This is what a user of AliExpress outside of China can choose right now as payment methods:
AliExpress removed the other payment methods from their international website sometime ago. As far as I am aware the only option is to use an old version of the AliExpress application, 8.4.0 or earlier to be more precise (you can download it in Uptodown.com, for example). Warning: the app checks for updates on startup, and records the amount of times it has moaned about updating; it eventually refuses to work without updating if you allow it to keep checking, so it is best to disconnect from the internet just before opening the app, and reconnect to internet once the app is about 10s launched (to dismiss the app update check).
With an old version of the application (8.4.0 and earlier) it is possible to select “other payment methods”.
Hard workaround to make an order work! If you order many small items from Simon the shipping costs for each item get totaled and skyrocket even though they will all go in one small package. I ended up for now ordering the same items elsewhere on aliexpress with free shipping until there is a way to work around this. It shouldn't be so difficult just to order something.
Sorry to know that it didn’t work :zipper_mouth_face: It is a sometimes weird site/app.
I normally use the app instead of the site, so I don’t know if there are differences.
I hope you manage to get it done in a next time and that you receive your stuff now
Yes, this is something I was also aware long ago. In Simon's shop any and all items feature “built in” shipping cost, this means the basic shipping cost is included in the price of the first unit of whatever thing. If this were a very small amount, this could work, but it is not a small amount and so it doesn't works.
The solution is to set the shipping cost independently, so the actual item value is reflected in its price. Allow the shipping cost to add afterwards. Many AliExpress sellers do it this way, and it works. As sellers, you are fully responsible for both the costs of items and the cost of shipping and handling. After all, what the buyer sees is the total to be paid, this is what counts.
That's the thing, shipping is not cheap for minor items and when you order so many different little items together, it just isn't worth it. I always prefer to order from Simon as he is a good guy, always helpful and knowledgeable, but it would be nice if he could make it easier to adjust the shipping.
I’m buying my first true flashlight. The convoy S2+ is the obvious choice.
I’ve been studying, reading and comparing for some time, to decide on SST-40.
This was true, until I recently discovered Simon offers S2+ with LH351D with new 5AMP (non 7185) driver.
I checked specifications along with test here on BLF online - and it seems that 3AMP is maximum with LH351D, unless I want to risk my led to burn.
The question is - how does the 5AMP driver works with LH351D? Doesn’t it destroy the led? Is this driver safe with this led? Or do I need to set the 12group driver to e.g. 0.1% 1% 10% 50% and never put it on 100%?
Yeah, the only thing that I would consider limiting to 3A is Nichia emitters - E21A a lot less, but 219b is about 3A. LH351D, I’d throw 5A at it without blinking.
Last time I selected webmoney as a payment method, it sent me to webmoney website then I closed the page, the order was left ”unpaid” and I could ask Simon for blf discount/consolidate shipping costs
That test is what we have to refer to but I've been using a Convoy 4 mode, 6A driver in an S21A for a while and there's been no issue.
In fact, what I've seen in my SP32A, D80v2 and the S21A with a LH351D is no amp reading higher than 5.5A. So, I think that LED will be fine with a good thermal path.
Personally, I'd go with an SST40 unless the hi CRI is all out necessary.
