Haikelite HK90 tear down
53 posts / 0 new
Tom E
Tom E's picture
The HK90 is a rather unique light, triple SBT90.2's in a 100 mm diameter head, with triple 21700's in parallel. I recently got one in from Neal's store in sand color. This is about the closest thing to an old classic, the BTU Shocker, but updated. Of course I couldn't leave it in one piece for long, as I did with the Shocker with modding, so here's some of the details.
Had to give the 40T's a solder blob job for better contact:
Fortunately, they provided a large hole in the driver (on the left) that could be used for leverage to pry out the driver, breaking the glue seal. The glue is a soft silicone type of sealant, so not so hard to break:
These are the tools I used to pop out the driver. The bent end of the pry tool fit in the hole, then I used the plyers as a lever on the pry tool. Just had to add hard plastic on the edge of the head so not to damage it.
The driver is the same design as the HK04 - matches in every detail except the size:
Under the driver is where it gets weird. Normally with a reflector like this, there is one center large screw, but in this light, there is a screwed down aluminum plate:
Removing the plate, found this. Wut? It's a copper plug 1/2 filled with thermal grease, covering the screw head:
After cleaning it out:
So here's the pieces:
After polishing with a fine GRIT pad:
The Shocker reflector, ok, they modded it slightly to remove some weight, which is what I used to do on modding Shockers. They even made cutouts to clear the solder connections (I did that as well). They really still could have done more to reduce the weight, but maybe that would have been even more expense.
One large MCPCB, 20 AWG wires. Another weird thing - guess they ran out of black wire:
View of the shelf - light covering of thermal grease but well spread out (how it should be), and shelf is pretty thick, at least 4 mm:
Large MCPCB and 2.0 mm thick:
The copper plug is 35 mm wide by 9 mm thick. At the center base it's 3.1 mm thick and the outer wall is 5 mm thick:
The weight of some of these components:
The switch LED - these are dual color LED's, red and blue. The red and blue are controlled by the USB charging circuit, while Anduril controls only the blue LED's. This switch PCB is glued down, haven't tried removing it yet - I broke the HK40's switch PCB attempting to do so, so might leave as-is.
Couple of issue as well. The holes have not been deburred on the bottom of the MCPCB and there's a contaminant on the right side shown, might be solder:
Why are these wires so stiff? Turnigy and other wire we source from Hank-IOS or MtnE is much more flexible:
It is 20 AWG:
Here's a look into the driver cavity where the copper plug snugly fits in. It's a tight fit, but as you can see, there's no anodizing on the contact surfaces, they did the right thing here. The machining marks are almost cosmetic - I can't feel them at all. Looks like they polished the surfaces but didn't take it down enough to remove the marks - sanding should get rid of them easily. The aluminum shelf is 4.7 mm thick at it's minimum in the center, and 9.4 mm thick in the outer part. The LED's are probably 80% sitting over the thick 9.4 mm part. Since the thinner center section is supplemented by the copper plug, it's total thickness is about 7.8 mm at the center.
The center screw is an M5 x 16mm.
In the head, all the anodizing is stripped and the inside has ridges, dunno if intentional. Again, machining marks on the shelf but can't feel them, so the must not be significant. Sanding should smooth them out easily. If you notice, the anodized ring isn't exactly round, it has 4 flat spots which match up to the 4 flat spots on the MCPCB - interesting they made the fit tight and locks it in to position so no need for screws to prevent rotating.
Glamour shot of major components all cleaned up, showing relative sizes:
 So I'm not quite sure what the purpose of the thermal grease is. There is no grease at all where the copper plug makes contact to the aluminum housing. Seems like applying a lot less to the outside of the plug instead of the inside would have had more thermal value? With the copper plug, I would think they were trying to keep the driver cooler and pull more heat from the LED's. Copper stores heat better than aluminum which can be a pro and con, but adding copper under the LED shelf is what many of us modders have been doing for years.
Overall, it's all what the Shocker was at the time - outstanding combination of lumens and throw with a big hot spot, and built like a tank, but with improvements:
  • SBT90.2 LED's - expensive but best combo of lumens and throw
  • side e-switch with driver running Anduril (wish it was firmware updateable from the outside though) with dual high performance Infineon FET's
  • 3 21700's, so can run the high performance 30T's and 40T's
  • SS bezel - nice look!
Initial Readings:
 Configured temp calibration by setting the temp to approximate correct, and setting the highest max temperature. It stepped down at the 25 second mark, so took the lumens readings as follows. Using 40T's with solder blobs on top:
  • 15840 lumens at start, ~14400 at 25 secs, might have already started dropping (these are maukka calibrated #'s)
  • 712 kcd taken at 5 meters, after doing the 30 second test on the same cell charge
Edited by: Tom E on 10/26/2020 - 22:53
JaredM
JaredM's picture
Last seen: 7 months 2 weeks ago
I really don’t understand.. there is literally no thermal path between the copper sink and the body?? Am I seeing this right? A triple 90.2 light WITHOUT a shelf?? Like $3 zoomy style? Just a floating copper puck?
https://fundrazr.com/osturaband
No affiliation, just a fan.
Tom E
Tom E's picture
Ooops, no. There's a thick alum shelf, unibody, part of the one piece head. The copper MCPCB is 59.9 mm x 2.0 mm in size, sitting on a shelf, at least 2-3 mm thick (didn't measure). The 35.0 mm x 9.0 mm copper plug sits below the shelf. I'll add a couple more pics.
JaredM
JaredM's picture
Wow. Ok. I was shocked by my initial (mis)understanding. Still a very odd design ‘feature’ with that grease cavity lol. Really don’t know what the thinking is there.
The shelf is anodized, btw?
Tom E
Tom E's picture
Nope, it's bare - post #1 updated with a pic of the shelf. They did some things right, but the burrs on the holes and edges of the MCPCB is not good. Unfortunately I find this on many lights.
Yea, can't figure out what they were doing with the thermal grease. Maybe storing it for future use? smile
JaredM
JaredM's picture
Thanks for the extra pics. Really clears things up.
Not having a good thermal path to the reflector seems like a missed opportunity. A proper thickness washer in the center could potentially help pull away more heat in the first minute of runtime.
How are the + traces routed?
Tom E
Tom E's picture
The traces, + and -, on the MCPCB are a little strange - one wraps of each LED wraps around the LED. On the driver, it's a straight connect of wires to thru holes to the brass ring.
JonnyBorneo
Last seen: 1 year 4 months ago
This light is a pass for me. Thanks for the breakdown.
Not the quality I seek.
Tom E
Tom E's picture
JonnyBorneo wrote:
This light is a pass for me. Thanks for the breakdown. Not the quality I seek.
This is why tear downs are so valuable - you don't really know what you are buying. It's a shame these tear downs seem to be a thing of the past, and they either don't exist or are difficult to find for more popular name brands, but I don't think a NiteCore, Imalent or AceBeam tear down would fair any better.
Overall, even though they have a strange usage of thermal paste, the copper heatsink plug is a good thing to see in there, plus the large thick copper MCPCB is better than 3 separate ones. I also can't find anything wrong with the reflector and AR treated glass.
I think Haikelite is another example where they don't advertise or list all the features the light has:
  • advantages of 6063 aluminum over the standard, cheaper 6061
  • large copper heat sink
  • double high performance FET's
  • switch LED's configurable by Anduril (not even in the included manual)
  • dual tripod mounts
Sirstinky
Last seen: 2 hours 11 min ago
Yikes! This light is almost $300 and has stuff like a hollow heatsink filled with thermal paste? Ugh.
agnelucio
agnelucio's picture
Thanks for the teardown; agreed, they are very valuable, and decreasing in prevalence.
I only ever buy lights to use as hosts, so really appreciate a teardown of an interesting light.
As for this light, well, from those images, there are design and construction elements which seem poor:
  1. Why use a separate chunk of copper if you’ve already machined a shelf?
  2. Why then fill that copper with heaps of thermal paste? Was more copper too expensive? If so, see #1.
  3. Issues you mentioned with the copper chunk and (more worryingly) the MCPCB having proper thermal contact.
  4. That Alu plate serves no obvious purpose other than retaining the (itself useless) thermal goo pile.
  5. With a reflector that large and heavy, either machine it to be lighter, or use it’s thermal mass to delay overheating. If they’re throwing out thermal paste, put some there instead.
Overall, it appears to me that they either didn’t care enough about their design, weren’t capable of improving it, or (most likely) wanted to release a new light with the latest emitters in fashion at the moment, with little care or consideration.
I’m sure that this light would be moddable in interesting ways (as of course you and others did with the BTU), but for $350, over twice the BTU’s price, I’d expect better.
Though, given what I’ve seen and experienced with Haikelite in the past, I’m not at all surprised.
Tom E
Tom E's picture
Just fyi, we are talking about $136 worth of LED's alone in this light, based on Hank's prices and $250-$260 is the average discount price of the HK90. It's unfair to compare the cost to a BTU Shocker.
Copper heatsinks, below the shelf, was and still is a common modding technique - I've done probably dozens of them this way. The use of the paste here is the odd thing, though I still think the copper heatsink helps more than hurts.
We are talking about some major bump up in specs. The HK90 is roughly 8 times the candela of a Shocker and 4-5 times the lumens, mainly because of the $136 in LED cost, combined with a high performance driver. For modding, it's a modder's dream: keep the stock LED's (best available), and keep the driver. Not much to do except usual tweaks like sanding the MCPCB/shelf contact surface, re-grease, maybe bump up the wires to 18 AWG, maybe bypasses on the springs.
JaredM
JaredM's picture
In a likely futile attempt to explain the odd design here, what are the chances that the hk04 driver fits nicely on the copper puck?
Tally-ho
Tally-ho's picture
Last seen: 4 months 4 days ago
Thank you for the teardown, much appreciated.
Even if I wasn’t interested with this flashlight at first, I might have be if the design had been top notch. I doesn’t think that it is bad but the triple SBT90.2’s MCPCB would have benefit to be a bit thicker with a thicker shelf instead of a copper patch inderneath that doesn’t touch the housing.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 30 min ago
Thanks for the tear down mate!
Also cost if you buy a brand name light and tear it down and break it, You will be crying this light is also expensive but at least lights like the haikelite are a bit easier to take apart. Except for the glued in driver sigh.
Tom E
Tom E's picture
Tally-ho wrote:
Thank you for the teardown, much appreciated. Even if I wasn't interested with this flashlight at first, I might have be if the design had been top notch. I doesn't think that it is bad but the triple SBT90.2's MCPCB would have benefit to be a bit thicker with a thicker shelf instead of a copper patch inderneath that doesn't touch the housing.
Oh boy, I'm doing a real bad job if you think it doesn't touch the housing - of course it does! It's screwed down solid to the shelf with a large contact surface, just that there's no thermal grease between those 2 surfaces. If I were modding this light without that stock copper piece, I might have done the same thing in a mod, with added grease of course smile.
Tom E
Tom E's picture
everydaysurvivalgear wrote:
Thanks for the tear down mate! Also cost if you buy a brand name light and tear it down and break it, You will be crying this light is also expensive but at least lights like the haikelite are a bit easier to take apart. Except for the glued in driver sigh.
Thank goodness they added a big hole in the driver to make it easier to remove than a Sofirn SP36...
Goin back in time, drilling a hole in the stock driver is what we used to do, but fortunately Haikelite laid it out so there's no components on each side of the hole, so no damage using a pry tool.
Tom E
Tom E's picture
Something like this could work out well, replacing the stock screw:
The screw is a direct connection between the copper plug and the reflector, and swapping from steel to copper should help. I'm not sure of the screw size, only guessing here, plus it's rather pricey.
Sirstinky
Where do you get copper hex bolts? Parkrose Hardware?
Tom E
Tom E's picture
Pic above has a link to an eBay listing.
Min qty here is 25K (ouch!): https://www.zenithind.com/copper-machine-screws-1730607.html
But at least someone makes them
agnelucio
agnelucio's picture
Tom E wrote:
Just fyi, we are talking about $136 worth of LED’s alone in this light, based on Hank’s prices and $250-$260 is the average discount price of the HK90. It’s unfair to compare the cost to a BTU Shocker.
Copper heatsinks, below the shelf, was and still is a common modding technique – I’ve done probably dozens of them this way. The use of the paste here is the odd thing, though I still think the copper heatsink helps more than hurts.
We are talking about some major bump up in specs. The HK90 is roughly 8 times the candela of a Shocker and 4-5 times the lumens, mainly because of the $136 in LED cost, combined with a high performance driver. For modding, it’s a modder’s dream: keep the stock LED’s (best available), and keep the driver. Not much to do except usual tweaks like sanding the MCPCB/shelf contact surface, re-grease, maybe bump up the wires to 18 AWG, maybe bypasses on the springs.
I didn’t think of discount prices, so that makes it more reasonable. The emitters are all well and good, but the overall quality just seems lacking.
As for the copper block, that’s fine in modded lights – I’ve done similar things in the past before I had a lathe, but in a machined light, I just don’t get it…
Maybe I’m just being too picky. It does look decent for some modding.
I wish more people would do teardowns, but of course they risk causing damage.
The copper machine screw could be soldered/brazed to the copper heat block.
Sirstinky
Holy smokes $15 for 2 bolts. I guess better than buying 25,000 at once.
richbuff
Last seen: 9 months 3 days ago
Tom E wrote:
Just fyi, we are talking about $136 worth of LED's alone in this light, based on Hank's prices and $250-$260 is the average discount price of the HK90. It's unfair to compare the cost to a BTU Shocker. ... ...
 ...We are talking about some major bump up in specs. The HK90 is roughly ..... ... ..
I want  to compare lumen and throw specs  with the X65. Could this humble light possibly be a X65 killer? I also want to see for myself how the HK90 beam profile and beam performance compares with the X65. I just increased my odds of living to see the day when that can actually happen. Not by any expensive high-tech, recent advanced medical intervention, but by  a much less costly means: I simply ordered another HK90. One of them should come in before the other one, later or sooner, I think, while there is still time.
Thanks for your graphic display of its guts.
Rev 22:15
Tom E
Tom E's picture
Easily beats the X65 according to what I measured, in a smaller package. The X65 holds 8 18650's though, and should hold high output/high throw longer. I dunno if the published specs on the X65 is correct: 12,000 lumens, 423 kcd. The HK90 is 15K-16K lumens, up to 18K, and throw is over 700 kcd.
If the X65 has 5 XHP35 HI's, then max lumens is more like 10,000, not 12,000. I see maukka measured it at 10.5, but before his full calibration setup. But he also measured throw at 587 kcd, so well over the rating.
I've just been researching the FET's - they are Infineon, slightly older generation it appears, ~2012 or so. They have a max amp rating of 100 which is good, but still think the SIRA20DP is superior with lower resistance and quicker in other notable specs. The parallel FET's is questionable whether there's an advantage. I thought TA tried it out and either made no difference or made it worse... I should ask him.
Still trying to figure how to mod it before re-assembly.
Note: More updates and pics added to the OP
Tom E
Tom E's picture
Maybe this would work out, little cheaper, maybe the 15 mm will work or cut down the 20 mm, probably easier to work with that head (link in the pic)
richbuff
 "Easily beats the X65 according to what I measured, in a smaller package." This is very exciting news. I am a huge fan of the X65, and I have been waiting four years for its successor. Thank you for your teardown, and for your observations!
Rev 22:15
Tally-ho
Tally-ho's picture
Tom E wrote:
Oh boy, I’m doing a real bad job if you think it doesn’t touch the housing – of course it does! It’s screwed down solid to the shelf with a large contact surface,
Oh no, not at all. When I said housing, I was thinking the wall of the housing because your picture clearly shown that it was screwed under the shelf.
Tom E
Tom E's picture
Ahh, ok. I added couple of pics showing where the copper plug sits in, and posted measurements of the shelf and copper plug - think this will help.
Tom E
Tom E's picture
Started on modding, might take me a while. Here's a closer look at the tracing on the MCPCB. Not sure if you can make them out in the first pic, so I traced them in the 2nd pic. Seems weird to have those loops, but I suppose the traces are wide enough not to lose much:
I replaced the 1K at R8 with a 500 ohm resistor to make the button LED's brighter. Swapped out the Infineons with a single known good SIRA20DP:
In inspecting the clearance for 18 AWG wires, noticed the cutouts in the reflector for the solder joints fell short slightly. Just did hand filing to sand off the sharp corners, as the corners were just too close to the large 18 AWG wire solder pads:
Not shown, but I sanded down the backside of the MCPCB. There was slight burr edges around the center hole and outer edges. From flat surface sanding, notice the MCPCB was not flat, bumped up in the center. I used this Snap-On 1/4" pin punch shown below, giving it a couple taps to flatten it out, worked great, I've used it before on MCPCB's, also works great to flatten out 0.1 mm copper sheet metal used for hand made tracing:
I did end up ordering the copper M5 x 15 mm screws linked in post #25. They will take a while to get here, but one can be easily swapped in later.
eBay link in pic:
To be continued...
JaredM
JaredM's picture
TomE, what do you think about the idea of cutting a disc/ washer out of a layer(s) of Al or Cu foil/sheet the same thickness as the led centering rings, and putting that between the mcpcb and the reflector? Maybe a little kapton over the + trace for extra caution.
Tom E
Tom E's picture
Possible. The copper screw will help somewhat, dunno how much really though. I got a set of copper washers - I should take some measurements. Also got 0.1 mm copper foil/sheet material.
Yea, might use the kapton tape while I got it all open. The idea of blowing $135 in LED's by one little mistake is scary - I'm take'n chances with this one.
Looking at it, if the washer is wide, it would overlap the traces, and they are raised. Probably want to avoid the traces.
