Current draw measured. In standby, the draw is a measly 7.5 uA. With LEDs at full brightness it’s 84 mA. With how I had the CN5710 set, I was figuring around 90 mA, so not too shabby.
Driver testing is complete. Anduril is fully functional! [WARNING - flashing lights!]
Small update, but it’s an update I guess. I drilled the holes for the LEDs and dry fitted them. Not quite sure what I’ll use to glue them in place… UV-cured glue? Hot melt glue? I’m out of clear epoxy. I’ve got JB weld but that would look unsightly. Probably just the UV glue I guess.
One of the more difficult things that I didn’t anticipate is that this kind of plastic doesn’t take glue very well. Hot glue was a no-go. Original Gorilla Glue fell right off. Gorilla Glue Super (CA) Glue Gel didn’t do any better. I ended up having some success with DAP RapidFuse.
Thanks guys. The Anduril thing was purely for the fun of it. What would have been much more purposeful is to have it be a simple on/off switch with a fade-out after like 30 minutes (assuming the child will probably just fall asleep with the light on). Sure, there’s sunset mode but I’m not going to encourage the child to tap 3 times then do another 2 taps. I would consider reflashing the driver after the competition, but umm… it’s glued down and the programming pads are on the glued-down side. Oh well, it works just fine. If she’s has problems with it, I’ll rip the driver out and put in a new one.
Great job gchart on your build. I love to see your electronic experience in action.
I am always learning from your posts how to wire things together, Thank You for all your contributions here at BLF.
I watched the video and truly laughed out loud when I saw you ramp the light up. The use of Anduril on such a light is, to me, the cherry on top for a BLF competition.
