I am producing a lighted switch with a diameter of 20mm
Someone tried to put the 21700 battery in the Convoy S11? It works? Will the positive terminal of the battery not deform?
It’s generally not worth lighting the stainless switches. it requires so much current to even be visible that it’s just a battery drain IMO.
excellent ! I’ll order one as soon as it is available :partying_face:
I tried with Samsung 50E and 40T - both work fine. Although I’ve put things together by myself but I assume stock version will take 21700 as well. Some “protected” 18650 are 5-7 mm longer so most of producers take it into account. Just pay attention your 21700 is 70mm long, not more. Which means it must be unprotected which (IMHO) is better. But I would recommend to use it with the adapter. S11 can take 26650 which means 21700 may rattle inside. The difference between 26650 and 21700 is 5mm, while between 21700 and 18650 is 3mm. When you bump your flashlight - this may make a difference.
Does anyone have beamshots of the lh351d 3500k or 2700k?
I would be interested to see these as well.
To everyone owns M21C-U, does your light after switching on high in 4mode setting step down from HIgH to moonlight within 10seconds?
Caramba just asked me about it if i have this problem he is experiancing and i just checked mine and it does this within 10s when set to MAX.
Weird...
Weird…
Yes, I noticed this on my M21C-U for 4 mode. This happened on high mode turn off(memory) and turn on again. It also happened for from off, double click to high.
I did some testing. This happened when battery is 3.8 volt and below. With a fresh battery, everything is fine.
I’m using P42A and 40T for M21C-U.
My combo exactly.
It shouldn’t step down from 100% to 0.1% at 3.8V
I’ve got an lh351d in 2700k coming in the post, I’ll post pictures when it arrives
My combo exactly.
I’ve just tested mine (with the xhp70.2) and it doesn’t do that, maybe the cell in yours isn’t providing the required voltage for that current.
Protected cell?
Molicel P42A and Samsung 40T....
Convoy S2+, Osram KW CSLNM1.TG, around 330 - 350m ANSI (not measured)
Convoy S21B, Osram KW CULPM1.TG, 410m ANSI (measured)
Just received my Convoy S21B KW CULPM1.TG. It has some strange, 3 weak oval circles, around the main beam. Is this as it should be?
Wow, thanks for shots of the S21B CULPM1 ! That is awesome!
Simon,
I just received my L21A CULPM1 last night! I wanted to say these things -
1. this was my first order from you, and my first convoy products (also got m21a CSLPM1) and they are fantastic! Build quality, threading, packaging, and looks. all awesome.
2. I received this order in 18 days to Eastern USA! I think that is amazing. No BS, just order and ship. Really appreciate that!
3. Both lights are VERY impressive! They both throw massively! The M21A with CSLPM1 is iconic - 21700 battery, C8 size, Super light and pocketable, and out throws all others close to its size i have. Look forward to having this as a go to light.
4. The L21A is a TOOL, it is solid, and very nice looking and seemingly unbreakable. Easily programmed it to my desired setting (#10). This thing throws easily with my other throwers of $100+. i couldn’t be happier.
Mine is the same. Purple outer ring.
An even cloverleaf is a good indication it’s well-centered. Any “irregularity”, eg, 2 short and 2 long, only 3 lobes, etc., generally means it’s a bit off-center.
The smaller the chip, the more critical it is to center it, and the harder it is, too.
Simon,
I am glad to hear that you like them
