Dear friends, good morning from Italy! I would like to add a mode that I don’t see written in this review. The mode is this: by making 7 clicks from off it is possible to activate or deactivate the LEDs on the power button; even with the flashlight off, therefore, there will be no LEDs on if deactivated with the 7 clicks from off. This seems convenient, if we do not want to consume that minimum current of the LEDs always on.
Normally, 7 clicks from Off configures the Aux-LED (for Anduril flashlights that have configurable aux-LED).
For some Anduril flashlights, this setting is connected to the side button switch (eg. the SP36, EC01, EC03, Q8 , SC31 Pro side button also lights up the same way).
7 clicks will cycle from Off -> Low (default) -> High -> Blinking (breathing) -> Off.
High uses a somewhat higher amount of power. Blinking uses less power, and the default Low actually uses very little power, just slightly higher than Off.
Just an FYI.
The Olight Traffic Wand/Diffuser works on the IF25A. The Olight diffuser mounts to the IF25A more securely than it does to the Seeker2/Pro and Warrior X.
Only caveat is, the light option must be selected first, since the button is not accessible once attached to the diffuser.
They can be found here, since Olight no longer sells them. Battery Junction/Seeker2/Pro Diffuser/Traffic Wand
The Olight diffuser/traffic wand is made of very hard, and strong, unbreakable plastic.
I have this light (IF25A). I brought it from the Sofirn store. I was disappointed it didn’t have the same version of Anduril as the BLF SP36 that I also brought from Sofirn at the same time. The version on the IF25A is older and didn’t have the useful feature where hold from off for moonlight delays going on until the hold is valid.
Sofirn’s other brand, Wurkkos, recently released a HD20 headlamp that can also function as usb-c battery to charge your phone. It’s odd they did that for a headlamp, but their handheld line of lights do not have the charge feature.
I’d get another IF25A if they add USB battery feature on the next edition.
could you elaborate on ‘until the hold is valid’? i love being able to hold on the LT1 to get the lowest setting from off.
my guess for the the USB power bank thing is that they have older stock of the earlier firmware/hardware resistors etc.
my LT1 has newer firmware with SOS, but i think it lacks the resistors for power bank.
i’m tempted to get this light, but if a version with newer firmware that includes SOS is going to be available i just may wait.
Sorry, what I said was kinda vague and the feature change in Anduril itself is very nuanced. The current IF25A’s firmware has the older Anduril where you get shortcut to moonlight if you hold from off, but the moment you click, the light comes on in moonlight, and when you release after the required delay, it stays in moonlight. If you release too soon (so that the IF25A doesn’t see it as a hold), it goes to the last used setting even if you intended it to be hold. There’s a very slight feedback by blinking the LED to tell you that you’ve held it long enough. If you overhold, the light start ramping up.
Contrast that to the latest Anduril (like the on BLF SP36). You hold from off to get to moonlight, just like the previous version. But the moment you click down, the light stays off until the hold time is met. That means you get a slight delay after clicking down when you start the hold, but the light turning on in moonlight is your cue that you’ve held down long enough and you should let go before you overhold and the light starts ramping.
It’s such a minor change, but the delay really helps you avoid holding too long (and start ramping up) or holding too short (ending in previous brightness mode). ToyKeeper does a great job making these effective UI features.
Thanks for the review!
I recently got mine and can’t unscrew the front bezel to gain access to the TIR optics. It feels like it’s glued, I put so much effort but didn’t achieve a thing.
Hmm, it might be snug but I didn’t find my IF25 to have a glued bezel.
Are you using just your hands? Have you tried something like one of those rubber jar openers, or a strap wrench maybe?
The SP33 V3 has a tighter beam, I just ran both for 3 minutes on 100% on my kitchen wall. The IF25a is approx 30% wider, while the SP33 seemed to be slightly brighter. That said, the SP33 is also significantly more blue (purple actually). Funny as they are both claimed to be 6500k lights. Heat wise, they both got about the same temperature with the SP33 keeping its output up over the IF25a which started throttling down a touch due to its thermal management.
On a side note, I also ran my SC31 Pro next to these lights too. It had the most narrow beam of the three, produced about the same color as the IF25a, and heated up as fast as the IF25a. All are claimed to be 6500k lights, but the SP33 looks closer to that with the others showing a whiter beam I’d guess somewhere around 6k.
So the classic trade off of mass Vs. output applies. As I recall, the SP33 and IF25a had about the same throw when on turbo when I compared them last summer, but the SP33 can stay brighter (and cooler in the hand).
I recall comparing my 5k IF25a to my 6.5k IF25a when I got them back in June. The 5k really suffered in throw compared to the 6.5k version. When on turbo, the 5k threw ok, but at 70% (where temperature was low enough to keep sustained for more than a minute in the bare hand), it just didn’t get out there like the 6.5k did at the same exact set ramp limit.
I’d take any of these on a dog walk, but it’s all about sustainable output at “x” range. If I were in thicker woods, looking for a shot deer I’d take the 5k IF25a. If out in the field, the SP33 or IF25a 6.5k depending on how much turbo I’d need. But front pocket EDC, the SC31 Pro all the way. My wife uses the SC31 pro, clips it to the dog leash, and runs it full ramp (where I have it limited at about 70% also) so she doesn’t overheat and she goes about two miles a day with Queso (our border collie) on leash. I typically recharge her daily but she’s done several days without battery issues at times. I run a higher capacity (MJ1) in the SC31 Pro as she doesn’t need turbo and can go a few days between charges/walks with the dog.
One more to toss out there, the SD01. Take a Q8, make it in the shape of an insulated coffee-mug, and put a magring on it, and that’s a SD01.
You hold it by the handle, and let gravity do its thing. No need to grip the whole light like a Q8 or other sody-pop-can light.
Lowest is 350lm, bright enough for looking out for rocks, branches, holes, etc., but it cranks up to 6000lm if you want to see what’s down the path wanting to kill you.
And yeah, it’s a diving light, so no worries about getting soaked in the rain, etc.
I’ve been having fun with mine, and even a paltry 350lm on lowest is plenty bright for most things.
Darn, that sounds frustrating. Hopefully they haven’t started gluing the bezel.
A hair dryer can help weaken glue if there is any, though my experience with glued heads has always been a bit palm-blistering.
Again, thanks for your helpful comparisons. Sounds like the 33 would have to be a 5000K emitter for me to like it. I don’t think they are in stock right now. I dedomed my 33 v2 and the color dropped slightly so that my be an option. Aside from that, the I25A 6500K sounds good. And the Sp31 pro too. 3 more lights. Thanks Sofirn. :rage:
just got my IF25A. the type C connector is a bit low and off to one side from the opening, however it plugs in and charges without issue.
put the light in front of a fan to let it acclimate to the room temperature. it’s 23°C in my room. checking the temperature calibration i got 2, then 3 blinks.
spot on out of the box. well done Sofirn.
the beam has a nice width of flood. holding it above my head aiming down makes it even broader for searching on the ground.
haven’t done any wandering at night yet, but from what i can tell so far it’s a perfect balance EDC for my use.
if i feel i’ll need more range (spotting (not hunting) deer etc), i’ll grab my Convoy C8+ XPL-HI.
love the interface. long push for moonlight, push again for smooth ramp. very familiar to my LT1.
color rendering (4000K) is wonderful as i hoped.
-would like the fins to be finished nicer. they are de-burred, but have sharpish edges.
for the $ though the light is an incredible value.
oh, and i paired it with a Vapcell G50 (Sammy 50G re-wrap) 4900mAh 9.8A as i don’t use turbo.
i’m thrilled with this light. my S2+ is going to become my dedicated bike light. which needs a new driver, and a wide lens.
Now… pocket a glove for use if using on turbo for more than a few minutes
I also prefer the 50G to the higher current batteries I tried. The high current batteries just got hot REAL fast, while not really doing much for the throw (when I tested both my 5k and 6.5k IF25a’s). I barely (by a hair) could see higher output on them, but figured “hey, if I can’t hold the light after 45 seconds… what’s the point?”
