How trustworthy are Sofirn batteries?
206 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 1 hour 18 min ago
ThirdHandChain wrote:
LittoKala LI 500 Engineer charger/tester. Black 18650 3000 mah button top rechargeable 3.7v that came with a sofirn SP31 V2.
You can’t trust the resistance reading then, most chargers aren’t an accurate measurement.
I have the same charger and can get 125 and others 35 using the same battery.
Button tops also raise the resistance, some more than others. Last year I purchased 120pcs Sofirn 18650’s to find the buttons could easily flick off with a knife. Very poor soldering job. The batteries are almost as good as a Sanyo NCR18650GA with the button removed.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
d_t_a
Last seen: 19 hours 22 min ago
Liitokala Lii-500 Engineer doesn’t show precise mR values (values will change even for other batteries).
However, the button on the button-top does add resistance for such kinds of chargers.
HKSJOSHUA_
HKSJOSHUA_'s picture
I just orded two samsung 40t batteries I do not trust the battery that they offer the sofirn c8g with.
Appreciate all the little things in life!
Richard Noggin 28
Why?
HKSJOSHUA_
I don’t know suppose I just think of them as being a rewrap batt.
Besides I had a better deal ordering two legitimate cells for a little more for what sofin wanted for one battery
JasonWW
JasonWW's picture
Last seen: 2 days 1 hour ago
They are a rewrapped cell because Sofirn is not a battery manufacturer. This does not mean it’s bad, though. It comes from a chinese battery manufacturer and generally speaking their chemical mixes tend to be slightly not as good as a company like Samsung.
The 40T is a top notch cell, but it’s usually more expensive than a chinese battery. The cheapest I’ve seen the 40T is about $7-$8 each plus shipping. If you paid noticable less than that, I would be suspicious if it’s a real 40T.
HKSJOSHUA_
I paid 6.99 a cell on 18650batterystore but with a coupon code it came out to 20 bucks shipped sofirn wants 9.99 for one cell that shyed me away lol
Funtastic
Funtastic's picture
If you get a Sofirn battery bundled with the flashlight I find it’s much cheaper on Ali or their website
JasonWW
JasonWW's picture
That sounds legit.
Funtastic
Funtastic's picture
Here’s my discharge test of the PLB 26650 5000mAh 10A cell Sofirn now stock.
The datasheet shows a maximum discharge temp of 60 degrees Celsius. Though the 20A discharge performs well, it exceeds the max temp at 74 degrees.
Keep in mind the results are slightly lower on the graph than the actual voltage due to resistance
5A – 0.01v
10A – 0.02v
15A – 0.03v
20A – 0.04v
Here’s a comparison vs the Sofirn 26650 HD 5000mAh
JasonWW
JasonWW's picture
Can you add a picture of each cell? I didn’t know Sofirn sold a PLB cell. The common PLB cell most are familiar with is the 5750mah. Pictures might help to clear things up.
The Sofirn PLB 5000mah is this one, right?
The High Drain you tested was this one that says 25A on the label?
Even though the older PLB 5750mah (Shockli 5500mah, etc…) was better than this new one (higher continous amps 20 vs 10-15, plus higher capacity) this newer 5000mah is still beating the cells Sofirn uses in their HD version? Man, that’s high praise to PLB. I wish they hadn’t discontinued the older, better cell.
Funtastic
Funtastic's picture
Yes, that’s the correct PLB cell I tested
Also the same Sofirn 25A HD button top
I was rather disappointed the older cell had been discontinued as I had placed a bulk order from my supplier. I had to then change to these PLB 5000mAh but I’m not disappointed.
Funtastic
Funtastic's picture
Funtastic
Funtastic's picture
I’ll run another discharge at 15A to check the temp. Pretty certain it was around 50 degrees Celsius
Funtastic
Funtastic's picture
Okay, I ran another discharge test at 15A and the temp reached 62 degrees Celsius. Slightly exceeding the max of 60. I reckon 14A continuous would be fine
I wonder what the ideal room temp is meant to be for an accurate test. Room temp tonight is 20C.
I’m not sure what’s up with this cell on capacity as almost every discharge shows a different result. Then again my charger hasn’t got a reliable cut off, sometimes 4.20v and others up to 4.25v.
This test at 15A got just over 5400mAh and battery was 4.23v
TimMc
TimMc's picture
Last seen: 40 min 5 sec ago
I received four button top 18650’s in a BLF LT1.
Sofirn 18650 3000mAh Test #1 (2020-11-06)
Room temp: 17C
Capacity (mAh):
3060, 3071, 3051, 3091
Internal Resistance (mOhm):
51, 59, 53, 46
Measured with a Vapcell S4+.
Is 2A continuous charge ok for these when around 3.8V?
niajef
Last seen: 6 hours 8 min ago
Room temp: 17C
Capacity (mAh):
51, 59, 53, 46
i have similar findings with their 18650, all measured just a tad over the rated 3000, but their 26650, which is supposedly PLB re-wrapped, rated at 5500, one of them measured at 5480, which is close enough ill let it slide, but the other is 5331, a bit disappointed with that. the no brand 26650 that came with my ft03 was over 5500, but it was only rated 5000
Funtastic
Funtastic's picture
Room temp: 17C
Capacity (mAh):
51, 59, 53, 46
I personally wouldn’t charge at 2A for a cell that has no datasheet. I no longer use Sofirn batteries, I stick to the big brands
JasonWW
JasonWW's picture
Room temp: 17C
Capacity (mAh):
51, 59, 53, 46
Like Funtastic said, without a data sheet its risky. You can try as long as your willing to monitor the temperatures to make sure they don’t get too hot. I would feel more comfortable at 1A to 1.5A.
JasonWW
JasonWW's picture
Surely you are not referring to the PLB 5500mah cells relabeled by Shockli, etc… No one has ever said they are related. They are definitely not related. They use a local Chinese made cell. Some measure closer to 5000 and some closer to 5500 and they separate them into two groups and label them appropriately. They are quite generic and nothing special.
The PLB 5500mah on the other had is a top quality cell. One of the best in its capacity.
niajef
i mean, it literally says that right on their site , even the ones that come with lights , are you saying they straight up lying? they dont say anything for their 18650s, and other manufacturers dont do this either, so i dont see why they would go out of their way to do this if its not true?
Funtastic
Funtastic's picture
Looks like they’ve just recently switched. The flat top PLB wouldn’t connect in series and so their factory rewrapped them and added a button top.
Might of been helpful to drop a link right from the start since the PLB button top has just been released by them. Jason was talking about the previous Sofirn 26650’s that came spec’d at 5000mAh and 5500mAh
TimMc
TimMc's picture
JasonWW
JasonWW's picture
We may be confusing the batteries. Their 5000mah HD 25A cell is a different version. They have 2 different 5000mah cells.
The regular 5000mah (and 5500mah) that are flat top (looks like button top is a new option) are not HD and have no amperage rating.
Then they have their newer 25A HD cell.
PLB stopped producing the 5500 that was so great and now produce a 5000 that is a bit less impressive. Don’t ask me why they stepped backwards.
I don’t think Sofirn said anything about their Heavy Duty 25A 5000mah being an actual PLB cell when they came out. They are definitely saying it now, at least on that Sofirn website. I checked their Ali store and there is no mention of PLB at all. I got a pair of these HD cells when they first came out and they are pretty impressive.
I have not gotten any of the new 5000mah PLB cells to compare them to. I also haven’t read any reviews comparing these 2 cells to each other.
So I dont know if the 25A HD are PLB rewraps or not.
Their other black 26650 is definitely not a PLB rewrap.
niajef
oh ya im not aware of that, i literally came into the flashlight scene like 2 weeks ago, so i just assumed sofirns been doing this for a while
TimMc
TimMc's picture
Ah. I had assumed that there would be a datasheet and some independent tests when I got the BLF LT1 kit. Facepalm
Perhaps I should get a few more Sanyo NCR18650GA. Big Smile
I’ll see how these go… don’t want to waste them.
niajef
im a little confused, actually very confused.
first, i dont know what you mean by their regular 5000mah that are flat top and looks like button top, are they selling that? i only see one battery option on their site, and its 25A HD, which they claim to be PLB, and 5000mah. wheres this regular one you’re talking about?
second, the one i got says 5500mah on the wrap. and i checked amazon.ca description, thats where i got them, they came with sp70. and it doesnt say PLB wrapped, it just says “(Sofirn 26650 5500mAh Button top batteries included).”
but on their own website, the sp70 listing does say it comes with PLB wrapped 26650, but it doesnt say the capacity. so does this mean the ones that come from amazon are the “regular” ones you’re talking about? and only if i buy them separately, or buy sp70 from their website, it comes with PLB cells?
i think im gonna need to have a word with their customer service and clear the air…
Funtastic
Funtastic's picture
Oh, if you’re charging them inside the LT1, they’ll be fine since it’s not 2A per battery, only 0.5A
niajef
or u can just leave s4+ on auto and let it do its thing…
JasonWW
JasonWW's picture
OEM cells from Molicel, Samsung, Panasonic, Sanyo, LG and Sony are the best. You always get accurate data sheets.
General rule of thumb is the higher drain cells can also take the fastest charging. Standard charge for GA is 1.67A. So they are probably okay at 2A.
I tend to use a lot of 30Q and I always charge them at 2A. It’s not an issue at all for them. Rapid charge for 30Q is 4A.
