I tried a bat stencil, sawn out of thin aluminium with a fret saw, but I made it too big, the edges of the wings do not receive enough light so they appear not sharp.
So it must be made tinier, not sure if that can be done nicely with a fret saw. And Iâm not sure about batman either, maybe I will end up with something entirely different
Jeff51 just posted about a batman projection contraption that uses a 100,000 lumen Imalent flashlight as a light source, and a 25cm fresnel lens with fairly long focal length. Pretty cool too, but not as silent, and maybe a bit less throwy than this one.
Tnx.
Today I got the 14AWG wire in so I could finish the battery carrier. I chopped the front section off the flashlight head 4mm above the shelf and sawed two grooves in the remaining rim to lead the ledwires to the side. Had to ream the holes in the shelf to 4mm diameter for these quite massive wires. Smoothed everything with sand paper so there were no sharp edges to cut into the wires. The wires were fixed in position with a good bit of kapton tape, does not look extremely profi but you are not going to look inside the lamp daily.
In the picture I show the old 18AWG wires too, so that you can see that 14AWG is a whole lot thicker.
I was lucky because with a 40T at 4.12V I measured 19.85 amps now, precisely what I was hoping for
So now that the battery tube was shortened, I could check the maximum flood setting of the lamp, with the slider towards the lens with the battery tube touching it.
In the picture the flood looks a bit less wide than in reality because of the wide field of my phone camera. Trees are at 25 meters as always. (it looks like I borrowed Flahoholicâs van for the beamshot )
Speaking of which, ships often have great spotlights, my cycle trip to work is along a small part of the Amsterdam port and Iâm always jealous of those marine mirror lights. They cost a fortune thoughâŚ
Yes, quite the modest LED and optics swap with a driver bypass
I could not get away with working on my dinner table. I have an Ikea Bjursta wall-mounted drop-leaf table next to my PC desk. It gets a bit cramped sometimes (about 90x50cm work area), but I quite like it. And it allows me to conduct mid-project research on BLF by simply turning in my computer chair, when I inevitably bugger something up
For who is into throw distance as unit (distance at which the illumination is reduced to 0.25lux AKA moonlight level), that is 4.36 km.
My Extech LT45 over-reads a bit, the Tasi 8133 makes it 4.24 Mcd but that may be under-read again. Letâs agree on rather throwy
(I do not dare to use my Mobilux classA luxmeter too much lately because the cable-connection to the sensor is rather worn-out and fixing it will require a completely new calibration as well, which will cost me 300+ euros)
