Great thread! I’ve been using a Nitecore for years that has a variable brightness white LED and blue, green, and red auxiliary ones. But I recently for a 2000K Noctigon KR4 and I’m loving this color temperature.
Any suggestions for a high end headlamp? Like best of the best, cost no object, ideally with a warmer color?
My verdict is to Convoy H1, look at the Lumen line vs Temperature Line…I’m seen pretty well calibrated step down vs other. It managed squeeze out 750ish lumen for 40 mins and gradually adjusted below 750. The only downside I see is, its getting really hot, 85’c is the highest. I dont know that too hard, maybe for the battery life if it is expose to above 60’c. Unless the HL had manual temperature recalibration, that should solved. I think recall back, there is temperature reconfiguration…can remember though
i dont know man, the temperatures are significantly hotter than the other two, which never peaked past 55, but 84 is quite hot.
and yes, convoy had good lumen output for the first bit, but if u look at the X axis carefully, it goes down to 300lm ish around 100 mins, and completely dies before 140 mins, whereas the sp40 was at maybe 350lm at 100 mins, and remains above 250lm before min 180. so in the long run, sp40 is much better, 100lm is still useable output, and it can last past 250mins. wuben is better before min 160, but if you just want a really bright first hour, then convoy is better
It looks like the 20% off model is new for 2020 (part# 2020101602) as opposed to the 15% off one (part# H1). Their website also states “[2020 Latest] WUBEN H1 1200 Lumens Rechargeable Waterproof LED Headlamp” when buying directly from them so I assume there’s a difference. What it is I have no idea
I would have thought that the older model have the bigger discount but that’s not the case.
Although only the 15% off has a pic of the cell and cable, in the text description, both the 15% off and 20% off say they come with the cell and cable.
… but if you want to have really hi cri - warm white - efficient - stabilized mode - light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))
".. but if you want to have really hi cri – warm white – efficient – stabilized mode – light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))"
(Sorry, but I cannot quote your post properly for some reason...)
its not that impressive, i think it depends on how much you need. if you need consistent 450-500lm ish, then wuben is the way to go, however, if you’re ok with maybe 200-300lm, then sp40 is much better
The sp40 may be the only headlight available with 3000k (shipped from china). No moonlight but a simple UI and micro USB. Can’t keep the clip on while in the headlight strap and that applies to most headlights. The Wowtac a2s is a strong contender at 30 bucks. I think the Armytek pro series including the brand new C2 has got to be the best all around headlight and with the clip on the tail end you can keep it on in the head strap. The UI sounds impossible when you read it but once you’ve done it a few times it’s very simple. We don’t know for sure that the new one is high CRI but it likely is. “Warm” and “white” labels/options. 3 moonlights, 3 turbos, 3 in the middle. 3500mah high drain battery. Magnetic charging, magnetic base. Wide smooth beam pattern. Plus other things that you don’t get in others. I don’t know what more you could ask for.
