Fireflies NOV-MU 21*Nichia E21A mule 1x21700 Flashlight --in stock
284 posts / 0 new
FireFlies
Last seen: 2 weeks 6 days ago
Update: (2021/01/06)
Fireflies NOV-MU is available in stock.
Product link:
Firefllies NOV-MU
OP from 2020/11/01 “-+Features:
• 21* Nichia E21A mule; with RGB Aux Leds
• Max output 5500-lumen
• Battery type 1×21700 / 18650 (65mm to 76mm)
• Built-in USB Type-C 2A fast charging
• High efficiency digital current regulated Buck driver , 6A CC
+ FET; Efficiency > 93%
• Made of 6063-T6 aluminum Alloy, Type III hard anodizing
• Heavy duty built-in Magnet in tail
• Ultra Clear AR Coating Glass lens
• Size: 4.48’‘ x1.26’‘ x 1.06’‘ /
114*32*27mm
• NetWeight: 108 gram
• UI – open-source Anduril firmware
Application: High CRI Photographic supplementary light ; Indoor light ; Portable reading light
Light diffuser
Short body will be produced later
Note : The photos from Prototypes do not represent the final mass-production products!-”+
Edited by: FireFlies on 01/05/2021 - 13:48
FireFlies
Reserved
ReManG
Last seen: 2 days 8 hours ago
Now this looks interesting…
What color temperatures will be offered?
twisted raven
Last seen: 7 hours 13 min ago
Man I never knew E21As were that tiny.
thefreeman
thefreeman's picture
Last seen: 3 min 59 sec ago
I’d offer a frosted lens as an option (or default), E21As have terrible tint shift, even if it’s a smooth transition with a mule it’s still quite noticeable, and potentially problematic for photography.
rprilenski
Last seen: 1 month 1 week ago
I would definitely be very interested in this! In addition to the question above, would you also offer tint mixing?
Also with this being a mule, do you have plans to release an E21A thrower of some sort? There aren’t a lot of E21A throwers on the market yet.
0oklight
0oklight's picture
Good design Fireflies, from info so far, I’d buy.
ETA?
1stein
1stein's picture
Last seen: 2 weeks 5 days ago
Finally something really interesting. In.
Rayoui
Rayoui's picture
Last seen: 8 hours 42 min ago
Nice. Definitely interested.
Yokiamy
Yokiamy's picture
Last seen: 1 hour 37 min ago
Interested !
FireFlies
4500K — Mass production.
We have some samples in small quantity available, 2700K / 3000K / 4500k / 5700k
FireFlies
ETA?
should be available next week
FireFlies
Yes, E21A thrower has been in progress already, final sample should come out next month
Tally-ho
Tally-ho's picture
Last seen: 5 hours 53 min ago
Nice to see more manufacturers using E21A. I will pass on this one because I don’t have use for mule, brightness decreases too quickly within a few meters without a reflector.
Tubercle
Last seen: 4 hours 35 min ago
Jack stepping it up! Great to see this!
hank
hank's picture
Last seen: 4 days 8 hours ago
Interested
scintillator
Last seen: 10 hours 15 min ago
Lovely to see this,I am enthused.
jp9mm
Last seen: 7 hours 27 min ago
FireFlies wrote:
ETA?
Is Fireflies custom programming Anduril for each of these lights?
Pip
Last seen: 52 min 36 sec ago
Sign me up for 2000k!
Mureo
Blahblahblahhuh
Interested!
But probably for a lower CCT than 4500k. Depending on price I would think about buying a 4500k, too.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 49 min ago
FireFlies wrote:
ReManG wrote:
Now this looks interesting... What color temperatures will be offered?
4500K -- Mass production. We have some samples in small quantity available, 2000K / 3000K / 4500k / 5700k
I would be really interested in a 2000K version. Will there be any chance for a custom order? Wink
freeme
freeme's picture
Last seen: 1 hour 13 min ago
I definitely need one. cool
0oklight
0oklight's picture
Thank you for your prompt reply.
I would be more interested in 3000k for indoor/ tent use but if lm is as stated, 4500k could be good for outside use.
SKV89
Last seen: 15 hours 5 min ago
I have a D4v2 and KR4 16x E21A mule and see absolutely no tint shift. The only issue with those mules is the positioning of the emitter around the outer perimeter causes a whopping 20% output loss and narrows the beam. The positioning of the emitters at the center in the FF mule will resolve this huge issue. Also FF made the right decision to use white mcpcb unlike the KR4 mule with the red MCPCB. White is the most reflective and the color DOES make a difference in measured output.
With 21 emitter and the optimal configuration mentioned above, this should make a good amount more than the specified 5,000 lumens at startup, especially considering this uses 21700 instead of the 18650 in the 16x E21A mules.
If this can charge and be used at the same time, then it would make for the perfect table lamp. The E21A 9080’s light quality is better than any light bulb I’ve tested and I tested ALOT!!
thefreeman
I saw your post about the light loss previously and indeed here this is a much better design, but maybe that’s the reason you didn’t notice the tint shift ? since it’s cutting most the greener light.
For lightbulbs the best I’ve seen are Sunlike SOL basically perfect.
SKV89
For me, I like duv a little below the BBL. It just feels so much more relaxed and welcoming. I’ve tested many lights with near perfect color rendering but lack the slightly rosy tint I like to see before bedtime.
lightdecay
I am interested if warm white E21A is available. 2000K preferred.
thefreeman
Ah yes, me too, and apparently most humans , Sunlike SOL are perfect compared to the reference black body.
derpilgerer
derpilgerer's picture
interested in 2000K
Captain_Joe
Interested in 2000 K & 4500 K!
