I am aware that batteries can be recharged outside of the light, but for convenience in these modern times i feel that EDC lights are more versatile being charged internally, than having to take the battery out every time.
BTW the most versatile external charger i own is the Olight universal magnetic charger.
I find with USB rechargeable lights i frequently just plug in and top the battery up as and when. With non rechargeable lights I tend to wait until the battery is more depleted before i bother to charge them externally, meaning these lights are rarely fully charged compared to rechargeable lights.
Sorry, i should have been clearer; i was reffering to my KR4, so meant 18650s, and of course the Emissar only takes unprotected batteries, which would be difficult to source at retail.
Thanks for your POV; i have not yet had any issues with the USB rechargeable lights i own.
^ This is where i stand on internal charging. 1/3 of my lights have it, and i never use it. Well, correction, I use it occasionally on my 3x18650 light because I want to cut down on tearing the outside plastic wrap of my double wrapped button top 30q’s.
Maybe its because i’ve been familiar with IC in the vape world for years before flashlights were in my life, but I saw more problems then it was ever worth using the supplied IC, because usually the MFG used subpar parts (whatever they may be) to include the IC, and it failed and sometimes brought the function of the device down with it. Not worth the headaches, especially when You can buy a XTAR VC4s or whatever solid charger for under $30. I think most of us have batteries coming out our ears (at least i know i do) and so being with out a fully charged battery is less of a concern than not using them enough before their life cycle is effected.
Charging multicell lights externally is a pain in my opinion. Lately I look for rechargeable lights only. Add a USB meter to monitor the process helps.
i think i would always wanna charge the battery in a charger if i can, this way i can still use the light while the battery charges, especially when you have multiple lights/batteries that need to be charged, its more efficient in terms of ports needed, and more space saving cuz u dont have a clutter of lights lying around the power source. with that being said, even though having built in charger is not 100% necessary for me, i think its definitely a nice to have feature in certain situation. its a big plus as long as it doesnt compromise price or quality.
I think for introducing anyone new to lithium ion-powered lights, gifting them a light with a good built-in charger is a great way to keep it simple for them.
After all, first and foremost is to dazzle them with modern LED technology - the nuances of maintaining an Li-ion cell can wait for later!
^ This. Internal charging is a must for a muggle light.
For me, I have enough 18650s and 21700s I just swap cells then put the depleted one the charger, then it’s available for the next swap when it’s charged. I don’t generally like internal chargers for my personal use.
Removing batteries is so last year. The removability should be retained. It will save wear and tear and accidentally putting in batteries backwards. If the usb port goes bad then you can go back to external charging.
My Sp 36 overcharges by a little. I am going to start taking it off charge when the current is a bit higher. Hopefully it will be the same current at a certain voltage every time. All my other internal chargers stop between 4.1 and 4.2. The SP36 stops at 4.24. Not horrible but I would like it to be lower.
Internal charging is a godsend for a frequently used light. This time of year, my headlamp gets used for an hour each night when walking the dog. So convenient just to be able to plug the light in as soon as I walk through the door to give it a top-up. Surely, not having to crack open the tail-cap each night saves wear and tear on the springs, o-ring and threads.
I would feel better if someone could test and explain the safety and reliability of built in charging. I only have a couple of Sofirns with this feature. Tested in that the light didn’t get particularly hot and seemed to terminate about where my chargers do so I guess its OK. Get the convenience. However, I feel better about doing it on a charger and knowing what my battery is doing. Also, the smart charger seems to be just easier on the batteries and treats each battery different according to the IR of the battery I assume. Just seems like a better route to me. Always have fresh cells available and always walk the dogs with two lights anyway;-) As I live in the city and don’t want to disturb my neighbors I walk with a low enough level that I go weeks in between swapping batteries unless I do something more demanding. With my Andrul light I just wait until it gets down to 3.7 or so.
If you have access to a multimeter and a USB tester meter like this one, you could evaluate the charging in your own lights.
With those tools, you can measure the charge current, termination voltage, and you can check if the charger never stops (like some cases of the Wuben C3). Depending on how the numbers look, it can give you a bit more peace of mind using the built-in charging when you aren’t able to bring a proper charger.
This is actually what i noticed with my TC12 compared to the KR4. For my frequently used EDC i had peace of mind just knowing i could plug it in after use and it would be fully charged at all times.
I originally preferred non-rechargeable, but my attitude has certainly changed, which is why i think its such a useful feature nowadays.
I find more and more I’m graduating to preferring lights with built-in charging. Got a nice stable of decent chargers and that, but it’s gotten really convenient to just plug a light in. I especially like how Sofirn is putting USB-C in their lights now. Almost all my electronics are USB-C now. Even got a cheapo electric razor which charges via USB-C. Got an SP36 and an SC31 Pro - Anduril with USB-C charging. It’s a type of bliss.
How much do you use the light? 18650’s have tremendous capacity. There should be no need to worry about runtimes. I use a torch daily, although only for short bursts at a time. An 18650 light will last 2-3 weeks before even getting to the point where it needs charging.
Because of the ramping feature i frequently use it as lamp of sorts, whilst working, so an 18650 can be depleted in a day sometimes.
But that was not the original point of the topic. I initially saw no point in rechargeables, but now think its usefulness outweighs the negatives. As a relative newbie i wanted to see what the general consensus was in 2020.
I would be able to give more of my lights to friends and family if they only had charging. As long as you have the ability to monitor the charge, I see no negatives to it and feel it is the future. Humans like the path of least resistance. External chargers can have their quirks also. Definitely not foolproof.
