It’s a 3V LED so it will work, though it won’t drive the LED to it’s max potential. I’m using Simon’s 8A buck driver.
The Osram’s have very small emitting areas so have more throw than other LEDs. The CULPM1.TG is a 4040 package so can be driven to higher currents than the 3030 variants.
Unfortunately I don’t have a spectrometer to measure CRI. It’s ~4900K at the lowest current setting and ~5250K at 8A. I’m getting ~1600 lumens OTF with the M21C host. I got decent focus just dropping it right in with one of the 4040 centering rings. I did have to put a shim under the bezel as the reflector moved around slightly if I shook the light too hard due to the thinner centering ring.
Can’t get any beamshots tonight; it’s pouring rain outside.
If you see a dark hole in the center of the beam only when it’s close to a wall, that’s actually a sign of a well-focused emitter. Totally normal for a thrower.
Everything that hits the reflector gets tossed forward in parallel rays. Anything that comes out the front of the LED ends up as spill. The “hole” in the reflector where the LED sits, and inner part of the reflector where no light from the LED hits (coverage is never 180° but maybe 160° at best) is also part of that hole.
Imagine the hole being really big, and you don’t have a cup for a reflector, but a curved ring. That’s what’s projected at least until the hotspot diverges enough to fill it in.
Pretty much all my good throwers have at least a slightly darker spot in the middle.
Anyone know what to do with the Convoy Z1 squeaking when adjusting focus?.
Simon said it was because of the wrong orings so I installed his replacements……same issue after about 3 minutes of focusing in and out. If it was for personal use I wouldn’t care, but I have to sell these.
lubed threads = no difference, lubed oring = problem solved, but it’ll dry and cause an issue down the line and also a dust problem. Installed thin S2+ orings and it’s perfectly fine but won’t seal properly.
This is a deal breaking issue for stocking these in the future. Some people report not having this issue and others who have reported it. I’ve had it on every single one, either straight away or after adjusting really fast for 3-5 minutes, the noise starts.
Really missing the push/pull setup after this mess.
Push pull setups are simple, tried and tested. They also work well in rainy days for as long as you take a bit of care with the zoom mechanism.
I guess Simon is paying for the hazing with this flashlight, product assessment and development has been inadequate or not good enough. It still is great but, as with anything, you must believe right. This at least means mainly listening to the people who actually cares about the product you are developing, and listening to knowledgeable customers.
In any case one must not throw in the towel with things like this, but persevere and improve them.
