Hi from NYC
11 posts / 0 new
Noodles
Noodles's picture
Last seen: 3 years 3 weeks ago
Hi from NYC
Heyas, Been Lurking for a a bit now just thought I would post a hello post.  It's been about a year since I got into budget torches.  Here is part of my current line-up
Not pictured are a few Sacredfire NF007's and a TR-803 Q5 that I lost Cry(I loved that lamp)
The HugsbyP2 has Q5, Superfire has Q5 and the UF501b has anR2.
I do have on order a good amout of stuff:
A Few Drivers from KD
http://kaidomain.com/ProductDetails.aspx?ProductId=1694
A "TRUE" Solarforce L2 body+flat Bezel from itc
A few 501a Bodiies from Manafont
And two R5 dropins, one from Manafont deal here on BLF and one from an Ebay seller.
Sorry for the long post, but i'm looking into the XML now and saw this on KD, anyone have it yet?  I love the SKYRAY host.
http://kaidomain.com/ProductDetails.aspx?ProductId=11104
The Giggle Loop
fishinfool
fishinfool's picture
Last seen: 2 years 2 months ago
Aloha and welcome to BLF Noodles!  Nice selection you have there.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Budgeteer
Budgeteer's picture
Last seen: 8 years 3 weeks ago
Welcome!
"Sorry for the long post, but i'm looking into the XML now and saw this on KD, anyone have it yet?  I love the SKYRAY host."
I do!
pulls over 3A with a full cell. Very floody, a nicer tint, very bright, very hot. Using aluminum foil on the dropin for a tight fit is mandatory. The reflector is orange peel and as such diffuse/smooth the beam considerably. Not a thrower by any means but a almost pocket light cannon.
It's great and has a decent driver. The body can't cope with heat at extended full brigtness sessions. 10-15min sessions are althrough quite ok. The medium can run easily till battery gives up. Would love a SMO reflector instead of an OP though.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Don
Don's picture
Last seen: 1 year 1 hour ago
Me too
It puts out a LOT of light. Beware of heat, make sure the dropin is a tight fit into the light body.
And welcome to BLF
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
charlestt
Last seen: 4 years 4 months ago
Welcome to the Club !!
I also have the XML drop-in and it's by far my favorite for the sheer amount of light it produces Smile
 http://i776.photobucket.com/albums/yy41/charlestt225/Sig/A1200023-1.jpg" width="159" he
Noodles
Noodles's picture
Budgeteer wrote:
Welcome!
I do!
Thanks for the welcomes Smile
Would you guys say that we go high drain batteries (IMR cells on )these new emitters (XML). if usining 18650's  xfires no prob. for the most part,  but to build this in an 16340 I would think high hight drain are a must?
Also I have read that the 501a will accept an 18350 battery?
The Giggle Loop
Don
Don's picture
If you want to go the 16340 route you'll need to use IMR cells, 3A from small cells is bad for them. Runtime on high will be of the order of ten minutes.
I'd give the 501a body a miss and get a Solarforce L2m body instead. Much more mass for heatsinking.
Noodles
Noodles's picture
thanks Don,
I will then put some Q5's/r5  in the 501A's, they are for my parents house ( father knows Li in care) We have plenty of foil paper here .  I will probably  try that XML next month or so the SKYrRAY.
In my EXP the IMR  cells are great when they are at peak, but they drop off output quicky, so quick that it is scary
The Giggle Loop
Budgeteer
Budgeteer's picture
Same as Don suggested, perhaps the KD C8 XM-L might be an option too for not much more.
sb56637
sb56637's picture
Last seen: 6 hours 52 min ago
Hi Noodles, a warm welcome to BLF! Thanks for joining, enjoy your hobby here!
Sorry, I don't know anything about XM-L emitters. I hope to learn as soon as they start putting them in 1xAA lights. Wink
brted
brted's picture
Last seen: 6 days 23 hours ago
Welcome to BLF, Noodles! There are some good pictures of the RQ07 with XM-L T6 over at CPF, if you are registered there (I don't think they let non-registered users see their Budget Lights Subforum):
http://www.candlepowerforums.com/vb/showthread.php?t=305498
