Is it hi cri?
This can be the reason:
It’s from the instruction for the biscotti (12-modes) driver.
Is it hi cri?
I personally feel like it is hi CRI but I’m not sure. I have 4 lights and 3 of them use LH351D and the other uses SST20 4000k, which is advertised as 95 CRI. I feel like the tint of this light is a bit warmer (more pleasant to my eyes) than other LH351D-adopted lights.
As for the accidental mode changing, I think what you suspect might be the case. I’ve tried to click the button more carefully and it hasn’t happened ever since.
Just did a real runtime test on 0.3% mode. It’s something that is hard to extrapolate from current measurements because the current is so low. And it’s annoying to test with a 5Ah cell because of the run duration. Anyway, it started its low battery flash this afternoon and it’s been running since the 22nd.
Runtime: 3 weeks, 4 days
LED: 2700k
Cell: Samsung 50e - I see between 4850 and 4950 mAh from these with low loads.
I have no complaints considering how practical three moonlight level high-cri emitters are. This really is a no-frills workhorse light.
where did you find a 12 mode? all i’ve seen is 4 mode only.
i was contemplating fixing my S2+ (SST20 4K) broken driver, and getting a lens to make it more floody for up close work.
i’m now considering putting the cash toward an S12. i’m liking the capacity of the 21700. if clear anodized with QLITE driver was an option, i’d nab one.
what is the driver size on these BTW?
cheers :disguised_face:
[edit] great review BTW!
Convoy Flashlight Store on Aliexpress has the 12 Mode models.
ah, found it. thanks :+1:
If you’re ok with the S12 size, definitely go for it. For flood beam, Nichia option should suit you, or you can get LH351D option for high CRI and neutral tint, it gives nearly 2000lm as well.
Compare those 3:
Compare those 3:
thanks, appreciate the advice and the image. looking at the size, i’m considering a sofirn IF25A. it’s shorter than my S2+
cheers
Thank you for the review. I like your to the point style.
After learning about Emisar doing mixed emitters, I asked the Convoy store if I could buy an S12 with mixed emitters as I noticed they had LH351D versions in 2700k, 3500k and 4000k. The reply was “uh ,no”. Custom emitters must be exclusively an Emisar thing.
I did swapped last week 219C with 351D 5000K and i gotta say that i got pronounced circled hotspot.
Tiny as hell and almost the same intensity spill where used to be three petels from three reflectors.
Wasn’t impressed so i swapped back 219C.
Can’t tell if it’s just my crapy swap or smaller dome emitters are better in these tiny redlectors…
Curiois what others will say ••••••• :~}
Was this with dome on or sliced?
I don’t know about mixed emitters, but I’m pretty sure you can get S12 with 2700K or 3500K if you ask - I got mine with XPL-HI (great choice btw)
No need to ask as those options have their own listing
Thank you very much for this fantastic in depth review
Thanks for the review and beam shots.
Nice review. If I might make a suggestion, I would suggest an update, letting people know that they don’t come with a spring bypass anymore.
To add to my previous comment, the o-ring from the bezel ring is absent on mine, as well as the screws that should hold/apply pressure on the LED copper plate.
SST20 4000K or LH351D 4000K? I have a few lights with LH351D and I’m more than a pleased with the quality of the CRI, but want to try something different like SST20. Pros and cons of both LEDs in this particular model?
SST20 has higher CRI and R9 (deep red), but can be very green. Nowadays 519A is the way to go, it has higher output than SST20, slightly higher CRI, and way better tint.
Simon doesn’t have S12 with 519A, only with SST20, LH351D and 219C…
