Does anyone know where else can I get the 18350 tube? Sofirn shops seem to be out of stock.I messaged their CS and they said maybe 2 weeks before they restock.
I could just buy an sp40 I guess, but that seems excessive. Even if it is a good deal of a light.
I'm not clear on exactly what the questions are above, but the stock wires appear to be ~24 AWG and are too short to pull the driver out and get a SOIC-8 clip on the MCU. My plan would be to replace them with longer 22 AWG's - think it should fit and allow the re-programming without de-soldering the LED wires. The switch wires appear to be just long enough to allow this, as shown below:
I tried to remove the bezel with circlip pliers first but I slipped and scratched the bezel. I then just tried to rip the cover out with my fingers and it worked. :innocent:
Thanks! I was thinking of trying to push a SOIC8 clip through the switch hole to reach the MCU as a backup plan to avoid soldering. I’ll probably end up swapping the emitter anyway… but it would be useful for those who just want to update/change Anduril.
To be able to pull the board down to reach the MCU, would you need to do the following?
Remove the bezel with some straps, a vice and heat
Desolder the 24awg wires from the PCB with the LED
removed the bezel by clamping the head in a vise, cushioned by pine boards (no damage)
either I used my sticky blue gloves, or used a strap wrench - seem to recall it came off fairly easy, no heat used (sorry, I mod a lot of lights and lose track of details, and had no notes)
de-soldered the LED wires form the MCPCB
using a solder pick, pocked it thru the Batt+ LED wire hole in the shelf, try to feel I'm not sitting on a chip, applied steady pressure til breaking the glue bond holding the driver in
then pulled the driver down by the spring
You really can't fit the clip thru the switch hole, plus the MCU isn't right there to access.
Finished my mod today:
replaced the 24 AWG with longer 22 AWG wires (so I can re-flash without de-soldering)
replaced the stock 6500K SST-40LED and 17 mm MCPCB at 1.5 mm thickness, with a 5000K SST-40 on a 16 mm Noctigon (slightly thicker at ~1.6 mm)
sanded the shelf MCPCB contact surface out to 2500 GRIT, applied fresh MX-4
tossed the set screw used to keep the stock MCPCB from turning (Noctigon didn't have the cutout to support it)
re-flashed with Anduril2
22 AWG bypasses on the tail and driver spring
It now measured 8.1 amps on a 35E cell at 4.20V. Max lumens and throw is about the same as the stock light did on a VTC5D cell. For the heck of it, tried a 25S at 4.17V and read 9.0 amps, only about 75 lumens higher.
The lumens on the 35E initially is 2310 (Tom E), 2040 calibrated. It drops pretty quick. It really is more amps and heat then the SC31 Pro can handle.
The 5000K tint is an improvement, least from what I recall...
Would it be fair to say that the SC31 Pro isn’t easy to reflash with a newer version of Anduril unless you remove the bezel with force and desolder some wires to get access to the MCU?
Yep! At least though you don't have to replace the driver and lose charging, like I've done on many other lights .
Totally agree - if Sofirn goes with an open source driver, they really should make the effort to make it flash-able, now that we have a method to do so with the pogo pins.
I swapped the MCPCB out with one from an SP40 (i think), and a 219C 4000K. But I don’t think I’ll go harder; I was getting a little over 5A but that’s enough for me on that.
Well, could use an XM-L2 maybe, but I'd go with a 351D, tint of your choice, and diamond in the 5050 centering piece -- I've done this a few times before, and the 3535 LED comes out centered. Basically as you tighten down the reflector, the 3535 LED turns in the 5050 centering piece til it settles at 45 degree angles - usually hangs up there, dead on at 45 degrees so comes out perfectly centered.
Is this something you did? Dunno how that is done, but I haven't played with pogo pins much.
Same for me, so I wrote a PM to Barry who answered: “I don’t know there is a HCRI version of SST40, if it’s available, I will try to use it.”
Hence my newb question: as far as I understand, in order to swap a LED with another, both should have the same voltage (I believe some require 12V) and the same footprint, am I correct or should something else be taken into account? Is there a "compatibility table" somewhere, classifying the current LED models according to these two criteria?
+1
Another newb question: if wired properly, could the USB-C port be used to flash the MCU? That would be the easiest solution, no need to disassemble the light at all.
