Last time I selected webmoney as a payment method, it sent me to webmoney website then I closed the page, the order was left ”unpaid” and I could ask Simon for blf discount/consolidate shipping costs
That test is what we have to refer to but I've been using a Convoy 4 mode, 6A driver in an S21A for a while and there's been no issue.
In fact, what I've seen in my SP32A, D80v2 and the S21A with a LH351D is no amp reading higher than 5.5A. So, I think that LED will be fine with a good thermal path.
Personally, I'd go with an SST40 unless the hi CRI is all out necessary.
Has anyone else had an issue with the Omten switches squeaking? I have a fairly new S6 and S2+, and both switches squeak on half presses? Anything I can do to quiet them down?
Excuse me, do you mean that 2.5A red led driver cannot be used in a S2+ host? It is 17 mm wide, isn’t it? Will it fit into S3 host then? Because I need a small red light, and I have already ordered red osram on a 16 mm board.
And for this setup, a 6×7135 driver would be the best. S2+ body is small, so even 8×7135 is too much - considering, that this LED does not tolerate heat as much, as many others - so it either needs limited power or good heatsinking with a good amount of thermal surface.
I would be happy with a 4*7135. Really just want to be able to run it as bright as possible without getting too hot for around 10 minutes (for photography lighting).
KY CSLNM1.FY ,it’s not pure yellow light .
Like the green light, it uses the design of coating phosphor powder on the blue chip. I can actually think of it as a warm yellow light with a color temperature of 1800K.
