【convoy】H4 and B35AM options are updated
Yea I understand what the thread content is, I have not seen the driver hit the store and was looking for something similar recently. Thanks for patronizing response though.
In my experience (and probably most others)- the osram LED’s have a relatively smaller “spill” area then other LEDs used for throwers like the sst40, xhp35 and sbt90… I also feel that the way the picture was taken (looks like from elevation off of the ground), that the spill area on both LEDs are not really apparent and we’re only seeing the hotspots. This new(?) osram CULPM1 should technically have the largest spill/lumen output of all the osram emitters though. I found the release of this flashlight, especially with an 8amp driver, very exciting! I’m not a huge fan of small spill throwers but I will buy this convoy, because I believe the spill area will be sufficient. I know the W2 in my KR1 has sufficient spill so this L21a host should be awesome for this LED / driver!
What is the tint on the L21A CULPM1.TG ??? It looks like a great handheld single cell thrower.
They come in CW only currently, so 5700’ish k to 6500k which is totally fine for throwers.
I mean, should CULPM1 be consider 1 Km light contender? Not below 1 km as such the sst40 I supposed so…this is consider thrower light stage two.
That would mean, the same level as the W’s which now had claimimg 2km.
Most of led that surpass 1km, it seem they ussually had a tight beam, for its reason. Its looks tight at closer but what it really matter is in the long distance. It like buggati Veron for long distance vs gtr for short drag race. You know what i mean?
I think any led could do over 1km with a big enough reflector :stuck_out_tongue:
All of the Osram white flat’s achieve 1km+ , the CULPM1 is the brightest white of them all. Using it in the Convoy L21A at 7A I get 1350 meters but my meter gives a higher number than others so I sell it at 1250m.
If I point it just above a hill on our farm I can see the outline of it and that’s 1300m so it’s at least that much
Sorry buddy, I replied at 3:30am, wasn’t meant to come out that way, I realized as I read it back but too tired to change it
Just ordered L21a with CULPM1 8amp ! Also ordered the m21a with CSLPM1 6a driver! By the way, my first Convoys! Can’t wait!
Convoy L21A CULPM.TG or otherwise known as the W2.1 driven at 7 amps
200 meters to the trees.
I find it curious to see many of you driving these emitters quite hard. Of course this also is because how these drivers are set at, namely the newest ∅22mm 8A switching driver (very smart choice, efficient cool running driver).
Curious because we don't really have any formal CULPM1.TG tests yet, hope they are ready soon. The CSLPM1.TG peaked at 8A, and so I wouldn't expect the CULPM1.TG to peak much above 9A. But we'll see.
Sun, 10/25/2020 - 16:09
Thanks for the beam shot! Makes me even more excited to receive mine seeing it in action!
And no worries about the comment, I get being tired. Definitely no need to go back and fix it :+1:
6.6A is the max in the specs and 8A - 10A pulsed.
I tested it using that ramping driver from Convoy.
- 50E 3.8v 6A = 1200 ish
- 50E for 7A = 1313
  • 40T for 8A = 1318
djozz tested an early chip from hank and he said his peaked at 7A, my testing confirms it. Even at turn on it didn’t go above 1380.
That’s very disappointing that it’s not really any improvement over the cslpm1
djozz tested XP-G3 Photo Red. If SST-20-DR performs similarly to XP-G3 Photo Red (it probably does), it does not seem useful to push the LED beyond 3A.
….yes, but I’m talking about the driver which is only pushing 2.5A
Received my L21A CULPM1… I will say nothing more you can ask for with such price tag.
IMHO, the L21A CULPM1 is probably the best value for money pencil beam thrower thus far. If not, at least for now.
Questions for Simon:
Let's say I would like to get a Convoy L2 smooth replacement reflector. The part is not for sale, which is weird because all other reflectors are (L6, M1, M2, M3, M21C, M26C, and so on). So, how do I order something like this? Custom order? How does it work?
Are you still offering discounts?
Thanks in advance.
I will add the link as soon as possible.
L2 has two kinds, 9mm bottom hole for 5050 and 3535 LED, 11mm bottoom hole for 7070 LED
Orange-yellow Osram just showed up in store :)
If we could get royal blue CSLNM1.14 That would be great. All colors covered
Anybody knows the wavelength of this?
