Although only the 15% off has a pic of the cell and cable, in the text description, both the 15% off and 20% off say they come with the cell and cable.
ā¦ but if you want to have really hi cri - warm white - efficient - stabilized mode - light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))
".. but if you want to have really hi cri ā warm white ā efficient ā stabilized mode ā light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))"
(Sorry, but I cannot quote your post properly for some reason...)
its not that impressive, i think it depends on how much you need. if you need consistent 450-500lm ish, then wuben is the way to go, however, if youāre ok with maybe 200-300lm, then sp40 is much better
The sp40 may be the only headlight available with 3000k (shipped from china). No moonlight but a simple UI and micro USB. Canāt keep the clip on while in the headlight strap and that applies to most headlights. The Wowtac a2s is a strong contender at 30 bucks. I think the Armytek pro series including the brand new C2 has got to be the best all around headlight and with the clip on the tail end you can keep it on in the head strap. The UI sounds impossible when you read it but once youāve done it a few times itās very simple. We donāt know for sure that the new one is high CRI but it likely is. āWarmā and āwhiteā labels/options. 3 moonlights, 3 turbos, 3 in the middle. 3500mah high drain battery. Magnetic charging, magnetic base. Wide smooth beam pattern. Plus other things that you donāt get in others. I donāt know what more you could ask for.
Why must we care about cri all the time? Im not colour blind, i know what its supposed to be, i aint trying to paint in the dark, just need to see what things are where
Thanks for the great advice! I just went on Acebeamās site and saw the H60 FULL SPECTRUM HEADLAMP:
ā Acebeam H60 utilizes the new SunLike TRI-R technology for high CRI (>97) and TLCL ratings with spectral distribution as close to the sunlight as possibleā
