam shots are not high enough quality to be of any value to the discerning flashoholic. I don't post pics on this forum, because I am not capable of working around not being able to attach pics on the forum.
This is a Must Have light. I ordered the HK90 first, but the HK90 has not arrived yet, so for me, this is the first multiple emitter 90.2 light.
