Sofirn SC31 PRO, New Anduril Flashlight
352 posts / 0 new
TimMc
TimMc's picture
Last seen: 57 min 43 sec ago
Are there some good 4000K emitter alternatives to the SST40 5000K for the SC31 Pro? Grad
It’s a nice flashlight. I wish it were warmer than 5000K.
Tom E
Tom E's picture
Last seen: 8 hours 4 min ago
TimMc wrote:
Are there some good 4000K emitter alternatives to the SST40 5000K for the SC31 Pro? Grad It's a nice flashlight. I wish it were warmer than 5000K.
Well, could use an XM-L2 maybe, but I'd go with a 351D, tint of your choice, and diamond in the 5050 centering piece -- I've done this a few times before, and the 3535 LED comes out centered. Basically as you tighten down the reflector, the 3535 LED turns in the 5050 centering piece til it settles at 45 degree angles - usually hangs up there, dead on at 45 degrees so comes out perfectly centered.
flashburn wrote:
If you take out the switch, the Attiny is exposed well enough to contact it directly with slim pogo pins. A standard programming clip does not fit though the opening behind the switch PCB, but if you make one with 0.5mm pogo pins and SOIC breakouts and a wooden clothespeg, it works.
Is this something you did? Dunno how that is done, but I haven't played with pogo pins much.
Ryzbor
Ryzbor's picture
Last seen: 1 week 3 days ago
Luxeon V 4000K is a very nice and overlooked high-power 3V led. IMO way nicer than the SST-40. 4040 size though.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
Cemoi
Last seen: 19 hours 17 min ago
TimMc wrote:
Are there some good 4000K emitter alternatives to the SST40 5000K for the SC31 Pro? (...) I wish it were warmer than 5000K.
Same for me, so I wrote a PM to Barry who answered: "I don’t know there is a HCRI version of SST40, if it’s available, I will try to use it."
Hence my newb question: as far as I understand, in order to swap a LED with another, both should have the same voltage (I believe some require 12V) and the same footprint, am I correct or should something else be taken into account? Is there a "compatibility table" somewhere, classifying the current LED models according to these two criteria?
TimMc wrote:
@Sofirn: Please add pogo pads near the spring
+1wink
Another newb question: if wired properly, could the USB-C port be used to flash the MCU? That would be the easiest solution, no need to disassemble the light at all.
Ultrafire C3 2AA / Nitecore LR10 / Manker E03H / Fenix HL10 / Zebralight H501R + H51W / DQG Hobi / Astrolux M01 / CooYoo Quantum Ti (lost) / BlackWater Kite Al / Emisar D4v2 (Nichia E21A)
oweban
oweban's picture
Last seen: 3 hours 34 min ago
5050 3V is almost bereft of decent emitters (especially w regards to high CRI). XML2 in <3000k is about it. Hence me ripping it out and popping a 3535 mcpcb in, but needed a new centering ring, 7mm (but slightly loose). Either way, much nicer now,
TimMc
TimMc's picture
Cemoi wrote:
Hence my newb question: as far as I understand, in order to swap a LED with another, both should have the same voltage (I believe some require 12V) and the same footprint, am I correct or should something else be taken into account? Is there a “compatibility table” somewhere, classifying the current LED models according to these two criteria?
Similar Forward Voltage is required.
I think you can try to put a slightly smaller LED on a slightly larger pad (e.g. 3030 on 3535). TIR optic and reflector might need to be considered case by case…
SammysHP
SammysHP's picture
Last seen: 1 hour 44 min ago
Success! My SC31 Pro now runs Anduril 2. Flashed without removing the driver!
It was surprisingly easy. First I removed the switch bezel, the silicone switch cover and pulled out the switch PCB to have a look at the driver. The wires are long enough. The MCU is located right in the middle of the big hole – how awesome!
So I made a little jig to update the firmware. A 4-pin pogo-pin adapter to contact pin 5-8 (MOSI, MISO, SCK and VCC). Without a matching PCB (0.05” pitch) this was the hardest part. My final solution was to use a ribbon cable (comes in 0.05” pitch), crimping the pogo pins onto the ends and glue everything to a piece of plastic. After the glue has dried, I covered everything in hotglue and heat shrink tube (that’s my usual way of making custom adapters). RST was hooked right into the leg and GND was the easiest: Just clamp it between the head and the battery tube.
Now that everything was in place I connected the programmer and my laptop, built the latest version of Anduril 2 with the SP36 config (which is used by Sofirn for all of their Anduril flashlights) and hit return.
Everything went well, so I could remove all wires and put the switch back together. Done, Anduril 2 update on the SC31 without removing the driver.
oweban
oweban's picture
WELL MR LAH DEE DAH
Tom E
Tom E's picture
Nice! That's pretty cool!
SammysHP
SammysHP's picture
Btw it should also work with the usual ProgKey that fits Lexel’s drivers, Emisar etc. Four pins on the legs, the rest on the MCU. My first attempt was an all-in-one adapter with six pins, but I was not able to print such fine details with my 3D printer.
A little bit of silicone grease helps to screw on the switch bezel without rotating the switch cover and switch PCB.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 8 hours 46 min ago
Very nice.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, XPL HI 5000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
longuylander
longuylander's picture
Last seen: 1 min 4 sec ago
I just got my 18350 tube for my Pro today. Using a Convoy S2+ clip, it’s now wonderfully sized and carried deep in my pocket. Because the light doesn’t draw a ton of amps, it still puts out its full power too. It will be a while before something replaces this light as my EDC.
aginthelaw
aginthelaw's picture
Last seen: 4 hours 43 min ago
oweban wrote:
WELL MR LAH DEE DAH
I heard of him. Born in China. He lives down under now?
never fear shadows…it means a light shines nearby
Lightbringer
Lightbringer's picture
Last seen: 3 hours 10 min ago
Nah, he’s married to Queen Lah Tee Fah…
drewski
Last seen: 9 hours 19 min ago
Has anyone else done any output/run time tests on the SC31 pro yet? That one earlier in this thread made it look like it’s really a 250 lumen flashlight with a “2000 lumen” burst for a few seconds.
SammysHP
SammysHP's picture
The turbo is just for short bursts, indeed. A flashlight of this size cannot handle the heat.
Tom E
Tom E's picture
Just look at runtime graphs for other lightweight flashlights with too much power, for example the D4V2, even in Muggle mode:
https://budgetlightforum.com/comment/1535656#comment-1535656
and here:
https://budgetlightforum.com/comment/1319921#comment-1319921
Bigger Zebra here:
https://budgetlightforum.com/node/65105
Smaller Zebra here:
https://budgetlightforum.com/node/52033
Room temp runtimes without the light being held in hand are worse case scenarios. If usage is for a minute or two, then you could probably get away with 500-1000 lumens held in hand. Your hand acts as a thermal bridge to pull heat away.
Zebra flashlights are probably the best at thermal management, in the mechanical design, driver design, and firmware. Our firmware, like Anduril or Anduril2, is general purpose for lots of designs and has limitations based on the driver, LED's, mech design, etc. Zebra probably has about the best runtime graphs of all compact flashlights, meaning highest obtainable output over time.
how crazy is this
Last seen: 6 hours 2 min ago
Would like to see more run time graphs as well. However, I know my SC31 Pro is not a 250 lumen light with a 2000 lumen burst! Lots of stuff going on here and lots I am not certain about. However, last night I put said light into top of ramp an stood it on the top of the fridge while I proceeded to do dishes and clean the kitchen. I know thermal ramps can be subtle and it can be difficult to judge lumen by eye. There is no way that I was cleaning the kitchen on only 250 lumen.
Wish I had the equipment to do the measurements. Mine calibrated the temp pretty accurate and I think the thermal management is fantastic. My rough guess is that this light will do somewhere over 500 lumen till the battery goes. I think it does very well indeed for the size of the light. It shouldn’t throw 100+ meters either but I am certain that it does.
drewski
According to gchart’s test the pro held around 300-400 lumens for like 3 hours https://budgetlightforum.com/node/74573
. Definitely not as bad as my first impression, and considering all the other features this light has to offer, I may have one coming my way soon.
Of course better regulation could be had even in that size of tube light, like with the sp31 v2.0 or sp32a, which are basically the same size (in diameter) as the sc31 pro, but they can sustain over 500 lm for a few hours. Of course they are totally different drivers and don’t have the other features like usb-c, Anduril, so there’s always trade-offs.
Tom E
Tom E's picture
Yep, gchart's chart looks about right: https://budgetlightforum.com/node/74573
Thermal calibration is the trick smile
Felipe m bercilla jr
Last seen: 1 month 1 week ago
Good day blf as a newbie I would like to ask some help how to access the led button to correct the position of led button lights my flashlight is sofirn sc31 pro I just bought recently. I had only few tools a circlip plier and few precision screwdriver.thank u so much.
If not too much a detailed instruction w/ picture pls once again thank u.
SammysHP
SammysHP's picture
Unscrew the bezel around the switch, pull out the cover.
It’s done.
Thank u sammy.
Tendou
Last seen: 20 hours 7 min ago
Anyone have both the 6500 and 5000 temperature sc31pro? I already have the 5000k version. Would the 6500k increase throw and lumen much? And is it really cold or neutral white?
Bardo219
Last seen: 11 hours 46 min ago
Anyone know if the 5000k version is available from a dealer in USA?
amazon only seems to have the 6500k
Zappaman
Zappaman's picture
Last seen: 5 hours 50 min ago
Yep, got both and have used them side x side several times. I would not buy the 5k (or 4K version of the IF25a) for outdoor use where I live.
If you have woods out back the lower tints are probably preferred. But here in Kansas I need to see out there a ways… and I personally felt the 5k tint just didn’t get out there like the 6.5k. On turbo both threw nicely, but the 6.5 was clearly the better thrower.
AND, as this light gets SO hot (SO quickly), I set my ramp limit to about 70% on the SC31 Pro 6.5k and I’m happy with it (also using a 50g at 10A/5000mAhs so it doesn’t overheat so fast when I do run turbo- rarely).
The beam tint of the 6.5 is a real winner too- NO blue and little yellow. I nice white beam at closer to maybe 6k (guess). Compared to my SP33V3’s 6.5k color (on the white wall), I can easily see a warmer beam from the SC31 Pro (which matches the IF25a’s beam color too. Both have great tints).
ZappaMan
Lightbringer
I got the “6500K”, and trust me on this, unless it’s mislabeled, it’s nice. There’s even a yellowish hint in the hotspot, so all the blue must go into the spill, but there’s nothing objectionable in that at all. A little fried-eggy, but not bad at all.
My 5700k SP10B seems bluer than my SC31pros.
Tendou
Thanks! I think I will get the 6500k sc31pro as my 5000k sc31pro high doesn’t seems as bright or as throwy as even my SP32AV2
Nachtfeuerzeug
Tendou, The SP32A has a slightly deeper reflector while the cooler temp of the SC31 pro  6500K is visible a little further than the 5000K but have the same reflector.
In my signature items, there's a link where I modified an sp32A v.1 with an SST40, 5000K. The driver has higher amp draw than the SP32A v.2 so I really fought  and held off for a sale to buy an SC31 pro because I already had a super badbutt EDC. Anduril had a slight influence in my decision to buy the SC31. Wink
EDC
Reviews:
Zappaman
Zappaman's picture
Yep… the Anduril UI, and USB C charging is a seller for sure ;). I have to be careful to who I give an SP22aV2 to. It’s a nice UI for someone willing to play with it long enough to learn it, like Anduril.
But the extra maintenance of charging batteries outside of the light has been a challenge for some people (like my mother-in-law, the perfect muggle tester for me). She didn’t touch her SP10 after the battery died. But she can plug her (new) SC31 Pro into her USB charge station NEXT to her phone… no problem.
ZappaMan
