i dont know what youāre talking aboutā¦im simply encouraging more members of this community to share their experience with good lights, sharing is caring, and more the merrier!
that looks pretty solid for dog walking id sayā¦i think im gonna cop one
Skilhunt H04 RC Mini 18350 LH351D High CRI 4500K??
It might be pushing the budgetā¦
I got an M150 V2 LH351D High CRI recently. The UI looks the same. Group B is nice. You can enable/disable steps to have between 2 and 7 steps to ramp through.
Tint is around 4500K though. Iām not sure what the H04 RC Mini tint is like.
Not real sure on the run time. My gut says over 12 hours on medium. I use it for perhaps an hour or so a night. Frequently I use it on low but lately I have been using it more on medium. I know I typically go weeks between charging it. However, I usually have a 30Q or even a 3500 mAh battery in it. Havenāt used the built in charging since I got it and just did that to confirm that it works and terminates properly. It does.
Just pulled an old Tenergy 2600 mAh that I put in several days ago. Battery was still at 3.9V and at that age IIRC, its down to about 2000 mAh maybe 2200. So, weeks to perhaps a month in my typical usage. I did just do some projects and my wife used it for an hour or so on High resulting in the last charge only lasting a few days. Hope that helps.
hmā¦im most likely gonna be using it on high, so if i can get like a week out of it, then im happy, i usually only walk him at night for like 30 mins or soā¦
That was quick. Could you list your process, equipment used, and maybe the steps you took? Iām really tempted, but havenāt done emitter swaps before.
Oh, right. Regulation is the other wish-list item, but somehow while working on things I never really notice the dimming until it shuts off or just before then when the battery indicator LED is flashing red. Iām happy that it has low voltage protection.
Sometimes I put it on turbo, stick the magnet to a surface, and forget about it until it shuts off.
Yeah, the more flashlights/headlamps I try, Iām finding that this is really a differentiator. Itās why some headlamps/lights are more expensive: better drivers.
The Manker E03H headlamp and inexpensive Sofirn C01S are regulated, IIRC, so the regulated lights are not always more expensive.
Ironically, because the regulation on the E03H keeps the light at one of the (high, medium, low) levels, the drops are very jarring as the battery depletes, while I donāt notice the slow decline on the unregulated SP40.
Thanks for including all the details. It makes a difference for someone whoās never done it before.
In addition to sourcing the emitter, I would need to get some solder paste (most seem to have 1-2 year shelf life and suggest keeping refrigerated) and decide on a pan to sacrifice for this purpose. Sooner or later I just know I have to try thisā¦
