Very pleased with my first Sofirn lights: a blue and an orange C01S, Low-High modes as expected, very nice tint. I added a piece of thin frosted film to remove a few artifacts in the beam, which is now perfectly smooth.
I'm considering the following mods:
Adding a magnet (I'll have to order some, found a dealer on AE who sells them by 10 pieces only, I don't need 50 or even worse 10 units). Question to those who have done so: I assume the magnet has to be glued, and therefore cannot be removed later?
Filling the trit slot with resin + GITD powder (I don't want any tritium).
Painting small parts of the lights with high quality GlowInc GITD paint (tail, and edge of the head).
I’ve added magnets to some, a trit vials to one, and tried resin + glow powder with one. The glow powder did nothing for me, can hardly tell it’s there. If trit vials are an option, do them! I love mine with a trit. But if it’s between glow powder and nothing, go for it.
Magnets… At least I needed glue. I put a small drop of super glue gel in the hole and then put the magnet in. To make sure I got it at the right level, I found a piece of horizontal steel (top of my fridge), laid down some foil, and then put my C01S on it, magnet side to the fridge. That sucked the magnet level while the glue cured.
Not sure why it hasn’t been brought up before now but the trit slot is far too deep and too wide. I know we wanted plenty of room but it’s really hard to center and it sits really far down in a pool of UV glue. It’s usable but it would cool if it got refined at some point.
This is not “a little glue on top”, I wouldn’t even mention that. This is “2-3x as much glue as necessary” and a plain waste. Unless you do something like shirnask and fill in the bottom or try to layer the glue it’s way too deep. When you layer it you just create bubbles or make it uneven.
I would like the low~~high one, but the first link offers extra discount for ordering 3 at once, so if those are also low~~>high that would be extra nice.
Edit:
In the opening post is says this:
So I guess all but the black one are low->high, no matter where you order it? Maybe the only difference between above 2 links is the BLF engraving?
I ordered using https://www.aliexpress.com/item/32952525303.html because it was slightly cheaper and got low>high. I don’t think the engraving is different, no idea why they have two listings…
Earlier in this thread i saw some pictures of the driver board, but no real details—has anyone done a deep dive into the boost and controller circuits? Is it using Torex Semiconductors?
