I’d add the headband strap upgrade at whatever price Barry thinks that reasonable.
Considering XP-E2 PC Amber could be also beneficial, as PC Amber (phosphor converted) is also gentle on eye (not simple Amber, because that is inefficient, and as the emitter gets hot, it starts to lose output considerably - but in terms of driving the LED, PC Amber acts more like a white LED, than a monochrome Amber/Red):
I guess, the only reason is, that SST-20 is not available in 5000K CCT (edit: as high CRI - I would not even consider "standard" CRI). If SST-20 would be available in the cooler white CCT range, then that would the choice without question :-)
LH351D 5.000K 90CRI has been rated to be a great tint choice on BLF (see Wurkkos WK30 or Sofirn SP36 BLF Andúril for comparison). And yes, it is "floodier" (or more floody?) than SST20 but it should fit in D25WR as it's the same 3535 footprint.
SST20 5.000K 70CRI is possible but not with HighCRI and its tint is know to be very greenish on low currents.
Generally spoken, yes. SST-20 5000K 65CRI was out of question, I wouldn't even consider that for any headlamp.
I just told, that if SST-20 95 CRI range would expand beyond the 2700K-4000K CCT range, that could replace even more emitters as "best default" choice.
Cree seems to be falling out of the innovation race. If I were them, I would also develop the corresponding HI (high intensity) variants for their XHP50.2 and XHP70.2 - and try to do something with the ugly rainbow beam.
XP-L HI warm high CRI emitters are treasure on their own kind.
d25 uses tiny reflectors around 10 –12 mm, i have not seen any single round tir of those sizes. stock reflectors however are fine when led used is a right one, my d25 came with LB leds and had a nasty beam with a center hole. i swapped them for xpg3, and beam changed completely. no more holes.
to answer op question, i’d be interested in 2 at least, any nw led is fine, , and around 620nm red, no deep reds, i build several lights with DR, not as good as regular red, harder to see,
