Not to be negative, but what kind of runtimes might we expect with this compact but extremely powerful light at higher levels? Is there a similar sized-light that we might extrapolate from?
Runtime: Two out of three is good. Which two do I want, and therefore, which third, do I have to have?
Single 21700, somewhere around eleven thousand turn on lumens, head size and head mass is the size that it is, so I would like to add this light to my collection to be with my MS03, EC03, FW21pro, NSX53, and TM9K. What do I get from those five lights? Very compact and extremely powerful, but run time is limited by fuel supply per power ratio, and is also limited by compactness of heat sinking/heat dissipation. I love those other five lights, so I know that I will also love this light. Choice of emitters and optics: I like some more power with a little less throw, and I also like some more power with some less throw, too.
It has normal modes for normal runtime.
If I want eleven thousand lumens for more time, then I need a bigger light. Even more time at eleven thousand lumens? Then I need an even bigger light. I can run my MS18 at 11,000 lumens without heat or fuel concerns until the New Jerusalem descends from Heaven to Earth. But I don't. Instead, I run it at 100,000 lumens until I need to charge it and let it cool off.
I have lots of lights that have very steep power/time graphs. I love them all. There are also lots of lights that have one tiny emitter sitting on top of ample fuel supply, replete with very nice power/time graphs. Because they are not very powerful per compactness, I have not purchased any of them, yet.
integratered DTP MCPCB does not save cost, it saves some assembly work though, Replacing main emitters is not complicated, no much difference with regular MCPCB.
New optics is mid-throw-flood, only 30degree available.
I don’t understand why there is little aluminium mass directly underneath that plate of LEDs (think ROT66) and all that heat sinking around an area that will hold little more then a switch.
Not an expert on thermal management but I challenge some of the smart people here to talk me thru how this design is going to manage the heat.
Or maybe that’s not the point in this case and if so apologies for raising this.
How can you tell there is little aluminum mass? The E07 had a very thick aluminum shelf under the mcpcb. It had some of the best heat sinking property for its size. I hope the shelf thickness, which is most important for heat transfer, remains thick like in the E07
The design seems to have further reduced the mass of aluminium that could conduct heat away by adding a ‘heat sink’ groove right where there should be a large body of mass to conduct heat away. It appears to be bottlenecked at the place that most needs material.
Bonkers! Haha
Edit: Just saying I can’t recall a design that undercuts the diameter of the aluminium that houses the mcpcb quite like this.
I wouldnt risk mine, UNLESS you told and show me how the 12 leds will be batter able to hold X amount of heat where it goes through Y’s dissipation. Hehe, my hope that will solve. I’m not sayin they can’t anyway…but what are the possibillity?
