Oh my, it was a mess before and now it’s even worse
It would be best of one side switched their naming but I doubt it will happen because this would confuse their existing customers.
Vinh’s lights are far less popular but not rare enough to be disregarded. And he used the naming for a longer time, so there are quite a few mentions around.
I strongly suggest using neither Vinh nor Hank naming. Or at very least making it clear which is being used, i.e. Hank-W2.1. Even in the case of Hank-W2.2 - that’s because even if the name has a singular meaning now, Vinh may want to use it eventually.
The more I consider it, I think the nick names should be dropped altogether. Boost HL and Boost HX are clear enough and brief. Funny, we are on the 3rd generation of these LED's already.
I'm more concerned about the lack of knowledge of them here. Hank rates the K1 with the HL as more throw than the HX (650 kcd vs. 600 kcd), but that's just one data point, and we don't know what the amps and lumens are. I think these #'s are higher than the W1 and W2, but I'm not sure now, since Hank took those options down.
Wow I completely missed that, assumed the “W2.1” he listed was the CULPM1.TG until now and that there was a “W1.1” listed as well still. Yeah Hank’s nomenclature makes little sense IMHO.
I would personally just prefer to use the part numbers. CULPM1 (and the .TG part if we’re discussing the color variants)… I wander over to reddit and nobody is keeping any of the conventions for the “2.1” style names straight… If the part numbers are hard to remember, just specify 3030 or 4040 and 1mm or 2mm.
The good news at least is that probably nobody is actually talking about the CULNM1.TG because it’s basically impossible to get a hold of. So that assumption makes things slightly easier to figure out…
That post is old (days? ). I've dropped the nick names in favor of their real names: Boost HL and Boost HX. Simple, to the point, can be shortened to HL or HX, and the manufacturer named them that way, so what could be better?
OSRAM LED’s for max throw
Color Part # footprint (LED surface) Max/Pulsed Peak Output (A)
White – KW CSLNM1.TG – 3030 (1mm²) W1 3/3.3 A 4.5-5.0 A (W1/NM1)
White – KW CSLPM1.TG – 3030 (2mm²) W2 5/6 A 7.0-8.0 A (W2/PM1)
White – KW CULNM1.TG – 4040 (1mm²) 3.3/4 A ~6 A (Boost HL)
White – KW CULPM1.TG – 4040 (2mm²) 6.6/8 A 9 A (Boost HX)
Red – KR CSLNM1.23 – 3030 (1mm²) W1
Blue – KB CSLNM1.14 – 3030 (1mm²) W1
Green – KP CSLNM1.F1 – 3030 (1mm²) W1 3/4 A 6.5 – 7.0 A
Green – KP CSLPM1.F1 – 3030 (2mm²) W1
Just fyi, if you follow the links to the individual LED's above, you may notice the W1, W2, and Boost HX are in full production phase, while the Boost HL is in End-Of-Life and not recommended for new designs. This may explain the availability issues.
Yeah, I remember when Led4Power had the CULNM1.TG/Boost HL he could only get a small number and they were already discontinued.
Sorry, I wasn't really addressing your table in particular, but rather the use of the "W2.1" style nicknames in general - I keep seeing them used inconsistently so I never know what is actually meant by them...
The CULNM sold by L4P was also a low flux bin. Surprisingly Fireflies was able to source the 6Q, which is the 2nd highest flux bin for their new lights. I wonder if the emitter is not really discontinued. They are probably still making them as long as the purchase quantity is high enough.
You’ll want to use the CSLNM1 for the S2, to get similar throw on the CULPM1 it needs to be driven at 7.4 - 8A and that’s getting way to hot in such a small host
To use the CULPM1 in the S2 requires Simon’s fet driver and he won’t give any warranty for it. I’m running it in my C8+ with a Samsung 30Q which peaks at 7.4A, no higher. I get 1300 lumens and 1002m range. I only have a cheap meter so I like to subtract 50m off that measurement
If you don’t want to run at 7+ amps with an 18350, wouldn’t the CULPM1 not be recommended for a C8+ 18350 tube? since it needs to be driven at 7.4 – 8A?
I installed a Boost HX (CULPM1) into an old SD Mini yesterday, running Anduril2 on a FET+1 driver. I extended the LED wires a little, using 22 AWG, and both springs are bypassed. The SD Mini is about the same size and design as the MH20GT. I tested it with a few different batteries, trying to find the sweet spot in amps.
So far it seems like 8.75 to 9.25 amps results in the most output. The highest I tested was with a fully charged VTC5D and measured 10 amps with output about the same as 8.4 amps. I haven't seen any signs of the LED turning blue, or any other damage.
Best calibrated lumens at start was: 1440 lumens (1630 Tom E lumens)
had an "original" Luxeon V in it that had an annoying blue ring around the hot spot
it's in great shape, even though I EDC'ed it for quite a few months, maybe year or 2
it's a really nice quality compact thrower - good factory focus, excellent quality reflector, good AR glass
it was already modded with a FET+1 driver (not sure if a regulated 9 amp driver exists in this size)
has the lit switch so perfect for Anduril 2
I must say without any focusing done, the hot spot looks well defined. I used the original 5050 centering piece I had in there, so the 4040 Boost HX twists into position but seems to be pretty well centered, based on how the hotspot looks. I couldn't use Simon's 4040 centering pieces I bought because they are for 7 and 9 mm holes, and the SD Mini was about 7.8 mm.
I see djozz came to about the same conclusion, at https://budgetlightforum.com/t/-/61873/9:
I bought these from Simon, BIN1:8RF-fcbB46-B5-6000, pre-mounted. This one was on a 20 mm MCPCB that had to be trimmed slightly to fit.
I found on some builds 6A hits just above 1300 at 30s, and others that need 7.5-8A. There’s a lot of variance with these.
Why doesn’t Simon’s 8A driver run at 8A? I understand resistance but on some L21A units it’s around 6.4A and others 7.2A, never higher with a topped off 40T, both running at 1300 lumens. Must be to doing with the led?
Came across a faulty driver that maxed at 3.97A, what would have failed?
Yes, I assume there are variances in the LED's, maybe though these are worse than most? I thought CREE's were binned pretty good.
I'm not familiar with Simon's 8A driver but the only right way to do these high amps (8-9A) with these LED's is buck/boost, and that's probably expensive. If his driver doesn't do boost, then the circuit resistance matters big time. You need to do everything right - spring bypasses, decent size LED wires, decent cell. I assume his driver probably has more internal resistance than a FET+1, so all those make a difference. Basically, you need higher amp capability in order for his driver to regulate or buck down.
The 40T is good but still you need to address the rest of it.
Btw, in the past when I used to buy drivers, we were always buying 4 amp, 5 amp, 6 amp rated drivers relatively cheap, and I could never get the rated amps out of them, ever... It's not surprising. 2-3 amps is easily do-able, above that, it's not easy.
