Would the 3V2 indicate that it supports 3.2V and that the WK01 and WK02 may be using the same driver?
@Wurkkos: Thanks for not using red loctite! It’s much easier to play around with the flashlight.
Interested
Update:
New promo codes for Amazon US, see updated OP.
Just in case, should you have problems with the codes:
Sometimes it needs some hours before the actual promotion becomes active. So, please try again a bit later if it's not working already. ;-)
hey Lux, i tried the aliexpress code for the WK01 4000K and it doesn’t recognize it. has it expired?
I will try to get a new discount code for AliExpress. :-)
Thanks.
New codes for WK01 and WK02 on Amazon US, see updated OP.
Bought four FC11 in 4000k and 5000k versions and I am pretty happy with these flashlights.
Now I want to upgrade my EDC kit(s) with 2 or 3 WK01. Is there any chance to get a discount code for amazon.de?
I will check with Wurkkos to get us a new discount code for Amazon DE.
OP is updated with new codes. :-)
Amazing. Thank you!
Edit: Tried to order with the code, but amazon says code is not valid…
Edit 2: Code is now working and price is 11.99 Euro! Thanks a lot!
Can we get it on Amazon Canada?
Ahhh...besten Dank für die Info! Wurkkos sagte 20% Discount, so dass es eigentlich € 12,79 statt € 11,99 sein müssten.
Falls Du Dir die WK02 auch noch kaufen solltest, sag mir mal bitte Bescheid, wie hoch der Endpreis ausfällt. Danke!
I will ask but that's one of those questions only Wurkkos can answer. Would Amazon US be an option for you? I suppose it would add quite some shipping cost, right?
Price for the WK02 is 14,39 Euro
Ahh, found out why. The code works together with the 5% coupon on Amazon. WK02 is 13,49 Euro with the extra 5%.
Thanks a lot! So, I will update the OP again since it is unforeseeable if Amazon will keep available those 5% extra discount.
The Amazon US codes no longer seem to work.
Any chance of a new code for Amazon.co.jp?
Is WK02 going to be restocked on Amazon US?
I also saw it a few days ago on Wurkkos site, for only $10.99 but now it’s back to $14.99.
For those interested, these lights are about to be discontinued and have both been discounted to $8.99 with free shipping on the Wurkkos store.
