Interested
Freeme, do you know if the parasitic drain, the previous FT02 was know for was fixed? Also how does the beam compare to the EC03 SST40? According to specs it is supposed to have more throw than EC03 SST40, is there any chance of beamshot comparison?
Also, do you know if the driver is the same as in EC03 or something completely different?
I have the same questions… the beamshot in the first post seems strange. Hotspot with a dark ring around it and another bright ring around that.
- No one has the light right now but they claimed low parasitic drain this round.
- I will post when my samples arrive later.
- Based on manufacturer's specs 639m(FT02S) vs 485m (EC03).
- Different driver.
Astrolux FT02 was 21700 Astrolux FT02S 26650 ?
FT02 - 21700 or 18650(with adapter)
FT02S - 26650 or 21700(with adapter) or 18650(with adapter)
Ordered 1x Astrolux® FT02S SST40 6500K
Thank You freeme!!!
Interested
Vould i get a code please
Shared.
Interested… Might wait for the XHP50.2 model and slice the domes. I think output will be similar between both LEDs and you will be limited by the battery you use.
Ordered one with 5000K! Tks!
interested in XHP50.2
Interested in both SST40 and XHP50.2
freeme - what’ll be the tint of the xhp50.2?
Pre-ordered!
Thanks pal!
Pre ordered
4x XHP50.2 in that host? That’ll get super heated in no time. The FT03 XHP50.2 could only handle 2 min max with one of them.
I’m expecting 1min on high not few seconds!
