[SOLD}: JetBeam RRT01 (original release)
For Sale: JETBeam RRT01 CREE XM-L2 LED Flashlight (original release). $65 PayPal, shipped USPS Priority Mail in the USA. Never carried, no scratches, in mint condition, works perfectly. Includes lanyard, spare O-ring, and hex key for pocket clip screws.
Photos available in Google Photos at https://photos.app.goo.gl/N3p9Dg5VxCxxMLbh6
Manufacturer's Description:
Features:
Specially-designed for different purposes like military, law enforcement, self-defense, hunting, outdoor, search, rescue etc.
Rapid power-on and brightness adjustment by rotating the bezel control ring
Magnetically-controlled stepless brightness adjustment system
Stainless steel lens retaining ring protects against impact
Durable stainless steel lanyard hole
CREE XM-L2 LED with a maximum output of up to 600 lumens with RCR123A battery
New two-section curved reflector custom-designed for CREE LEDs improves reflective efficiency and focusing capability
Effective throw of over 113 meters
Newly designed high efficiency broad voltage drive circuit
Titanium pocket clip
Able to tailstand for use as a candle
Impact-resistant in accordance with US MIL-STD-810F
Waterproof in accordance with IPX-8 (2 meter submersible)
Specifications:
Model: RRT01
LED: CREE XM-L2
Maximum output: 600 lumens with RCR123A battery
Reflector: Custom-designed precision metal reflector
Lens: Double-sided toughened mineral glass with anti-reflective coating
Material: Aero-grade aluminum alloy
Finish: HA III military grade hard-anodized
Battery: RCR123*1 / CR123A*1
Standby current: 50ÎĽA
Switch: Rapid Response Control Ring IPX-8 standard waterproof (2 meter submersible)
Dimensions: Tube diameter 23mm, Total length 81mm
Weight: 46g (without battery)"
I’ll take it. My son wants this carry.Please Pm PP info.
Paypal sent. Thank you!
SOLD!
congratulations!
I think it is a version with strobe too (based on the direction of the writing)… winner in every way :+1:
congratulations!
I think it might have strobe too,
(Eye10 driver as in your 2019 model) :+1:
note: on the bottom light, the RRT-01 label, reads left to right when bezel is on the left:
I think, when bezel is to the left, if lettering is right side up, yes strobe
please confirm, if convenient :slight_smile:
I can't directly confirm, as it's packed up and ready to go out in the mail. But a 2014 user review on Amazon contains this information (I got mine in 2012, but I don't know when any change was implemented by the manufacturer or what production run the reviewer's light came from):
I bought two Jet Beam flashlights the JETBeam RRT01 and the JETBeam PC10. I was going to decide which one I wanted to keep the cheaper one or the more expensive. Both lights are very good and I was impressed by the quality so I decided to keep them both. Even the packaging is professional with manuals everything you need and comes in a little space efficient box. Jet Beam lights are very good quality, there isn’t anything cheap or frustrating about them that I found. They are waterproof and submersible, for use in pools or diving. The JETBeam RRT01 has all functions and even more then listed in previous reviews. I tried the light with CR123 and RCR123 batteries you do get more lumens from the RCR battery, but all functions with both batteries. The on switch is a rotating dial around the light, which gives off gradual amounts of light. The light can be very minimal similar to a very low glow which you can barely see even in the dark to a very bright light. I found the lumens ratings are accurate. I have a 900 lumens light and this one is very similar. The users manual says it does have a “hidden” SOS mode. To get to the SOS mode you twist the on switch 3 times making the light go into SOS mode. You can also choose your brightness for SOS mode, very minimal or full power. I found the light also has a Strobe mode, which none of the reviews or users manual mentions. To get to Strobe mode you twist the on switch 3 times making slight minimal twists. The SOS mode is large more liberal twists. Maybe these can get confusing to people so the manufacturer doesn’t mention it. I found all functions work with both batteries, however you do get more lumens from the RCR123 Batteries. I use the Nitecore RCR123 rechargeable batteries; they have 3.2 volts instead of the 3.0 volts like most RCR123 batteries.
thanks for that quote, suggesting by 2014 the RRT-01 had strobe at three quick rotations, and SOS at three slow rotations
I have a light with that driver, it is an Eye10 TiC… it actually gives strobe at 2 quick rotations also
there seem to be several variations
the strobe function is at 2 quick rotations on my “2012” RRT-01 as well, as in my Niteye Eye10 aluminium version.
my impression is that as new models came out on the Eye10 series, those drivers also went into the RRT-01 lights, over time…
even up to the 2019 RRT-01, the drivers are still marked Eye10
Thanks Jon,
It will make a great Christmas gift to replace my son’s 12 year old JetBeam Jet II IBS. And perhaps keep him from constantly attempting to ” borrow ” mine. :slight_smile:
