Good day Martin!
Any better deal than existent we can expect by Halloween for LUMINTOP X9L?
maybe - i have no info yet
Sofirn SP40 led Stirnlampe 1200 Lumen CREE XPL LED Kopfleuchte mit 18650 Batterie und Magnet
CONVOY S21B with KW CULPM1.TG 6A Driver Strong LED Flashlight 12 Groups 21700 Version Torch Flash Light
Sofirn SP33 V3.0 3500 Lumen , USB Ladeanschluss XHP50.2 Leds mit 26650 Batterie
damn, still no a3 pro
Is the diffuser made out of rubber? It looks like a hard plastic.
2020 Singles Day & M4D Sales
veröffentlicht am 10. November 2020 in flashlights von m4d m4x
Hello my dear friends!
Here are my deals for this special sale – if you find more let me know and i add them!
-> SHARE THIS PAGE SO YOUR FRIENDS CAN SAVE $$$
https://www.banggood.com/custlink/GmKd5SmuU7also try my code for better deals on many items!
28% OFF Coupon: BG1128
[Astrolux 5th Anniversary Limited Edition]
Astrolux® FT03 SST40-W Copper/Brass
2400lm NarsilM v1.3 875m Long Range Flashlight 2A Type-C Rechargeable 26650 21700 18650 Thrower LED Torch
My Code: M5thLD
Your price: $71.99
Astrolux® FT03 XHP50.2 Copper/Brass
4300lm 735m NarsilM v1.3 Thrower LED Flashlight 2A USB-C Rechargeable 26650 21700 18650 Strong Torch
My Code: M5thLD2
Your price: $76.99
Astrolux® FT03S SBT90.2 Copper/Brass
4500lm 1428m Anduril UI Thrower LED Flashlight Long Range 21700 26650 18650 Powerful Flashlight
My Code: MA5th03
Your price: $96.99
[NEW]
Astrolux® FT02S 4* SST40 7000LM
Ultrabright Anduril UI Strong Flashlight 639m Long Range 18650/21700/26650 Powerful LED Torch
My Code: :MA5th23
Your price: $40.99
[NEW MODEL GROUPBUY]
HAIKELITE HK4S 4x SST20 4000LM 650M
Super Bright Long Range EDC Flashlight Type-C USB Rechargeable 21700 26650 Powerful LED Torch
My Code: :MHK4S1
Your price: $38.99
HAIKELITE HK4S 4x SST40 7000LM 500M
Ultra Bright EDC Flashlight Type-C Quick Charge USB Rechargeabl Mini LED Torch 21700/26650
My Code: :MHK4ST40
Your price: $41.99
PLEASE NOTE!
The prices may rise after the 11.11 Sale!
Ok - the copper FT03 is stunning! I see they left out the weight because that must be a ton of copper! The FT03 is a pretty big light.
Any special deal for the author of the firmware?
The HK4S is also a stunner in a small package - 5000K tint of course. Hhhmmmmm. I really thought I needed to take a break from buying for a while
hi i’m interested in the Rovyvons
what is the password for the copper Rovyvon Aurora A9 copper?
https://deals.m4dm4x.com/2020/11/05/rovyvon-aurora-a9-copper-650lm-usb/
Thank you my friend
Not a bad deal with that seeknite even though shipping increases the price to $14.29.
Astrolux® EA01
XHP50.2 3500lm SST40 616m Anduril UI
TIR Ultra-Throw EDC Flashlight Type-C USB Rechargeable
26650 26350 21700 18650 Mini LED Torch
including lung and short tube!
available in Black / Blue / Grey Body
available LEDs: SST40 5000K/6500K XHP50.2 5700K/6500K
my Code MAEA01 saves you 28%
Specifications
Product name: | Astrolux® EA01 TIR Ultra-Throw EDC Flashlight |
Brand: | Astrolux |
Model: | EA01 |
Emitter Type: | XHP50 / SST40 LED |
Color Temperature: | 5000k
5700K 6500K |
Max Output: | XHP50.2: 3500 lumen
SST40: 2300 lumen |
Range: | XHP50.2: 521 Meters
SST40: 616 Meters |
Intensity: | XHP50.2: 68000CD
SST40: 98000CD |
Firmware: | Andúril UI |
Driver: | FET+1 driver. |
Battery Configurations: | 1x 26650,1x 26350,1x 21700 or 1×18650 Li-ion Battery (Not included) |
Charging: | Integrated charger via USB-C |
Switch: | Electronic side switch |
Material: | Aerospace-grade aluminum alloy |
Waterproof: | IPX7 Waterproof |
Color: | Black, Blue, Grey |
Weight: | 120g(26350 version),160g(26650 version) [without battery] |
Size: | 26650 version:
116mm x 41mm (Length x Head diameter) 26350 version: 81.5mm x 41mm (Length x Head diameter) |
User interfaces:
[1] By default the EA01 is set to use SMOOTH RAMPING. Instant access to TURBO mode is also provided.
[2] A more conventional STEPPED RAMPING UI is available if you like discrete modes level. You can choose how many steps you want.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets. To exit this mode, physically disconnect power
[4] MUGGLE mode uses a reduced output.
[5] It has an electronic LOCKOUT for safety but acts also as momentary low light.
To know about the exact source code used in the product, please go to:https://tiny.cc/TKAnduril
1 x Astrolux EA01 Flashlight
1 x Lanyard
