I don’t know how good 7-LED optics are, but a “D4SV2” could probably fit 7x E21A, because it is similar size to Fireflies E07 (but Fireflies E07 does not offer E21A as an option).
We would just need a D4SV2-sized 7.5A CC driver and a D4SV2-sized 7x E21A-suitable board for 7-LED optics.
Or maybe we could have a “D4SV2” mule with 32x or even more E21A.
Anyone with D4V2/KR4 Nichia 219C 4000k? I would like to know the tint. I have a Lumintop HL3A and a Convoy T2 with this led and they have a very good neutral tint, however the Lumintop Tool AA with the same led has more yellowish tint which I don’t like so much.
Oooh, 7xE21A D4Sv2 would be a must-buy for me. Off the shelf, LEDiL ANNA would not fit, as it’s like 40mm diameter. The E07 uses a custom proprietary optic.
Hank was great about the issue I had with my light after I contacted him and asked me to return the light with paid shipping and sent a replacement that is fully functional I am glad to say.That took about two weeks.
Although there is still some odd behaviour with this light though....
Sorry for reacting lately to this post (to which ToyKeeper answered in post #1895), but I have just received my very first Anduril flashlight (an Emisar D4v2 with E21A). I found out the same behaviour, but in fact the LEDs do light up again after going off, after 15 seconds (if the light is still cold) to 30 seconds (if the light is very hot).
Moreover, this doesn't only happen when going directly from Turbo to Low, but also when ramping down from a "medium" level to Low, although the delay is much shorter in this case (a couple of seconds).The delay between the LEDs going off and relight seems to be both #1 temperature and #2 initial brightness, dependent. The brighter and/or hotter the light, the longer the delay to "reactivate" the LEDs at low level.
I think Hank is only saying it does not work with aluminum KR4 if you are using the 18350 tube. It is compatible with the 18650 tube.
It is also compatible with KR1 with the 18650 tube.
I like the new clip a lot. I would like to buy a couple of them for my older KR4 flashlights with my next order. Will you sell it separately as a component? https://intl-outdoor.com/components-6.html
I must say that small lip on pocket entry section could be a tad longer. Not huge like on original clip but a little bit more.
Now it reminds me of tiny Lumintop clips which are not bad but this tiny part can tore fabric if you don’t use fingernail to lift the clip a bit.
Or it’s just photo not giving right impression... i hope
I think the perfect “bent end” of any clip i have is on the d4v2, it is perfect size to grab with finger nail if needed to lift over pocket, but also slides into pocket well most times.
