Interested
Green one with sst40 ordered!! Thanks Freeme
Thank you.
Interested. Can i have a code please?
Thank you, green EC01 SST 40 ordered
Sent.
I have a XHP50B 5700K more than a year, and now received SST40 5000K. New tint is nice, but I want to let you know that SST40 hotspot significantly smaller than XHP50B. With a smaller hotspot it became less convenient for me.
*Edit: can't embed an image so put a link here
Thanks for sharing, Casual. Allow me to repost your pic for you.
Can i get a coupon code for this please
That why it mean a lot to create triple SST40 as such EC03 is perfect host, even upcoming FT02S with Quad SST40, is to jump-up the lumen output and in getting bigger hotspot, though not bigger as the xhp50.2 but in near close comparison.
Done. [quote=jaynick] Can i get a coupon code for this please [/quote]
I have been looking for the beamshot picture of the SST40 5000K on EC01. Thank you for sharing.
Interested
SST-40 versions should really have an SMO reflector - the LED is more for throw and the LED has little to no beam tint shift, so SMO is the way to go.
XHP50.2's beam has some ugliness to it, so OP is preferably bettery. Ok, I can't rhyme...
Sent.
Interested
My green EC01 just shipped
Expected dilivery date Jan 2, 2021
Estimated delivery date is Nov 30.
Shouldn't be that long.
… Expected dilivery date Jan 2, 2021 :person_facepalming:
Does anyone know what’s the current draw with SST-40 emitter? Thanks.
Also one suggestion to Astrolux - a dual switch setup with a simple on/off flat tail switch (there’s plenty of space there) with a side switch for mode adjustments would be much easier to use than than too complicated, “one million clicks” Anduril UI.
I disagree, this flashlight is not a thrower and if you want one - search for something else. SST-40 makes beam profile less floody and more balanced but it’s still not a thrower, just a good all rounder. Also SST-40 emitter is the only way for people who don’t want a very cold white light (6500-7000K) of the XHP50 emitter.
I disagree - don't add a tailswitch - waste of length, adds resistance, and Anduril is smart about LVP and monitors voltage with the e-switch off (used to be a problem with Narsil, etc.).
Are you familiar with the Sofirn C8 lights?
