Headlamp/headlight recommendations wanted
significantly, in every almost case. the only time we get some perks is if they listed a new product in USD, but we buy it in CAD. thats about it. lol, we have less selection, higher prices. such a scam
Wow, $32 with 15% off? That’s a pretty legit deal. If I didn’t already own it, I’d be all over that. I didn’t even realize they had it on their Amazon store. You could do much worse for $28 IMHO.
ya if i didnt have to pay import fees, id be all over that too…
There's actually two listings.
One offers 15% off, and the other is 20% off.
That's about $25.60 before tax.
whats the difference between the 2?
Good question.
They look the same to me.
looks like theres only one way to find out :stuck_out_tongue:
Great thread! I’ve been using a Nitecore for years that has a variable brightness white LED and blue, green, and red auxiliary ones. But I recently for a 2000K Noctigon KR4 and I’m loving this color temperature.
Any suggestions for a high end headlamp? Like best of the best, cost no object, ideally with a warmer color?
Nice Gchart, pretty awesome chart comparison
My verdict is to Convoy H1, look at the Lumen line vs Temperature Line…I’m seen pretty well calibrated step down vs other. It managed squeeze out 750ish lumen for 40 mins and gradually adjusted below 750. The only downside I see is, its getting really hot, 85’c is the highest. I dont know that too hard, maybe for the battery life if it is expose to above 60’c. Unless the HL had manual temperature recalibration, that should solved. I think recall back, there is temperature reconfiguration…can remember though
15% off includes cell and usb cable.
i dont know man, the temperatures are significantly hotter than the other two, which never peaked past 55, but 84 is quite hot.
and yes, convoy had good lumen output for the first bit, but if u look at the X axis carefully, it goes down to 300lm ish around 100 mins, and completely dies before 140 mins, whereas the sp40 was at maybe 350lm at 100 mins, and remains above 250lm before min 180. so in the long run, sp40 is much better, 100lm is still useable output, and it can last past 250mins. wuben is better before min 160, but if you just want a really bright first hour, then convoy is better
oh thats a no brainer then, 5% of like 32 bucks is like $1.60, for a battery, and sofirn batteries are solid too.
It looks like the 20% off model is new for 2020 (part# 2020101602) as opposed to the 15% off one (part# H1). Their website also states “[2020 Latest] WUBEN H1 1200 Lumens Rechargeable Waterproof LED Headlamp” when buying directly from them so I assume there’s a difference. What it is I have no idea :stuck_out_tongue:
I would have thought that the older model have the bigger discount but that’s not the case.
Wait theres an older version of the h1??
Although only the 15% off has a pic of the cell and cable, in the text description, both the 15% off and 20% off say they come with the cell and cable.
… but if you want to have really hi cri - warm white - efficient - stabilized mode - light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))
I've changed my mind about the Lumintop HL3A.
The brightest model is only about 500 lumens over any significant length of time, according to this review:
https://zeroair.org/2020/03/18/lumintop-hl3a-flashlight-review/
(The "2800 lumens" doesn't last very long at all.)
The Wuben H1 keeps on looking better for my needs.
It's only about 500 lumens as well, but somewhat cheaper (on American Amazon.)
Wuben H1 have no warm led, if you dont need warm led you can just get D10 for 10$ ;))
Quadrupel wrote:
".. but if you want to have really hi cri – warm white – efficient – stabilized mode – light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))"
(Sorry, but I cannot quote your post properly for some reason...)
I don't care about high CRI.
EDIT:
I am not sure if I want a 5700K headlamp.
(I didn't realize that was cool white.)
Looks good, but for few dollars more you can get H04 :wink:
