Emisar 21700!!!
Noctigon K1 uses a 21700 battery.
which 21700 would you recommend for k1
If you have SBT-90.2:
All other emitters:
am i correct in assuming that its because sbt has a high drain? while all other emitters, including osram, are sufficiently handled by 10A discharge? does this make sbt run time less?
and also, it seems sbt advantage is high lumen? but whats the point of high lumen in a dedicated thrower? isnt kcd more important? the osram 2.1 having 650kcd will still have higher beam intensity, aka look brighter, than the sbt, no? sorry im still very new, just gathering pieces of information trying to put them together.
Noctigon K1 with SBT-90.2 can use FET turbo, while other emitters can only use regulated mode up to 5A or 7.5A max current.
SBT-90.2 has a much bigger hotspot, but because it can put out more lumens it also has very good throw. Other emitters have very good throw, but the hotspot is much smaller.
I recommend SBT-90.2 if you can afford it.
ya i see its 50 bucks on top, thats quite deep…i think maybe ill just stick to osram, its meant for pure throwing anyway, dont need a huge hotspot
21700 Emisar lights would make sense!
Hi, guys, new 21700 light will be released soon, with Noctigon name.
Great news, flooders or throwers? I still look for something what would keep high lumen flood on bike night rides better than Emisar D4s. Emisar lasts longest time when outside temp ist about 8*C.
The name is Noctigon K9.3, guess how it will be like :sunglasses: ?
This is great news!! Will it use the same battery holder (with charging function) as the K1?
9 emitters in 3 triples?
Yes
9 leds?! It will be huuuge… 3x21700?
If it’s like that, then we can simply call it K9, or K33, not K9.3.
My poor wallet!
Is date known? :slight_smile:
OHHHHH ! I cant wait to see what it is ! either way ill more than likely take 2-3 =D
K9 always reminds me of... :-D
K9.3 could mean...
  • 9 emitters where 3 of them have a different tint than the other 6 ones? Multi-channel operation to ramp tint?
  • 9 emitters with a big tube using 3x 21700 batteries? I don't think so because it would mean a veeery big head diameter, right?
  • 9 as in SBT90.2? Maybe 3x SBT90.2 with only one 21700 battery? Nah....it would drain the battery in seconds. :-D
I guess the only important question will be: WHEN will it be available? Because most people will say again...
Will you send a sample to ToyKeeper before, so we get a great review again (as usual)? ;-)
Hmm… maybe wrong guess, but what if it is 27× E21A? :partying_face:
