The lantern can also be reflashed with a SOIC8 clip… which is much easier to obtain.
Otherwise, yes, it can run Anduril 2. I’m using it on mine.
Sad to hear, hope they can still build the Olive green, FDE, and bare aluminum models still.
I am still holding my breathe for olive green or something close.
I have not been on here for a long time.
Are there any accessory kits available or at least a reflector to block the back facing light?
Can someone help me out? I bought a new one of these, has Rev 5 board. I was going to bridge 6,7 pads but noticed none of my pads were bridged and from looking around it looks like all rev 5 pads are not bridged. Can anyone shed some light? I thought 4 and 5 were always bridged from the factory. Was v5 changed?
4 and 5 are now bridged with 0 ohm resistors rather than being soldered.
So if I want to bridge 6 and 7 I can still do so and it will work the same as it did before?
Yes.
Another question, does anyone know why it recommends not running it on high if only off USB (no batteries connected)?
Whining noise from the charge regulator chip, I believe.
whats the ATL for the LT1?
LT1 arriving soon.
Which Anduril firmware should I update it to?
I have a SOIC8 clip to modify a UT210E…
The LT1 build of Anduril 2?
Most up-to-date build of Anduril 1 is already installed on the LT1?
before flashing, see if there is a feature you want/need on it first?
mine came with SOS, long push from off gives low mode. i’m good
Good point. I’ll only flash it if there’s some bug that was fixed for a feature that I’d use.
cheers TimMc
I’m a bit lost with trying to find the project / branch for LT1 and what was changed (checks ToyKeeper’s signature)…
LT1 arrived! The handle is aligned perfectly.
Thanks DBSAR and Sofirn!
still endlessly waiting for LT1 to arrive at amazon.ca warehouse
I ordered the LT1 kit from amazon.com.au on the 29th of October when there was no stock locally in Australia. It was shipped from China and arrived today.
Can you order the LT1 from amazon.ca and have it shipped from China? No pressure lol. If you don’t need a lantern… It is rather nice
