WUBEN
(WUBEN)
November 9, 2020, 2:24am
7
C3 is WUBEN 2020 new model that provides type C fast charging and 1200 lumens flood beam. Definitely, a must-have for daily use.
Could you check the code again, I have checked the setting and do what I can to it.
If it is still not working, I will create a new one.
niajef
(niajef)
November 9, 2020, 3:13am
8
just curious, on amazon.ca, theres 2 listing for the C3, one sold by wu ben, fulfilled by amazon, another sold by RX technology, fulfilled by amazon. i thought the one sold by wu ben is the legit listing, how come the link in your signature takes me to the RX technology one? lol
WUBEN
(WUBEN)
November 9, 2020, 4:22am
9
Because WUBEN has 2 AMZ CA stores lol
If you check WUBEN best selling item L50 is also sold by RX technology
JagerLion
(JagerLion)
November 9, 2020, 4:54am
10
What is the status on potentially dangerous overcharging on the C3?
Anyone tried the new Wuben C3 flashlight yet?
Just got hold of the Wuben C3 and tried some test.
I monitored the Wuben C3 charging the included Wuben protected 2600mAh 18650 battery. (connected a USB meter to check the USB charge current) -- at around 0.40A charge current (USB side), the indicator on the Wuben C3 will switch from 'red' to 'green', when I removed the battery and checked its voltage, it was around 4.13v with my DMM.
I reinserted the battery and continued charging it with …
WUBEN
(WUBEN)
November 9, 2020, 9:43am
11
We have received emails and messages from Facebook about this issue. And our R&D guys have worked out solutions to fix this issue.
Sorry to cause trouble to your guys and thanks for all the support. WUBEN will face the problem and fix it as perfectly as we can.
For the previous C3, WUBEN highly recommends using WUBEN original battery to charge rather than use other brands.
Swabs
(Swabs)
November 9, 2020, 2:09pm
12
I tried the 20% code the past two days, and it doesn’t work.
WUBEN
(WUBEN)
November 10, 2020, 1:30am
13
New code is updated, pls check the 20% OFF code: WUBENUSC3
https://www.amazon.com/gp/product/B08LG64XBV?th=1
Swabs
(Swabs)
November 10, 2020, 1:46am
14
I don’t know what I am doing wrong…? But, code still not working on the US site.
niajef
(niajef)
November 10, 2020, 1:57am
15
are you doing it at check out?
Swabs
(Swabs)
November 10, 2020, 2:06am
16
Yes, at check out under the Payment Method it says “add a promotion code… ”
I get a message that states “The promotional code you entered cannot be applied to your purchase.”
All I am trying to buy is the WUBEN C3 using the link provided in the thread.
niajef
(niajef)
November 10, 2020, 2:04am
17
did u follow his link? maybe its only for the listing from RX technology, not the one from wu ben
Swabs
(Swabs)
November 10, 2020, 2:12am
18
Yes, I used the link provided in the thread for the RX Technology listing.
niajef
(niajef)
November 10, 2020, 2:20am
19
it worked for me, i think u have to choose dark, not classic, but i dont know if thats the right one to order though, it does say pre-order
Swabs
(Swabs)
November 10, 2020, 2:37am
20
Ok, the code for the pre-sale dark unit worked. But there is no $3 instant coupon like stated in the OP. I will just pass on it after all.
Thank you for your help.
WUBEN
(WUBEN)
November 10, 2020, 4:08am
21
Ooooops, choose the wrong ASIN by mistakes.
Can't believe I have made such a stupid mistake. The code has correct to the right C3 that has $3 clip coupon plus 20% OFF and another 20% OFF for the holster when ordering them together.
Sorry again
niajef
(niajef)
November 10, 2020, 4:10am
22
WUBEN:
Can’t believe I have made such a stupid mistake. The code has correct to the right C3 that has $3 clip coupon plus 20% OFF and another 20% OFF for the holster when ordering them together.
Sorry again
i sent you a private message regarding amazon.ca
WUBEN
(WUBEN)
23
The ASIN is already correct, it will active after 4 hours ( based on Amazon rules)
Sorry again and again for the troubles that I trouble to you guys
Code worked for me. Thank you, WUBEN.
WUBEN
(WUBEN)
November 10, 2020, 6:23am
25
Thank you, Texas Hulk for updating
WUBEN
(WUBEN)
November 10, 2020, 8:45am
26
Just check Amazon messages a few seconds ago and did not found any messages yet.
Kindly double check if you sent through RX Technology , Link: https://www.amazon.ca/WUBEN-Flashlight-Rechargeable-Tactical-Charging/dp/B08LG64XBV/ref=sr_1_5?dchild=1&keywords=wuben%2BC3&qid=1604979113&sr=8-5&th=1
