1A tint is cool white , 3A is neutral and 7A warm white.Best choice would be 1A not for the tint , but the latest led bin (V2).
It’s a huge upgrade from the light you have now.
Where are you from ? Because some members here mod C8’s for better throw (new driver and spring byppass etc)
Some newish Orsam chips with jumbelly alphabet names colloquially known as W1, W2 and more recently ‘W2.1 and W2.2 (CULPM1.TG)’.
Finding their way into single 18350 (Manker MC13), 18650(Acebeam L17, Noctigon KR1), 26350(Acebeam E10) and 21700(Convoy L21A, Noctigon K1, Acebeam L18) hosts.
Some hosts use smooth reflectors, while others like the MC13, L17, L18 and E10 use ‘Total Internal Reflection’ or TIR which basically re-routes all the spill and probably most of the corona back into a more intense hotspot.
Come in different colours, White, Green, Red, Blue and Yellow. With Green being notably brightest.
Hoping someone with more dollars and sense than me can make heads and tails and come up with a winner but that appears to be where the compact thrower game is at.
I think it will throw noticeably better. A WF1 would throw a bit further but the hotspot is so small it might be annoying.
I do not have one to compare but I have a Convoy S2+ with SST-40 driver and cslpm1.f1 (W2 Green) and its a monster for only a small reflector. I would imagine the larger C8 reflector would make even better use of the W2 format.
I have WF2 in the KR1 host with a much smaller reflector and it just outperforms a C8 XPL-HI, so by the same token WF2 + larger C8 reflector should be even better. (Or consider L21A for even better again! a bit larger light and 21700).
That looks like the ‘W1 white’ or ‘WF1’ emitter. It will be the best throw distance for $ in a C8 (edit: unless you go green!). The hotspot will be a bit tighter than the XPL-HI, but it will throw noticeably further. Like maybe 120 meters more, which is significant but not mind blowing. Still pretty good for the $! You will waste a lot more chasing the ultimate osram unicorn… trust me
thats actually a very good breakdown, i been so confused about all these different options.
so osram is the best thrower emitter right now? how much better is a, say w1 or 2.1, compared to sst40? i have a ft03, i ordered xhp50.2 by mistake, planning to order sst40, but thats a different story
SST-40 is a bit of a bigger hotter running LED, so you probably want a bigger host to help with heat. I think the Osram will still out throw the SST-40 but the SST-40 will have a bigger beam all round. Same can be said for the larger XHP and SBT90 chips. Bigger, angrier, hotter, more lumens, but not necessarily more candela/throw (unless you drive them hard with a very large reflector).
