As I understood, Sofirn will not pot this batch, they claim that the C01 is robust enough without potting. I tend to agree (did a convincing abuse test on an unpotted C01) but must admit I’m not part of the “potting crowd”.
The lack of potting does enable easy led swapping, so you loose some, you win some.
I see the most likely point of failure of the C01 not in parts coming loose in the driver by heavy impacts, but in the poorly executed contact area on the outside of the driver, that electrically connects the battery tube with the driver : the tracing is too thin and it does not extend to the very edge, so it will wear away over time in heavy use.
Potting is getting more relevant the larger a light gets, large components, expecially big inductors can break off on impact. The C01 has tiny components soldered flat on the driver board, the inductor is even for this size light very tiny, the only large component is the led, but that is soldered through-hole, so that is as robust as it gets. I do not see things breaking even in an extreme impact event.
@Sofirn, will the C01 be available somwhere I can pay with PayPal? Can’t buy from AE since I have no credit card and AE has no IBAN for direct bank transfer.
AE does not have them either, that is a Sofirn store on AE… there is also a Sofirn store on Amazon, in addition to the sofirnlight.com site.
the lights have been announced prematurely, causing you, and many others, to ask where they can buy the light. Those three sources are the ones Im aware of. afaict, they are all just Sofirn outlets, with no stock ready to ship, yet.
the price on the sofirnlight site is lower, I suspect because they dont have to pay comission fees to ali and amazon, if you buy from the sofirnlight site
I hope someone will offere a modding service for this light, since Sofirn isn’t going to offer hosts. I’d put money up in advance to enable someone to set up for doing that.
I”d love to have an amber one.
And eventually a variety of colors like I used to be able to get in Arc AAAs — UV, blue, aqua, green, amber, orange-red, and red.
Just got a bit old and shaky to work on such tiny hardware myself.
LEDSales increased shipping costs, so I didn’t stock the white Yujis. Also, I find desoldering a bit too dangerous to mod others lights. Only if I could get C01’s at the price given on sofirnlight.com, I’ll buy some more of them.
I don’t know how closely you’ve followed this thread, but Barry has dropped in a few times and is aware of our interest in other color temperatures (2300K, possibly 5700K) of the Sophia LED’s, as well as a host version with no LED.
However, he later reported that in order to keep the costs low, they are going to just do one big production run with only the 3400K (although apparently after seeing the success of the C01R, they also decided to make a red C01).
If you think it is worth asking again, there was interest in probably close to 200 hosts indicated in this thread (135 on the list, plus 2 more pages not updated on the list):
I’ve been looking for a 2700k AAA light, and this looks to be about as close as I’m gonna get. Question though - what was the rationale for putting the 3400k emitter in the C01 with only one mode, vs using the C01S as the host with 2 modes, or the C01R driver with 3 modes? I thought the C01 was discontinued and replaced by the C01S - it seems like a step backwards to take the one mode C01 out of retirement to put a great emitter in it, when they had multi-mode hosts available that seem much more desirable? Am I missing some pro of the C01 compared to the newer host options?
Edit - after looking at the link posted above me, is it just that the physical size of the 5mm emitter will only fit in the older C01? If that’s the case, I feel like there are a bevvy of good 2000k to 3500k emitters that would fit in the multi-mode AAA sofirn models… I guess I don’t see the appeal / benefit of trying to use a larger 5mm emitter if it means giving up multiple modes, when there are other emitter options of a similar CCT and quality that would allow more features. What am I missing? I’ll still probably buy one, just would love a 2000k-3000k AAA aluminum light with moonlight, low, high modes, and small/light enough for keychain carry.
The C01 was brought back due to its popularity. The first time around it sold out relatively quickly, and there has still been desire for more. The 5mm emitters chosen both times give off very nice light and will only fit the C01 host due to its shape/design. The C01 could have been designed with multiple modes, but 1 was chosen for simplicity’s sake. Simpler electronics, no modes to fuss with. To many it’s actually a plus. The C01S already meets the purposes of a multi-mode C01, and stepping away from 5mm emitters makes more sense for this UI anyway. Simple, single-mode 5mm lights are kind of non-existent elsewhere (arguably because it’s a dated design, but the demand/desire proves its relevance), so this light fills that void.
I agree what pioneer24 is asking, because it is more convenient have 2 modes moon high with reverse UI on durable host.
I hope there will be next batch C01 like this, because apart plastic Nitecore tube there are none 5mm Led multi modes
It is not an either/or situation it is an
and/both situation
there are single mode high CRI 5mm C01 (very few single 5mm lights use High CRI LEDs). One that does is the very expensive McGizmo Sapphire. Hence my request for Titanium and Copper models.
there are two mode power LED C01S
and there are three mode power LED C01R
I expect we will see the three mode lights offered with High CRI white power LEDs in the future.
by power LED, I mean, smd, not 5mm
so, all the choices are possible.
lastly, if a light does not have an LED you want, it is possible to learn how to change the LED to something you like better.
The thread we are in is only about the 5mm single mode version, but there are other threads for the power LED models.
