outstanding first Rodeo!
congratulations
Thanks!
I’ve been quite inspired by all the dedication and creativity around here. It’s infectious!
Looks good Blahblahblahhuh! You could get a new LED spacer that will fit your needs with centering. I’ve struggled with this in the past. You can try over and over again to get the LED centered, and eventually with luck it will be close to centered. But with the right spacer, centering is so easy. Kadomain has a great variety of spacers: MISC PARTS.
Thanks!
And wow! Those are lots of different spacers! I’ll check those out. The impatient part of me wasn’t going to wait weeks to get them to solve the problem. But the future me will thank you when I order a bunch and avoid this problem altogether.
I’ve purchased last year copper version of Astrolux C8. It was deep in the drawer until yesterday. I’ve swapped standard BLF Bistro driver and XP-L HI to some more fancy components.
Took L4P 9A driver and Luxeon MZ 3000K bought here and put things together. The whole set creates nice WARM Flashlight. Copper is kind of warm in touch (silky and smooth thread movement). True - heavier than the aluminium, but so much nicer.
Surprisingly Luxeon MZ (4 panel LED) and SMO went together very nicely this time. I like Simon’s new 3030 9mm hole gaskets. They get widened easily and allow to sit reflector deeper which results in more focused beam. In case of MZ it gave not round hotspot but “+” shaped, very unique looking with a functionality of 5050 wide hotspot.
Some pictures below, the housing of copper C8 is eyes pure happiness just by itself Enjoy.
Very nice!
Some sliced LH351Ds to replace the 2700K and the yucky 6500K SST-20s in a tint ramping Sofirn IF25 :
For reference : SST20 JA3 2700K on the left, LH351D 4000K on the right.
Neutral tint at the extremes and slightly rosy in the middle :
That’s awesome! So to be clear you replaced the sst20s with sliced 5000k and sliced 2700k? Or was it 5700K/2700K?
Either way the tint/cct range is awesome
Thanks, I really like the tint ramping feature, I wish there was some better hosts/driver though, it would be great in something like a D4V2, or maybe a fireflies E07 or E12, with E27A for a large CCT range.
Yes it’s 5000K+2700K, I didn’t have any 5700K at the time, with 5700K or even 6000K (if the tint is good enough) it would have been better, estimation with sliced 5700K :
Crossing the –0.0050 duv mark in the middle.
Modded Atom AL Mule w sw45 to Aspheric lens, for a more collected beam.
Nice aspheric
thank you for the encouragement
I dont like mules, they throw light sideways too much
puts light in my eyes when tailstanding…
all three lights are on, only the mule glares at the camera:
I have an aspheric I use in the workshop all the time, and a mule I like only for its short physical length and low moonlight mode.
Where did you find the aspheric lens?
I’d like to add one to an old EagTac T25C2 :sunglasses:
the aspheric came from Kaidomain
18mm Optical Glass LED Lamp Lens
I originally thought I would try it on an AA Tool, but quickly discovered that the reflector places the LED too far from the lens. The aspheric lens only works up close to the LED.
Ah. Thanks for the insight!
Good, straight file works almost as precision ground flat stone - removes protrusions from the surface and leaves it flat. When the surface is already flat, it just slides back and forth without material removal.
Using sandpaper rolled around such a straight file can give some visible improvements in material removal rate.
Nice mod jon_slider.
I am looking for a new tester for my flashlight and hope that he will contact me at next second.
