Search Amazon 3M Scotch-Brite 6×9” sheets. They come Red/Coarse Green/Medium White/Fine grit…
The abrasive pads are primarily used for auto body work, sanding irregular surface contours without worry of taking off too much material on sharp edges
Also used in metal working polishing, deburring, or “shoe shining” shafts on a lathe
For buffing off LEDs (diffuser) I’d try medium grit, or coarse if not effective
It must be a bit brighter than the Yuji led, see the chart below that I made a while ago, but we are still talking a few lumen from a 5mm led, so do not expect too much.
Picked up a total of 19 of these C01 (including 4 of the red version) on behalf of my own collection, for a couple of friends, and for Christmas gifts. Not sure if this iteration of C01 had an interest list, but I’m fairly sure I expressed interest earlier in the thread, so I wanted to give support and confirm that a purchase was made.
Really appreciate Sofirn being active here on BLF and making product decisions based upon our feedback. Can’t wait to receive them!
To USA buyers, when track on 17track.net, you need to change the carrier to “DHL ecommerce US”, while the default is USPS which give only a receving information.
I have to ask, does the C01 5mm “Sophia” Led version come with no glass lens?
Mine arrived today and works great, but I was wondering about the lack of a lens and an unpolished Alu “reflector” that you can touch because… no glass!
That’s the way they are conceived.
The C01S has an SST-20 “power”-led and a TIR optic.
The C01 has a 5mm led, sticking out of a “cone”.
Parts of the two heads are not interchangeable.
Maybe Djozz’s son can do another penetration test on the playground again? According to the first test C01 seems to sustain even toughest abuse. :smiling_imp:
yes, and that light was not potted, but he did not test it under water…
maybe this image will help people who did not ever see a Fenix E01:
I seek confirmation that the new unpotted C01, does in fact have the O ring around the LED…
that was the original first release of the C01, that had been potted with a material that did not set up hard, so Unheard repotted his… He found no O ring
