some more photos:
Also I designed E27 model with this body 20cm:
some more photos:
Maukka thanks for review again!
And thanks from Seoul Semiconductor Co Ltd and thanks to them and for Georgy Korolev for free samples of smd 3030 SunLike TRI-R (3-R) STW9C2SB-S LEDs
This is great news! Excellent lamp and review.
I agree!
And the main thing for you and me is eazy delivery, because Mordor is next to us.
Hahahahahaha
You are right. I am about to finalize order. Had a lot of discussion with my wife and organizing apartment project.
Hopefully next week I'll pull the trigger on few items.
Maximum power of this type of lamps what I do is 54w, but now I have another type of aluminium profile
Protected lamp’s bodies
30cm long (can be any) ~ 2.2kg fo 90w (real) in passive cooling (160-180w with quiet fans)
I am going to produce grow led lamps with color leds and with SunLike leds (88w)
With SunLike ot will be healthy powerful lamps for big rooms (industry), foto/video light, for plants
Герметичные корпуса для ламп. Длина 30см (можно любую) ~2.2кг для 90вт в пассиве (160-180вт если добавить вентиляторы на малых оборотах). Планирую делать с этими корпусами лампы для растений на цветных светодиодах и на солнечных (88вт). На солнечных будут лампы с большой яркостью для глаз в большие помещения, для фото/видео освещения, для растений
id30209: DesertSnake:This is great news! Excellent lamp and review.
I agree!
Because of Cow Id 19, MORDOR is everywhere :smiling_imp:
Some joke:
That is bonkers, I love it! :heart_eyes:
Full review eta when
SunLike:Maximum power of this type of lamps what I do is 54w, but now I have another type of aluminium profile
You mean you want to review this thing when it will be ready? With SunLike or RedBlueWhite LEDs?
I’m gonna need a bigger sphere…no, house.
There’s 3m diameter =) but some kind of expensive… You’ll have to take out a mortgage
Isn’t it just a big white sphere with a hole in it? Couldn’t be too hard to DIY, right?
[quote=SunLike]
What aluminium profile you used for this lamp?
Can you provide link on Ali / Ebay or other ?
Very nice lamp, I like it There is only one thing that puzzles and worries me. You designed a lamp (IP67 rated I see) with a metal housing that additionally works close to water, and you provide a cheapest AC power cord without earth-grounding? After all, this is a basic safety rule . And please do not write to me that the power supply is well insulated because you are not able to predict all the events that may happen.
Very nice lamp, I like it There is only one thing that puzzles and worries me. You designed a lamp (IP67 rated I see) with a metal housing that additionally works close to water, and you provide a cheapest AC power cord without earth-grounding? After all, this is a basic safety rule :person_facepalming: . And please do not write to me that the power supply is well insulated because you are not able to predict all the events that may happen.
yes, without ground wire. If you really need it, just said about it in your order.
Just use 10mA RCD (residual current device, УЗО)
The grounded power cord should be a standard component of this lamp. Not on the principle that if someone asks, will get it. A great way out, advise the customer that should modify the home electrical system by adding RDC… Not every customer has to be an electrician and know how to do this. You pay great attention to the quality of the lamps (components used, modifications, cooling) and you neglect the basic safety rules .
The grounded power cord should be a standard component of this lamp. Not on the principle that if someone asks, will get it. A great way out, advise the customer that should modify the home electrical system by adding RDC… Not every customer has to be an electrician and know how to do this. You pay great attention to the quality of the lamps (components used, modifications, cooling) and you neglect the basic safety rules :person_facepalming: .
RDC it is the main component of any home electrical system. In USA it is 5mA. Ordinary it is 30mA. In Belarus or Russia or Ukraine they do not need ground wire, because they do not have ground contact (or just ground contact in socket without wire) in most situations.
So, stop your tantrum!
OK, I see You know better and know everyones home electrical systems ingredients all over the world. For me EOT.
