Update: (2021/01/06)
Fireflies NOV-MU is available in stock.
Product link:
Firefllies NOV-MU
• 21* Nichia E21A mule; with RGB Aux Leds
• Max output 5500-lumen
• Battery type 1×21700 / 18650 (65mm to 76mm)
• Built-in USB Type-C 2A fast charging
• High efficiency digital current regulated Buck driver , 6A CC
+ FET; Efficiency > 93%
• Made of 6063-T6 aluminum Alloy, Type III hard anodizing
• Heavy duty built-in Magnet in tail
• Ultra Clear AR Coating Glass lens
• Size: 4.48’‘ x1.26’‘ x 1.06’‘ /
114*32*27mm
• NetWeight: 108 gram
• UI – open-source Anduril firmware
Application: High CRI Photographic supplementary light ; Indoor light ; Portable reading light
Light diffuser
Short body will be produced later
Note : The photos from Prototypes do not represent the final mass-production products!-”+
Official store:
New fireflies flashlights to come
NOV-MU Nichia E21A
https://budgetlightforum.com/node/75049
E12R
https://budgetlightforum.com/node/74907
Reserved
Official store:
www.ff-light.com
NOV-MU Nichia E21A
E12R
T9R
https://budgetlightforum.com/node/74550
T1R
https://budgetlightforum.com/node/74939
Now this looks interesting…
What color temperatures will be offered?
Lithium Ion Battery Safety 101
Old Lumens Competition 2020 Modified Light Entry
Man I never knew E21As were that tiny.
I’d offer a frosted lens as an option (or default), E21As have terrible tint shift, even if it’s a smooth transition with a mule it’s still quite noticeable, and potentially problematic for photography.
I would definitely be very interested in this! In addition to the question above, would you also offer tint mixing?
Also with this being a mule, do you have plans to release an E21A thrower of some sort? There aren’t a lot of E21A throwers on the market yet.
Good design Fireflies, from info so far, I’d buy.
ETA?
Finally something really interesting. In.
[WTS] HID host: http://budgetlightforum.com/node/68693
[WTB] Interesting LEDs:http://budgetlightforum.com/node/68968
Nice. Definitely interested.
Interested !
4500K — Mass production.
We have some samples in small quantity available, 2700K / 3000K / 4500k / 5700k
Official store:
www.ff-light.com
NOV-MU Nichia E21A
E12R
T9R
T1R
should be available next week
Official store:
www.ff-light.com
NOV-MU Nichia E21A
E12R
T9R
T1R
Yes, E21A thrower has been in progress already, final sample should come out next month
Official store:
www.ff-light.com
NOV-MU Nichia E21A
E12R
T9R
T1R
Nice to see more manufacturers using E21A. I will pass on this one because I don’t have use for mule, brightness decreases too quickly within a few meters without a reflector.
Jack stepping it up! Great to see this!
Interested
Lovely to see this,I am enthused.
Is Fireflies custom programming Anduril for each of these lights?
Sign me up for 2000k!
Interested!
But probably for a lower CCT than 4500k. Depending on price I would think about buying a 4500k, too.
I would be really interested in a 2000K version. Will there be any chance for a custom order?
I definitely need one.
@1theDeals
Thank you for your prompt reply.
I would be more interested in 3000k for indoor/ tent use but if lm is as stated, 4500k could be good for outside use.
I have a D4v2 and KR4 16x E21A mule and see absolutely no tint shift. The only issue with those mules is the positioning of the emitter around the outer perimeter causes a whopping 20% output loss and narrows the beam. The positioning of the emitters at the center in the FF mule will resolve this huge issue. Also FF made the right decision to use white mcpcb unlike the KR4 mule with the red MCPCB. White is the most reflective and the color DOES make a difference in measured output.
With 21 emitter and the optimal configuration mentioned above, this should make a good amount more than the specified 5,000 lumens at startup, especially considering this uses 21700 instead of the 18650 in the 16x E21A mules.
If this can charge and be used at the same time, then it would make for the perfect table lamp. The E21A 9080’s light quality is better than any light bulb I’ve tested and I tested ALOT!!
I saw your post about the light loss previously and indeed here this is a much better design, but maybe that’s the reason you didn’t notice the tint shift ? since it’s cutting most the greener light.
For lightbulbs the best I’ve seen are Sunlike SOL basically perfect.
For me, I like duv a little below the BBL. It just feels so much more relaxed and welcoming. I’ve tested many lights with near perfect color rendering but lack the slightly rosy tint I like to see before bedtime.
I am interested if warm white E21A is available. 2000K preferred.
Ah yes, me too, and apparently most humans , Sunlike SOL are perfect compared to the reference black body.
interested in 2000K
Interested in 2000 K & 4500 K!
