Sofirn SP40 Headlamp
168 posts / 0 new
niajef
Last seen: 14 min 33 sec ago
TimMc wrote:
niajef wrote:
why should you have waited though? what did sofirn say? e if they were replacing it, it would take a long time to ship from china, no? wouldnt it be easier to just return to amazon and order a new one from amazon?
Within an hour of sending an email they forwarded the video of the issue to their engineers and confirmed it was a driver issue with my unit. And offered a replacement from Amazon. I guess I could’ve kept the first kit for parts. But I had returned it before I saw the last email.
They still had stock in Australia at the time. It took 7 days for an LT1 to arrive from China recently when ordering from Amazon while there was no local stock so shipping is ok.
I’m happy with most of my Sofirn lights and their customer service. Smile
Well i havent had any problem with sofirm lights so far, so i cant really comment on their actual customer SERVICE, but i have been in contact with them for other things, and they are definitely very friendly and responsive! and judging by your experience, their service sounds very good…they should ship more stock to amazon warehouses around the world, they would blow up as the best value brand.
do u know if they have something equivalent to a ft03? i know their sp70 performs about the same, a little bit better, but its much more expensive and bigger.
TimMc
TimMc's picture
Last seen: 2 hours 9 min ago
I have used a FT03… maybe a Sofirn C8 is similar?
niajef
naw i just checked, theres nothing…the tk70 is 58kcd on turbo, only sp70 can match it with 160kcd at peak…shame
Tom E
Tom E's picture
Last seen: 26 min 26 sec ago
I've looked and looked and could not find any mention of anyone getting out the driver. So, here it is, done today...
 A 20 mm FET+1 should fit fine, but I'll lose the charging. Anduril2 using the switch LED's is the plan.
It's fairly unique. There's a vertical board extending up from the driver and through the switch PCB at the head, 2 posts, so 4 contact: grnd, switch, and one for each color LED. So the first thing you need to do is de-solder the 4 contacts on the switch PCB, then it loosens the driver. Pop out the switch PCB (no wires), then lightly tap down on the exposed vertical board til the driver glue seal breaks - didn't take much taps using a small hammer and screwdriver.
Pieces:
Close up of the switch PCB showing the ends of a PCB sticking up through it, with solder contacts:
Solution? Solder wick to remove the solder joints:
All clear now, it's loose and can be popped out, no glue:
Solder filled wick:
Driver details, PIC MCU:
Empty cavity showing the hardened glue used on the driver, and cutout on the left for the vertical board, on the right for the LED wires:
Pieces. MCPCB is 16 mm with screw holes, 1.5 mm thick. Will re-use the MCPCB but gotta decide what 3535 LED to use...
Driver replacement should go fairly easy. For the switch, can run 3 wires up through those holes, and solder to the pads. I plan on reusing the stock MCPCB. For the driver, a standard 20 mm will do, but will de-solder the brass ring on the spring side of the stock driver and transfer to the new driver to keep the same spacing for contact to the batt tube.
gchart
gchart's picture
Last seen: 8 hours 34 min ago
Nice tear down Tom!
TimMc
TimMc's picture
Thanks for the tear down!
Are you getting your driver boards done at OSHPark?
Tom E
Tom E's picture
Thanx! Yep, usually at OSHPark. I got 20 mm's in in the "After Dark" finish - they look amazin!
Just fyi, I posted a mod of another right angle light, the Amutorch AL1, here in the mod thread: https://budgetlightforum.com/comment/1716004#comment-1716004
Quadrupel
Quadrupel's picture
Last seen: 21 hours 46 min ago
What a driver Big Smile Now i see why it have no cooling ribs . Its possible, but unreasonable to modd this thing. Sofirn engineers have to be fired at once Big Smile
phouton
Last seen: 14 hours 50 min ago
@Tom E Thanks for taking such detailed photos of each step of disassembly! This is a great reference.
Tom E
Tom E's picture
Here's pics of the mod - 351D 2700K 95+ CRI reflowed onto stock MCPCB, 20 mm FET+1 DEL driver:
Transferred the brass ring from old driver to new. Thinking I may need the elevated contact surface with the battery tube:
From below, where the driver will go. Cleaned off all the glue, though it was tough goin. It left some scratches where the driver will sit on the edge:
From the top, sanded down the shelf to prep for the MCPCB. The circular patterns really aren't there, well, you can't feel them anyway:
Stock spring transferred, bypass added:
SIR800DP should be fine in this one. Tombstoned a 4.7K resistor for the AUX LED pinout:
All nice and clean, using Arctic MX-4:
Wired up. Long wires needed to reach the switch PCB:
Driver inserted (after flashing Anduril2), showing a shorty tube a friend sent me, total of 3 actually. Good for the SP40, SC31 Pro, and SC31B:
All soldered up, assembled. I do really like the Stickvise that someone on BLF recommended:
BillyBobJoe
Last seen: 4 days 10 hours ago
Has anyone had issues with the charging port on the SP40? Mine got really hot, started to smoke and now the light only has one mode. Off, on. And the red light on top flashes all the time. I’m not sure if its the fault of the headlamp or of the power supply feeding the USB.
Old_Klein
Last seen: 7 months 1 week ago
Hi Tom E
Can you share the .hex with Anduril 2 for the SP40.
I got a Oshpark Del driver coming soon. Will do same mod as you did Smile
Tom E
Tom E's picture
Old_Klein wrote:
Hi Tom E Can you share the .hex with Anduril 2 for the SP40. I got a Oshpark Del driver coming soon. Will do same mod as you did :-)
Sure. I'll rebuild new just in case of any updates. Can't recall off hand if updated after this mod.
Remind if I forget - got a list now of things to-do this eve...
Tom E
Tom E's picture
Here's the link to the Anduril2 for the modded SP40, with a FET+1 driver: google drive SP40
Let me know if it works, should be shared. It contains the .HEX file, as well as a ZIP file of the full source, configuration, and build files used. I use Atmel Studio 7 under Win 10.
The cfg file is as follows:
// Sofirn SP40 (rt. angle head) config options for Anduril 2
#define MODEL_NUMBER "0352" // Unique for this light, in MODELS listing
#include "hwdef-BLF_Q8.h" // same hardware as the Q8 (FET+1 with switch AUX LED)
// the button lights up
#define USE_INDICATOR_LED
// the button is visible while main LEDs are on
#define USE_INDICATOR_LED_WHILE_RAMPING
// enable blinking indicator LED while off
#define TICK_DURING_STANDBY
#define STANDBY_TICK_SPEED 3 // every 0.128 s
#define USE_FANCIER_BLINKING_INDICATOR
// off mode: high (2)
// lockout: blinking (3)
#define INDICATOR_LED_DEFAULT_MODE ((3<<2) + 2)
// TE 2020-11-15: Use the Emisar D1 as a reference for the ramp settings and thermal settings
// ../../bin/level_calc.py 1 65 7135 1 0.8 150
// ... mixed with this:
// ../../bin/level_calc.py 2 150 7135 4 0.33 150 FET 1 10 1500
#define RAMP_LENGTH 150
#define PWM1_LEVELS 1,1,2,2,3,3,4,4,5,6,7,8,9,10,12,13,14,15,17,19,20,22,24,26,29,31,34,36,39,42,45,48,51,55,59,62,66,70,75,79,84,89,93,99,104,110,115,121,127,134,140,147,154,161,168,176,184,192,200,209,217,226,236,245,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define PWM2_LEVELS 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,3,4,5,7,8,9,11,12,14,15,17,19,20,22,24,25,27,29,31,33,35,37,39,41,43,45,48,50,52,55,57,59,62,64,67,70,72,75,78,81,84,87,90,93,96,99,102,105,109,112,115,119,122,126,129,133,137,141,144,148,152,156,160,165,169,173,177,182,186,191,195,200,205,209,214,219,224,229,234,239,244,250,255
#define MAX_1x7135 65
#define HALFSPEED_LEVEL 14
#define QUARTERSPEED_LEVEL 6
#define RAMP_SMOOTH_FLOOR 1
#define RAMP_SMOOTH_CEIL 120
// 10, 28, 46, [65], 83, 101, 120
#define RAMP_DISCRETE_FLOOR 10
#define RAMP_DISCRETE_CEIL RAMP_SMOOTH_CEIL
#define RAMP_DISCRETE_STEPS 7
// safe limit ~50% power
#define SIMPLE_UI_FLOOR RAMP_DISCRETE_FLOOR
#define SIMPLE_UI_CEIL 120
#define SIMPLE_UI_STEPS 5
// stop panicking at ~75% power or ~1000 lm (use D1: D1 has a decent power-to-thermal-mass ratio)
#define THERM_FASTER_LEVEL (RAMP_SIZE*9/10) // throttle back faster when high
// TE - changes:
#undef DEFAULT_THERM_CEIL
#define DEFAULT_THERM_CEIL 55 // from 45 -> 65
#define MAX_THERM_CEIL 80 // from 70 -> 80
#define USE_2C_MAX_TURBO
// Make standard mode default, not Simple mode
#define SIMPLE_UI_ACTIVE 0
Old_Klein
Thanks man. Highly appreciated.
Will give this a go when i come home in January.
With Anduril 2, a short battery and a Lh351 dogfarts. This will be pretty much perfect for trail running
roughrider
roughrider's picture
Anyone in comms with Sofirn in regards to updating (moonlight, Type C port, etc.) this headlamp?
Tendou
Last seen: 3 days 23 hours ago
I find that using the 18350, the body is too short for the headstrap. How do you use 18350 with headstrap?
TIFisher
Last seen: 1 day 2 hours ago
No problem for me….
Tendou
TIFisher wrote:
No problem for me….
!{height:200px; width:300px}https://i.imgur.com/1xwyeao.jpg!
Seems that you need to use the rubber strap on tailcap. I guess there’s no other way then.
Jabe1
Last seen: 19 hours 4 min ago
I don’t own one, but it looks like maybe you can turn the battery tube around and it may work better. Assuming that the threads are the same on either end.
Couchmaster
Last seen: 4 days 16 hours ago
Has anyone else fried a 18350 battery using the micro USB charging when the short tube is on? Once the magic smoke was released I tossed the battery and put the 18650 tube and battery back on and it works perfectly. I don’t have the courage to get another short battery and see if it repeats it. Could have been the battery.
TimMc
TimMc's picture
The charger might be exceeding the maximum recommended charging current for the 18350 cell.
I tried charging a Keeppower IMR18350 in an SC31 Pro and it was using around 1.17A. The max charging current for this cell is 1.1A.
Couchmaster
Crap….I’m sitting here reflecting and I just realized what I did. I’m such a dumbass…..I had gotten a deal on Surefire CR123 Lithium’s cheap so I bought some and stored them in the same drawer (metal tool chest in the basement) right next to my rechargeable Lithium’s. They’re all in plastic cases and appear identical. BUT THESE ARE NOT RECHARGEABLE!!!! Surefire makes rechargeable in this size, but these ain’t it.
Quote:
Quote:
“The best 123A lithium batteries available, bar none 123As outperform alkaline batteries 10-year shelf life — they’re ready when you need them”
Holy F, I’m glad I didn’t stuff them into USB rechargeable lights and gift them to folks for Christmas. My mouth is open at my own stupidity. https://www.surefire.com/products/parts-accessories/batteries/123a-batteries/
TimMc
TimMc's picture
Did you avoid breathing in the fumes and letting it get in contact with your skin?
There have been some horror stories about cells exploding, followed by being poisoned and then long term impact to health.
Couchmaster
I hope so. I could smell it, which clued me in, but although the wrapper was melting, the fumes seemed minimal. It cooled off as soon as I took it out.
idahofarmer
Last seen: 6 days 18 hours ago
I can top your stupidity and raise you one. I was reloading some bullets. I grabbed the powder I needed (they put names on some brands and numbers on others) which was xxxx numbers (something like 4198, I cannot remember now). I loaded them up and went to the range and promptly blew my gun in half with a huge explosion. When I got home I tried to figure out what happened. Eventually I figured it out. I had transposed the numbers something like 4198 instead of 4891. I cannot remember what the numbers are now it was 25 years ago. But one powder burs faster and makes 3x the pressure so BOOM gun exploded.
Boy did I feel stupid. From that point on I used powders with names like titegroup, varget etc.
Couchmaster
Oh damn….I guess you were OK except maybe mentally? I don’t have any 10mm as it’s too close to .45 which I have and I don’t reload cause I’d be the type to double charge or stuff in the wrong stuff in a round here or there. I read about it on occasion. I should take a page from my firearm caution and give my non-rechargeable Surefire CR123 away and just stay 100percent with 18350 rechargeable only.
Hopefully you took out a beat up Glock and not a Sig X6 or Colt Python.
idahofarmer
Oh hell no on the glock, you knew it was going to be the most expensive gun I own right???
A tricked out HK 45 elite. Boom split the gun right in half. Bruised my hands and my ego. Luckily I had on some tough shooting gloves that day.
On a good note I told hk what I did and they sent a red label ticket for me to ship it back free. They fixed it and replaced most parts, reblued/blacked the gun and shipped it back one week later. All for 106 bucks. Serials didnt match but it was good as new.
gchart
gchart's picture
Now that’s service!
Scientist
Scientist's picture
Last seen: 3 days 11 hours ago
Can anyone help? My son in law got one of these just after they were released. He used it and loved it for hunting for one season. However now it isn’t working. When charging the button flashes red and eventually turns green. But when you turn the light on the button only flashes red and the emitter stays on for about 30 sec on high, longer on lower settings. The battery seems OK so I guess the driver has a problem? Anyone seen this?
Please illuminate responsibly
Part time fragmented conciousness technician
UV triple using Sofirn C8F
395nm High Power LED in Sofirn SC31b
