well their sp70 listing says “You are buying SP70 KIT with 26650 Batteries(rewrapped PLB cells), choose 5000K or 6500K.” i dont think thats vague at all, thats straight up telling us, yes we are sending you the flashlight with PLB cells wrapped with our name.
also, where are you seeing 4 listing in their own store? i see none, i only see them, and the blue ones you mentioned, in “E-battery store”
ah whatever, im too lazy to figure all that out, im counting on it to make the best decision for me, if sometimes it screws up, then it is what it is. batteries are consumables anyway, if i can get a few yrs of life out of them, ill be happy
That’s the thing, i dont know! because this sp70 listing on their site doesnt specify the capacity, it just says PLB wrapped. and on amazon, it only says capacity, 5500mah, does not say PLB. so theres no conflict with the two listing at all. it could very well be 5500mah PLB cells, they just missed a piece of information in each listing. and then they have their own separate battery listing for 5000mah PLB. god this is so confusing.
im starting to think maybe sofirn has 2 batches of batteries, 1 that comes with flashlights, probably cheaper and worse in quality, and 1 thats being sold separately. cuz their 21700 lights come with 4000mah batteries, while separately sold ones are 4800mah. although 18650 doesnt fall under this pattern, both separately sold ones and ones that come with flashlight are 3000mah.
In my opinion worst thing which can happen if charging the cell at 2A is somewhat reduced lifespan, nothing more serious. Also, 2A can only be maintained until maximum charge voltage is reached, which due to current rate by rail resistance overhead will be attained earlier (less time at 2A and longer CV phase). To sum up, I wouldn't care.
Highest discharge rating I've seen at PLB for their NMC cells is 3C here and there, with a restrained 2C nearly elsewhere. The official rating may seem low but I guess the chinese government, their main customer (for their EV buses fleet) doesn't likes to be lied.
The Sofirn rating, on the other hand, is a typical unofficial fabrication. The worst part is that they went too far, 25A is not a safe discharge rating for these cells. HKJ tested them from different rewrappers in the past (here, there, or the 55A cell over here) and it can clearly be seen that at 20A not only their end of discharge temperature gets on the limit, but their discharge curve also looks forced and already losing capacity. So, the bladesmith leaving the forge is… Sofirn.
5500mah, they came with sp70 when i ordered them off of amazon
i wrote them an email just now, but its saturday morning in china already, they dont work on weekends, they should get back to me on sunday night. i will update here if they come back with a solid answer
I think their 25A HD cells are quite good regardless of the amperage over rating. I use them daily in my SP70. I would say they are comparable to my older black and blue Liitokala.
I have not tried their regular, non HD 5000mah and 5500mah. Based on the tests I’ve seen of them I believe they are fine for low amperage lights, but won’t give the highest output on FET driven lights. Decent I would say.
Okay, I’m in the US so I may not be seeing the same exact ads on Amazon.
I see one listing for the SP70. Its from the Sofirn store and has 90 reviews.
They list it as coming with the 5500mAh cells and rated the lights output at 5500 lumen.
So I don’t see anything contradictory to what you received.
Keep in mind that when they bundle products together like a flashlight, batteries and charger to ship to Amazon they can choose whatever combination of parts they want. Then when it comes to sales on their own website they can bundle together whatever parts they want there. So it’s quite possible their website could list the HD batteries and Amazon could be selling it was the non HD batteries. This is perfectly normal.
yes, that’s what im suspecting right now, and that’s what i asked them. because it would kind of makes sense, and its sort of a marketing ploy, where they list only one battery option per size, so u would think they only have one type of this battery, and so if the light comes with batteries, it has to be those. when in fact, they just dont openly sell the shittier ones, and use them to couple with their flashlights.
and ya, it doesnt contradict with what i received, because the amazon listing shows 5500mah, and i received 5500mah, however, the weird circle of confusion and contradiction comes in when amazon sp70 says 5500mah, while sofirn sp70 says PL. now, theoretically, those should be the same batteries, which means mine is PLB, and that sofirn has 2 versions of PLB, 5000 and 5500, but they only sell 5000 separately on their site. alternatively, if mine is not PLB, then it means they only send the 5000 PLB with sp70 orders placed on their site, but everywhere else, amazon, BG, AE., they send the non PLB 5500mah. again, im leaning towards the latter, but we’ll see come sunday night.
Ok, confirmed, 5000mah 26650 is PLB, 5500mah is not, new orders of sp70 should come with 5000mah, but amazon still has old stock, thats why it came with old 5500mah.
Of course this is assuming they are telling me the truth, personally im willing to give them benefit of the doubt
Thanks for the test of the PLB 26650 5000mAh 10A. I got a pair when they were on clearance at Sofirn’s website and only now have a Convoy M3 to use them with!
Lumeniac didn’t directly mention what cell he used for runtime tests in his M3 review, but assuming it was a Liitokala 26650 5000mAh, the runtimes should be just as good with a PLB.
Actually, I don’t think the Sofirn 5000/5500mAh 26650 are always labeled correctly.
Some of the Sofirn “5500mAh” 26650 test a bit closer to 5000mAh, and the battery (the top portion) looks a bit different, indicating it’s likely a different battery.
Although the 5000mAh (based on capacity testing, not the wrapper label) 26650 seems to have a bit lower internal resistance (using a YR1030 battery resistance meter to test)…
i recently got an sp33 v3.0 and the battery is definitely labeled as 5500. Is this a lie? I’m looking to get a spare but if these are not properly labeled then I will look to get 2 if i will see a difference in turbo output as on another post someone mentioned they saw brighter turbo output from an older 21700 4000 sofirn than when a newer 5000 sofirn was used in the same light. to clear up my thread i have been on a bit of a sofirn splurge so i have 3 new lights, 2 using 21700 (c8f and lt1s) and sp33 26650 so…i’m wanting to get the most of the 2 flashlights as i don’t expect nor really want to get much if anything more out of the lantern but who knows. coud it be resistance problem that would cause less output? neither are throwers but i’m not super impressed with them as they both claim around 3500lm turbo output. An expert i’m certainly not but also these are my first lghts with a claim of higher than 1400 so i don’t really have a good personal reference to compare.
