Just happened to be buying 2 LT1s for someone else and noticed the orange. Site let me order but quickly got an update from Sofirn that there’s no stock. The person answering messages didn’t know when colored lanterns would again be available.
Yup. Same here. Took them 2 days to message me, but sadly, no more orange.
That looks awsome! :+1:
I was using my lantern in my RV this past weekend and noticed something new that I can’t seem to find any reference to. My switch LED was flashing slowly in an orange color. What does this mean?
You can set the indicator lights to high, low, flashing, or off. Seven clicks to change mode while not locked out, three clicks while locked out.
Ah, okay, I see that now on the instruction sheet. I must have inadvertently changed it to flashing while locking/unlocking (which I do all the time). Thanks!
Hi! Did some search about flashing the lt1 in this thread and few others… Last info about that dated in 2019. Would like to know if someone achieve to flash anduril 2? I already flashed my D4V2 and KR1 with it and now using two different anduril version makes everything complicated for nothing… I’ve read that we need different programming kit than the D4V2 one… Last info found is we need to buy the HQ lexel progkey and build it yourself wich I don’t have the knowledge and equipment for… I’d like to buy a kit ready to use… Anyone have info where I can find that?
The lantern can also be reflashed with a SOIC8 clip… which is much easier to obtain.
Otherwise, yes, it can run Anduril 2. I’m using it on mine.
Sad to hear, hope they can still build the Olive green, FDE, and bare aluminum models still.
I am still holding my breathe for olive green or something close.
I have not been on here for a long time.
Are there any accessory kits available or at least a reflector to block the back facing light?
Can someone help me out? I bought a new one of these, has Rev 5 board. I was going to bridge 6,7 pads but noticed none of my pads were bridged and from looking around it looks like all rev 5 pads are not bridged. Can anyone shed some light? I thought 4 and 5 were always bridged from the factory. Was v5 changed?
4 and 5 are now bridged with 0 ohm resistors rather than being soldered.
So if I want to bridge 6 and 7 I can still do so and it will work the same as it did before?
Yes.
Another question, does anyone know why it recommends not running it on high if only off USB (no batteries connected)?
Whining noise from the charge regulator chip, I believe.
whats the ATL for the LT1?
LT1 arriving soon.
Which Anduril firmware should I update it to?
I have a SOIC8 clip to modify a UT210E…
The LT1 build of Anduril 2?
Most up-to-date build of Anduril 1 is already installed on the LT1?
